查看: 880|回复: 0
[编程申请]:大家帮帮我看看这个程序的问题在哪里?
发表于 2005-6-9 10:56:31 | 显示全部楼层 |阅读模式
(defun c:pl_sum_t()
   (setvar "cmdecho" 0)
   (prompt "\n选择要统计长度的线槽")
   (setq ss (ssget '((0 . "LWPOLYLINE"))))
   (setq ss_ll_300 0)
   (setq ss_ll_250 0)
   (setq ss_ll_200 0)
   (setq ss_ll_150 0)
   (setq ss_ll_100 0)
   (setq ss_ll_50 0)
   (setq n 0)
   (repeat (sslength ss)
      (setq en (ssname ss n))
      (command "lengthen" en "")
      (setq ss_l (getvar "perimeter"))
      (setq en_data (entget en))
      (setq ss_w_list (assoc 43 en_data))
      (setq ss_w (cdr ss_w_list))
      (if (= ss_w 300) (setq ss_ll_300 (+ ss_ll_300 ss_l)))
      (if (= ss_w 250) (setq ss_ll_250 (+ ss_ll_250 ss_l)))
      (if (= ss_w 200) (setq ss_ll_200 (+ ss_ll_200 ss_l)))
      (if (= ss_w 150) (setq ss_ll_150 (+ ss_ll_150 ss_l)))
      (if (= ss_w 100) (setq ss_ll_100 (+ ss_ll_100 ss_l)))
      (if (= ss_w 50)  (setq ss_ll_50 (+ ss_ll_50 ss_l)))
      (setq n (+ 1 n))
   (setq str1 (strcat "你所选择的线槽宽度为300" "总长度为:" (itoa ss_ll_300)))
   (setq str2 (strcat "你所选择的线槽宽度为250" "总长度为:" (itoa ss_ll_250)))
   (setq str3 (strcat "你所选择的线槽宽度为200" "总长度为:" (itoa ss_ll_200)))
   (setq str4 (strcat "你所选择的线槽宽度为150" "总长度为:" (itoa ss_ll_150)))
   (setq str5 (strcat "你所选择的线槽宽度为100" "总长度为:" (itoa ss_ll_100)))
   (setq str6 (strcat "你所选择的线槽宽度为50" "总长度为:" (itoa ss_ll_50)))
   (alert (strcat str1 "\n" str2 "\n" str3 "\n" str4 "\n" str5 "\n" str6))
(prin1)
我已经知道了,谢谢各位!(itoa错了)
GMT+8, 2026-11-6 00:55 , Processed in 0.532490 second(s), 32 queries , Gzip On.
