查看: 981|回复: 1
[求助] [求助]:autolisp画出的图形出错
发表于 2005-7-11 18:23:22 | 显示全部楼层 |阅读模式
我想要在一个大长方形上绘制一堆周期排列的小长方形,可是我的程序有时候可以work,有时却会画出不规则四边形。一个小小的程序每次执行会有不同的结果,怎么会有这种怪事!而且错误总是出现(command "pline" temp1 temp2 temp3 temp4 "c")这一行,我检查一下,给的坐标并没错,可是autoCAD就常常不按给定的坐标去画图,我快被搞疯了,给各位高手帮帮忙。
(defun C:test()
  (setvar "cmdecho" 0)
  (setq ss1 (ssget ":E"))
  (setq en1 (ssname ss1 0))
  (setq en1_data (entget en1))
  (setq pt1 (cdr (nth 14 en1_data)))
  (setq pt3 (cdr (nth 22 en1_data)))
  (setq y1 (cadr pt1) y3 (cadr pt3))
  (if (> y1 y3) (setq temp pt1 pt1 pt3 pt3 temp))
  (setq period 2000)
  (setq transmission 1000)
  (setq chip_length (abs (- (cadr pt3) (cadr pt1))))
  (setq period_num (fix (/ chip_length period)))
  (setq shift (/ (- chip_length (- (* period_num period) (- period transmission))) 2))
  (setq x1 (car pt1) x3 (car pt3))
  (setq y (+ (cadr pt1) shift) y1 (+ transmission (+ (cadr pt1) shift)))
  (setq temp1 (list x1 y) temp2 (list x3 y) temp3 (list x3 y1) temp4 (list x1 y1))
  (setq en2 (entlast))
  (command "array" en2 "" "r" period_num 1 period 0)
  (prin1)
发表于 2005-7-11 19:48:41 | 显示全部楼层
问题:
1. 画线时要取消捕捉(setvar "osmode" 0)
2. (command "array" en2 "" "r" p_num 1 period 0)阵列仅一列就不能再有间距0,应改为(command "array" en2 "" "r" p_num 1 period)
  1. [FONT=courier new](defun C:test ()
  2.   ;(cmdla0)
  3.   (setvar "osmode" 0)
  4.   (setq        ss1 (ssget)
  5.         i   -1
  6.   )
  7.   (while (setq en1 (ssname ss1 (setq i (1+ i))))
  8.     (setq en1_data (entget en1)
  9.           pt1           (cdr (nth 14 en1_data))
  10.           pt3           (cdr (nth 22 en1_data))
  11.           y1           (cadr pt1)
  12.           y3           (cadr pt3)
  13.     )
  14.     (if        (> y1 y3)
  15.       (setq temp pt1
  16.             pt1         pt3
  17.             pt3         temp
  18.       ))
  19.     (setq period 2000
  20.           tran         1000
  21.           c_len         (abs (- (cadr pt3) (cadr pt1)))
  22.           p_num         (fix (/ c_len period))
  23.           shift         (/ (- c_len (- (* p_num period) (- period tran))) 2)
  24.           x1         (car pt1)
  25.           x3         (car pt3)
  26.           y         (+ (cadr pt1) shift)
  27.           y1         (+ tran (+ (cadr pt1) shift))
  28.           temp1         (list x1 y)
  29.           temp2         (list x3 y)
  30.           temp3         (list x3 y1)
  31.           temp4         (list x1 y1)
  32.     )
  33.     (command "pline" temp1 temp2 temp3 temp4 "c")
  34.     (setq en2 (entlast))
  35.     (command "array" en2 "" "r" p_num 1 period)
  36.   )
  37.   ;(cmdla1)
  38.   (princ)
  39. )[/FONT]
GMT+8, 2026-11-6 10:16 , Processed in 0.402040 second(s), 34 queries , Gzip On.
