查看: 1401|回复: 4
[ARX程序]:怎样把防护林线型文件调出在半径编辑框中显示1, 半径编辑框中显示100?
发表于 2002-4-20 00:04:12 | 显示全部楼层 |阅读模式
在土地平整设计中, 需要布置防护林. 在图纸中, 一个圆圈表示一棵树, 一排圆圈表示一排防护林.
再用以下文件Y.LIN定义一个线型作防护林用:
*YYL1,F2 circle     0     0     0     0     0     0     0
A,0,[CIRC2,Y.shx,s=1],-100
怎样在以下C文件的半径编辑框中显示1, 半径编辑框中显示100?
// MyExam07Dlg.cpp : implementation file
#include "stdafx.h"
#include "MyExam07Dlg.h"
#include "exam07.h"
#ifdef _DEBUG
#define new DEBUG_NEW
#undef THIS_FILE
static char THIS_FILE[] = __FILE__;
#endif
// MyExam07Dlg dialog
MyExam07Dlg::MyExam07Dlg(CWnd* pParent /*=NULL*/)
        : CAcUiDialog(MyExam07Dlg::IDD, pParent)
        //{{AFX_DATA_INIT(MyExam07Dlg)
        //}}AFX_DATA_INIT
void MyExam07Dlg::DoDataExchange(CDataExchange* pDX)
        CAcUiDialog::DoDataExchange(pDX);
        //{{AFX_DATA_MAP(MyExam07Dlg)
        DDX_Control(pDX, IDC_COMBO_REGAPPS, m_ctrlRegAppComboBox);
        //}}AFX_DATA_MAP
BEGIN_MESSAGE_MAP(MyExam07Dlg, CAcUiDialog)
        //{{AFX_MSG_MAP(MyExam07Dlg)
        ON_CBN_KILLFOCUS(IDC_COMBO_REGAPPS, OnKillfocusComboRegapps)
        ON_EN_CHANGE(IDC_EDIT_XPT, OnChangeEditXpt)
        //}}AFX_MSG_MAP
END_MESSAGE_MAP()
// MyExam07Dlg message handlers
BOOL MyExam07Dlg::OnInitDialog()
//        FILE *fp;
//        if ((fp=fopen("y.lin","r"))==0) {
//                acutPrintf("找不到文件");
//                return;
        SetDialogName("exam07:MyExam07Dlg");
        CAcUiDialog::OnInitDialog();
        DLGCTLINFO dlgSizeInfo[]= {
                { IDC_STATIC_GROUP1, ELASTICX, 20 },
                { IDC_STATIC_GROUP1, ELASTICY, 100 },
                { IDC_EDIT_XPT,ELASTICX, 20 },
                { IDC_EDIT_YPT,ELASTICX, 20 },
                { IDC_COMBO_REGAPPS, MOVEY, 100 },
                { IDC_COMBO_REGAPPS, ELASTICX, 20 },
                { IDOK,MOVEX, 100 },
                { IDCANCEL, MOVEX, 100 },
        const DWORD numberofentries =
                sizeof dlgSizeInfo / sizeof DLGCTLINFO;
        SetControlProperty(dlgSizeInfo, numberofentries);
        SetWindowText("Forrest Linetype");
        DisplayRegApps();
        return TRUE;
void MyExam07Dlg::DisplayRegApps()
        AcDbRegAppTable *pRegAppTable;
        acdbHostApplicationServices()->workingDatabase()
                ->getSymbolTable(pRegAppTable, AcDb::kForRead);
        char *pName;
        AcDbRegAppTableIterator *pItr;
        if (pRegAppTable->newIterator(pItr) == Acad::eOk)
                while (!pItr->done())
                        AcDbRegAppTableRecord *pRecord;
                        if (pItr->getRecord(pRecord, AcDb::kForRead)
                                == Acad::eOk)
                                pRecord->getName(pName);
                                m_ctrlRegAppComboBox.InsertString(-1, pName);
                                pRecord->close();
                        pItr->step();
        pRegAppTable->close();
void MyExam07Dlg::OnKillfocusComboRegapps()
        CString strFromEdit;
        m_ctrlRegAppComboBox.GetWindowText(strFromEdit);
        if (m_ctrlRegAppComboBox.FindString(-1, strFromEdit) == CB_ERR)
                if (acdbRegApp(strFromEdit) == RTNORM)
                        m_ctrlRegAppComboBox.AddString(strFromEdit);
void MyExam07Dlg::OnOK()
        CAcUiDialog::OnOK();
void MyExam07Dlg::OnChangeEditXpt()
        // TODO: If this is a RICHEDIT control, the control will not
        // send this notification unless you override the CAcUiDialog::OnInitDialog()
        // function and call CRichEditCtrl().SetEventMask()
        // with the ENM_CHANGE flag ORed into the mask.
        // TODO: Add your control notification handler code here
 楼主| 发表于 2002-4-24 03:01:50 | 显示全部楼层
为什么会退出ARX时出现unhandled exception c0000005?
