查看: 1016|回复: 3
[求助] [求助]:高手帮下忙,一个转换图层的工具,不知道怎么弄
发表于 2005-7-22 11:46:51 | 显示全部楼层 |阅读模式
内容如下
;; 覆盖tangent\tch\sys\下的同名文件即可。
;; liukai  2001.10.15
(defun c:- () (command "_.zoom" "0.8x") (princ))
(defun c:= () (command "_.zoom" "1.25x") (princ))
;; Change slected objects to current layer
(defun C:LK-LA-OBJ2CLAYER ( / oldvar e-sel)
  (setq oldvar (getvar "CMDECHO"))
  (while (setq e-sel (ssget))
    (setvar "CMDECHO" 0)
    (command "_.change" e-sel ""
             "_p"
             "_la" (getvar "CLAYER")
             "_c"  "BYLAYER"
             "_lt" "BYLAYER"
    (setvar "CMDECHO" oldvar)
  (princ)
);end defun C:LK-LA-OBJ2CLAYER
(defun C:5 ()
  (C:LK-LA-OBJ2CLAYER)
  (princ)
(defun c:4 ( / esl en el sLayer)
  (if (setq esl (entsel "\nPlease pick a object:"))
    (progn
      (setq en (car esl)
            el (entget en)
            sLayer (cdr (assoc 8 el))
      (setvar "CLAYER" sLayer)
      (princ (strcat "\nCurrent layer is : " sLayer))
  );end if
  (princ)
(defun C:LK-LA-PICKOFF ( / oldvar cla esel en el ela)
        cla (getvar "CLAYER")
  (while (setq esel (entsel))
    (setq en (car esel)
          el (entget en)
          ela (cdr (assoc 8 el))
    (if (/= ela cla)
      (progn
        (command "_.layer" "_off" ela "")
    );end if
  );end while
  (princ)
(defun C:6 ()
  (C:LK-LA-PICKOFF)
  (princ)
;; All layers turn on
(defun C:LK-LA-ALLON ( / oldvar)
  (command "_.layer" "_on" "*" "")
  (princ "\nAll layers on.")
  (princ)
);end defun C:LK-LA-ALLON
(defun c:7 ()
  (C:LK-LA-ALLON)
  (princ)
(defun c:qq ( / ss)
  (if (setq ss (ssget))
    (command "_.pedit" ss "_y" "_j" "_p" "" "")
  (princ)
(defun c:as (/ ss nCount oldvar en el elay)
    (progn
      (setq nCount (1- (sslength ss))
      (command "_.layer" "_off" "*" "_y" "")
      (while (>= nCount 0)
        (setq en (ssname ss nCount)
              el (entget en)
              elay (cdr (assoc 8 el))
        (command "_.layer" "_on" elay "")
        (setq nCount (1- nCount))
    );end progn
  );end if
  (princ)
(defun c:g (/ ss oldvar)
  (while (setq ss (ssget))
    (command "_.change" ss "" "_p" "_t" PAUSE "")
  (princ)
(defun _@ld (file)
  (if (and
        (not (member file _tchatoml))
        (load (strcat _prefix file))
    (setq _tchatoml (cons file _tchatoml))
  (princ)
(defun c:clean ()
  (setq _tchatoml nil)
(defun getpfx (/ str str1 i j n)
  (setq str (getvar "acadprefix")
        str1 (strcase str)
        n (strlen str)
        i 3
        j 1
  (while (and
           (/= "\\SYS1;" (substr str1 i 6))
           (> n i)
    (setq i (1+ i))
  (if (> n i)
    (setq _prefix1 (strcat (substr str 1 (+ i 4)) "\\")
          j (+ i 6)
          i (+ j 6)
    (setq i 6)
  (while (and
           (/= "\\SYS;" (substr str1 i 5))
           (> n i)
    (setq i (1+ i))
  (strcat (substr str j (- i j)) "\\")
(defun angtos1 (a)
  (angtos a (getvar "aunits") 9)
(defun redraw_le ()
  (foreach e le_drw
    (redraw e 4)
  (foreach e le_del
    (entdel e)
  (setq le_drw nil
        le_del nil
(defun *error* (msg)
  (redraw_le)
  (setvar "cmdecho" 0)
  (setvar "users1" ".")
  (slb_sld)
  (mkstr2)
(defun s::startup ()
  (if (not (menugroup "tch"))
    (command "menu" "tch.mnu")
  (princ "\n≡ TArch6 for R15 ≡")
  (princ)
(setq _prefix0 (getpfx)
      _prefix (strcat _prefix0 "LISP\\")
      _dim_auto T
      _is_v14 T
      _pi2 (/ pi 2)
(if (not _prefix1)
  (setq _prefix1 _prefix)
(_@ld "loadcfg")
(loadcfg)
(setq t_blip (nth 4 _cfgdata))
(setvar "blipmode" (if t_blip
                     0
                     1
(setvar "limcheck" 0)
找朋友传的个lisp程序
在天正3里加载很好,在天正6里边加载的话,每打开一个图形都要重新加载一次,有没有高手能够指点下,能不能让他在天正6里不需要每次都加载
发表于 2005-7-22 12:09:37 | 显示全部楼层
在acad.lsp中添加:
(load"程序文件名")
 楼主| 发表于 2005-7-22 14:47:02 | 显示全部楼层
我没有学过这些东西啊,斑竹帮忙下,加进去啊,然后复制进来,我直接粘贴,谢谢了,我的这个程序自身的名字就是 acad.lsp 啊
发表于 2005-7-23 15:46:45 | 显示全部楼层
看不懂
GMT+8, 2026-11-6 10:15 , Processed in 0.492447 second(s), 38 queries , Gzip On.
