查看: 1269|回复: 5
[LISP函数]:终于找到ukword函数,不敢独享
发表于 2005-8-4 11:19:53 | 显示全部楼层 |阅读模式
(defun ukword(bit kwd msg def / inp)
  (if (and def (/= def ""))
    (setq msg (strcat "\n" msg "<" def ">:")
          bit (* 2 (fix (/ bit 2)))
    (setq msg (strcat "\n" msg ": "))
  (initget bit kwd)
  (setq inp (getkword msg))
  (if inp inp def)
;;调用方法如下:
(defun c:xt001()
  (setq tt (ukword 1 "Yes No" "请选择(Yes/No):" tt))
发表于 2005-8-4 15:11:49 | 显示全部楼层
应该这样:
  1. [FONT=courier new]
  2. ;;调用方法如下:
  3. (defun c:test ()
  4.   (setq tt (ukword 1 "Y N" "请选择(Yes/No):" tt))
  5.   (cond        ((= tt "Y") (操作1))
  6.         ((= tt "N") (操作2))
  7.   )
  8. )
  9. (defun ukword (bit kwd msg def / inp)
  10.   (if (and def (/= def ""))
  11.     (setq msg (strcat "\n" msg "<" def ">:")
  12.           bit (* 2 (fix (/ bit 2)))
  13.     )
  14.     (setq msg (strcat "\n" msg ":"))
  15.   )
  16.   (initget bit kwd)
  17.   (setq inp (getkword msg))
  18.   (if inp
  19.     inp
  20.     def
  21.   )
  22. )
  23. [/FONT]
 楼主| 发表于 2005-8-4 16:06:24 | 显示全部楼层
        ((= tt "N") (操作2))
对,不加这个什么事也不干哈!
发表于 2005-8-4 20:16:51 | 显示全部楼层
弱弱问一句:这个函数用来做什么啊? 见笑了
已领礼包: 488个
发表于 2005-8-4 22:56:28 | 显示全部楼层
最初由 xyp1964 发布
[B]应该这样:
[CODE]
;;调用方法如下:
(defun c:test ()
        ((= tt "N") (操作2))
(defun ukword (... [/B]
这是为什么,如果是 (initget 1),不就成0了么?
 楼主| 发表于 2005-8-5 08:19:27 | 显示全部楼层
当bit为0时就可能接受null输入了!
GMT+8, 2026-11-6 12:18 , Processed in 0.413526 second(s), 42 queries , Gzip On.
