查看: 1290|回复: 4
[求助] [求助]:这个程序为何无法实现
发表于 2003-3-17 20:35:03 | 显示全部楼层 |阅读模式
;查选中图块在图形中的数
;cks.lsp
(defun c:cks ()
  (setq a1 (entsel "\nselect a bolck:"))
  (setq a2 (car a1))
  (setq a3 (entget b2))
  (setq a4 (assoc 2 a3))
  (setq a5 (cdr a4))
  (setq a6 (ssget "x" (list a5)))
  (setq a7 (sslength a6))
  (princ a7)
  (princ)
看不出问题出在那里?请各位看看~~
提示错误:
命令: cks
select a bolck:
错误: 参数类型错误: lentityp nil
发表于 2003-3-17 22:26:13 | 显示全部楼层
(setq a6 (ssget "x" (list a5)))错了,改为
(setq a6 (ssget "x" (list '(0 . "INSERT")(cons 2 a5))))
发表于 2003-3-18 08:12:15 | 显示全部楼层
Re: [求助]:这个程序为何无法实现
最初由 snsj 发布
[B];查选中图块在图形中的数
;cks.lsp
(defun c:cks ()
  (setq a2 (car a1))
  (setq a5 (cdr a4))
  (setq a6 ... [/B]
其中(setq a3 (entget b2))也错了
应为(setq a3 (entget a2))
发表于 2003-3-18 10:13:42 | 显示全部楼层
经检测,这样是正确的。
(defun c:cks ()
(setq a2 (car a1))
(setq a6 (ssget "x" (list '(0 . "INSERT") a4)))
(princ a7)
(princ)
 楼主| 发表于 2003-3-18 11:51:06 | 显示全部楼层
谢谢各位
原来是对象类型未声明
改为:
;查选区内的块数
;cks.lsp
(defun c:cks ()
  (setq a2 (car a1))
  (setq a5 (cdr a4))
  (setq a6 (ssget (list '(0 . "INSERT")(cons 2 a5))))
  (princ "\n选区内的块")
  (princ a5)
  (princ "数目为:")
  (princ a7)
  (princ)
或者为:
;查选区内的块数
;cks.lsp
(defun c:cks ()
  (setq a2 (car a1))
  (setq a5 (cdr a4))
  (setq a6 (ssget (list '(0 . "INSERT") a4)))
  (princ "\n选区内的块")
  (princ a5)
  (princ "数目为:")
  (princ a7)
  (princ)
GMT+8, 2026-11-3 13:19 , Processed in 0.530193 second(s), 40 queries , Gzip On.
