查看: 1249|回复: 0
[原创]:真正的万能通用排序函数,对任何类型的表都有效
发表于 2005-6-15 00:07:27 | 显示全部楼层 |阅读模式
  1. ;;测试程序
  2. (defun c:test (/ coord tt)
  3.   (setq        coord
  4.          '(
  5.            (1 (1 . 2) 3 ("kkj" 4) (3 0))
  6.            (1 (1 . 4) 1 ("skj" 45) (2 3))
  7.            (1 (1 . 2) 3 ("Aej" 45) (7 1))
  8.            (1 (2 . 3) 2 ("ser" 4) (9 2))
  9.            (2 (6 . 2) 2 ("Serj" 9) (1 4))
  10.            (3 (3 . 5) 1 ("kkjsd" 35) (7 6))
  11.            (2 (4 . 7) 2 ("Akjdd" 3) (5 4))
  12.            (3 (3 . 3) 3 ("sekj" 446) (3 4))
  13.            (2 (2 . 2) 2 ("serj" 9) (1 4))
  14.            (1 (8 . 2) 2 ("wggj" 46) (2 4))
  15.            (1 (1 . 4) 1 ("kkj" 9) (4 4))
  16.            (3 (3 . 3) 3 ("sekj" 446) (3 4))
  17.            (1 (8 . 2) 2 ("wggj" 46) (2 4))
  18.           )
  19.   )
  20.
  21. ;;表第一项为要排序的依据,注意后面的括号没有,第二项即为后括号的个数,第三项为按升还是降排序
  22.   (setq        tt '(("(nth 0 (nth 3 " 2 ">")
  23.              ("(nth 0" 1 "<")
  24.              ("(car (nth 1 " 2 "<")
  25.              ("(nth 1 (nth 4 " 2 ">")
  26.              ("(nth 1 (nth 3" 2 ">")
  27.             )
  28.   )
  29.   (order coord tt)
  30. )
  1. ;;;主程序
  2. (defun order (coord_list tj / coord_ord        coord_I        i j k n        tj_ tj_c tj_1
  3.               tj_2)
  4.   (setq n (length coord_list))
  5.   (setq k (length tj))
  6.   (setq tj_ "(cond ((")
  7.   (setq tj_1 (nth 0 (nth 0 tj)))
  8.   (setq tj_2 tj_1)
  9.   (setq tj_1 (strcat tj_1 " p1"))
  10.   (setq tj_2 (strcat tj_2 " p2"))
  11.   (repeat (nth 1 (nth 0 tj))
  12.     (setq tj_1 (strcat tj_1 ")"))
  13.     (setq tj_2 (strcat tj_2 ")"))
  14.   )
  15.   (setq tj_ (strcat tj_ (nth 2 (nth 0 tj)) " " tj_1 tj_2 ") t) "))
  16.   (setq tj_c "((and ")
  17.   (setq i 1)
  18.   (repeat (- k 1)
  19.     (setq tj_c (strcat tj_c "(= " tj_1 " " tj_2 ")"))
  20.     (setq tj_1 (nth 0 (nth i tj)))
  21.     (setq tj_2 tj_1)
  22.     (setq tj_1 (strcat tj_1 " p1"))
  23.     (setq tj_2 (strcat tj_2 " p2"))
  24.     (repeat (nth 1 (nth i tj))
  25.       (setq tj_1 (strcat tj_1 ")"))
  26.       (setq tj_2 (strcat tj_2 ")"))
  27.     )
  28.     (setq tj_ (strcat tj_
  29.                       tj_c
  30.                       "("
  31.                       (nth 2 (nth i tj))
  32.                       " "
  33.                       tj_1
  34.                       tj_2
  35.                       ")) t) "
  36.               )
  37.     )
  38.     (setq i (1+ i))
  39.   )
  40.    (setq tj_ (strcat tj_ "(t nil))"))
  41.   (setq
  42.     coord_i
  43.      (vl-sort-i        coord_list
  44.                 (function (lambda (p1 p2)
  45.                             (eval (read tj_))
  46.                           )
  47.                 )
  48.      )
  49.   )
  50.   (setq j 0)
  51.   (repeat n
  52.     (setq
  53.       coord_ord        (append        coord_ord
  54.                         (list (nth (nth j coord_i) coord_list))
  55.                 )
  56.     )
  57.     (setq j (1+ j))
  58.   )
  59.   (setq coord_ord coord_ord)
  60. )
GMT+8, 2026-11-6 23:35 , Processed in 0.430247 second(s), 32 queries , Gzip On.
