查看: 728|回复: 3
[求助]:这样怎么画不了圆?
发表于 2005-6-22 16:04:18 | 显示全部楼层 |阅读模式
Private Sub Command2_Click()
Dim acadApp As Object
Dim acadDoc As Object
Dim moSpace As Object
Dim cen(2) As Double
Dim C As Object
Dim R As Double
cen(0) = 100: cen(1) = 200: cen(2) = 0
R = 300
On Error Resume Next
Set acadApp = GetObject(, "AutoCAD.Application")
If Err Then
Err.Clear
Set acadApp = CreateObject("AutoCAD.Application")
If Err Then End
End If
acadApp.Visible = True
Set acadDoc = acadApp.ActiveDocument
Set moSpace = acadDoc.ModelSpace
   '这就是圆心的坐标
   Set C = ThisDrawing.ModelSpace.AddCircle(cen, R) '在“当前文档”的“模型空间”里“画圆”
C.Color = acBlue
End Sub
这段程序能连接cad,但却画不了圆,那位能帮帮我,应该怎么修改阿?
已领礼包: 5217个
发表于 2005-6-22 16:46:47 | 显示全部楼层
可以画,最好在end sub前加ZoomAll
发表于 2005-6-22 19:12:05 | 显示全部楼层
Set C = acadDoc.ModelSpace.AddCircle(cen, R)
发表于 2005-7-15 14:19:48 | 显示全部楼层
在end sub前加ZoomAll ,而且要改为Set C = acadDoc.ModelSpace.AddCircle(cen, R)
GMT+8, 2026-11-3 11:12 , Processed in 0.503347 second(s), 38 queries , Gzip On.