为什么会退出ARX时出现unhandled exception c0000005(Access violation reading 0Xcccccce8) at address 6bc418d8h)
The following is the code:
#include "stdafx.h"
#include "exam07.h"
#ifdef _DEBUG
#undef THIS_FILE
#endif
                // NOTE: the ClassWizard will add member initialization here
        //}}AFX_DATA_INIT
        DDX_Control(pDX, IDC_EDIT_YPT, m_ctrlYPtEdit);
        DDX_Control(pDX, IDC_EDIT_XPT, m_ctrlXPtEdit);
        //}}AFX_DATA_MAP
        //}}AFX_MSG_MAP
END_MESSAGE_MAP()
                { IDC_EDIT_ZPT,ELASTICX, 20 },
                { IDC_EDIT_ANGLE, ELASTICX, 20 },
                { IDC_STATIC_GROUP2, MOVEX, 20 },
                { IDC_STATIC_GROUP2, ELASTICY, 100 },
                { IDC_STATIC_GROUP2, ELASTICX, 80 },
                { IDC_LIST_BLOCKS, MOVEX, 20 },
                { IDC_LIST_BLOCKS, ELASTICY, 100 },
                { IDC_STATIC_TEXT2,MOVEX, 20 },
                { IDC_STATIC_TEXT2,MOVEY, 100 },
                { IDC_LIST_BLOCKS, ELASTICX, 80 },
                { IDC_STATIC_TEXT2,ELASTICX, 80 },
                { IDC_STATIC_GROUP3, MOVEY, 100 },
                { IDC_STATIC_GROUP3, ELASTICX, 20 },
                { IDC_STATIC_TEXT3,MOVEY, 100 },
                { IDC_STATIC_TEXT3,ELASTICX, 20 },
        m_ctrlXPtEdit.SetRange(-50.0, 50.0);
        m_ctrlYPtEdit.SetRange(-50.0, 50.0);
        SetWindowText("forrest Line");
        return TRUE;
 楼主| 发表于 2002-4-25 05:13:36 | 显示全部楼层
为什么编译dialog是有显示文本radius, 但是运行时却没有radius?
// Dialog
IDD_DIALOG1 DIALOG DISCARDABLE  0, 0, 189, 60
STYLE WS_POPUP | WS_CAPTION | WS_SYSMENU | WS_THICKFRAME
CAPTION "Dialog"
FONT 8, "MS Sans Serif"
BEGIN
    DEFPUSHBUTTON   "OK",IDOK,132,7,50,14
    EDITTEXT        IDC_EDIT_XPT,53,17,52,15,ES_AUTOHSCROLL
    EDITTEXT        IDC_EDIT_YPT,53,34,52,15,ES_AUTOHSCROLL
    PUSHBUTTON      "Cancel",IDCANCEL,132,24,50,14
    GROUPBOX        "Edit ",IDC_STATIC_GROUP1,7,7,104,46
    LTEXT           "radius",IDC_STATIC,18,19,25,8
    LTEXT           "offset",IDC_STATIC,17,36,25,8
END
// DESIGNINFO
#ifdef APSTUDIO_INVOKED
GUIDELINES DESIGNINFO DISCARDABLE
BEGIN
    IDD_DIALOG1, DIALOG
    BEGIN
        LEFTMARGIN, 7
        RIGHTMARGIN, 182
        TOPMARGIN, 7
        BOTTOMMARGIN, 53
    END
END
#endif    // APSTUDIO_INVOKED
#endif    // English (U.S.) resources
#ifndef APSTUDIO_INVOKED
// Generated from the TEXTINCLUDE 3 resource.
#define _AFX_NO_SPLITTER_RESOURCES
#define _AFX_NO_OLE_RESOURCES
#define _AFX_NO_TRACKER_RESOURCES
#define _AFX_NO_PROPERTY_RESOURCES
#if !defined(AFX_RESOURCE_DLL) || defined(AFX_TARG_CHS)
#ifdef _WIN32
LANGUAGE 4, 2
#pragma code_page(936)
#endif //_WIN32
#include "res\exam07.rc2"  // non-Microsoft Visual C++ edited resources
#include "l.chs\afxres.rc"          // Standard components
#endif
#endif    // not APSTUDIO_INVOKED
 楼主| 发表于 2002-4-26 04:31:26 | 显示全部楼层
为什么下面的代码不能显示半径为1, 间距为50?
void MyExam07Dlg::DisplayPoint()
{   FILE *fp;
    if ((fp=fopen("y.lin","w"))==0) {
             printf("cannot open file \n");
             return;
    acutPrintf("display. \n");
        while((m_str=getc(fp)) != EOF) {
      acutPrintf("%s,str.\n", m_str);
      if (m_str == '=')  m_strXPt=getc(fp);
      if (m_str == '-')  m_strYPt=getc(fp);
    acutPrintf("%s,radius", m_strXPt);
    acutPrintf("%s,offset", m_strYPt);
        m_ctrlXPtEdit.SetWindowText(m_strXPt);
        m_ctrlXPtEdit.Convert();
        m_ctrlYPtEdit.SetWindowText(m_strYPt);
        m_ctrlYPtEdit.Convert();
    fclose(fp);
y.lin如下:
A,0,[CIRC2,Y.shx,s=1],-50
 楼主| 发表于 2002-4-29 22:49:38 | 显示全部楼层
为什么半径是5而不是1, 间距是0而不是50?
Y.LIN IS AS FOLLOWED:
{   FILE *fp;
             return;
    //AfxMessageBox("m_str");
    acutPrintf("%c fir\n", getc(fp));
        while ((m_str=getc(fp)) != EOF) {
          //AfxMessageBox(m_str);  @ ? ?
      //acutPrintf("%c,str.\n", m_str);
      if (m_str = "=")  m_strXPt=getc(fp);
      if (m_str = "-")  m_strYPt=getc(fp);
    acutPrintf("%s radius\n", m_strXPt);
    acutPrintf("%s offset\n", m_strYPt);
    fclose(fp);
GMT+8, 2026-11-3 07:26 , Processed in 0.475100 second(s), 40 queries , Gzip On.
