查看: 1276|回复: 2
[求助] [求助]:LISP中关于命令选择该怎么用?
发表于 2003-3-28 20:18:45 | 显示全部楼层 |阅读模式
(defun c:gz ()
(prompt "输入要修改高度的文字")
  (setq a1 (ssget  '((-4 . "<OR") (0 . "MTEXT") (0 . "TEXT") (-4 . "OR>"))))
  (if a1
    (progn
  (setq as (sslength a1))
  (setq a2 (getdist "\n输入新字高:"))
  (setq xz (getstring "\n输入文字对其方式:左下角对其<a>/右下角<任意键>"))
        (if  (= xz "a")
          (progn
  (command ".scaletext" a1 "" "BL" a2)
  (princ "\n选区内")
  (princ as)
  (princ "个文字被成功修改!!!")
  (princ)
  (princ "执行右下角对齐方式")
  (command ".scaletext" a1 "" "BR" a2)
  (princ "\n选区内")
  (princ as)
  (princ)
    (princ)
    (princ "\n没有文字被选择,请重新选择!!!")
    (princ)
  就像上边的程序我想当用户输入A的时候执行缩放点的左下角对其,当用户输入其他的时候执行右下角对其,这样的选择性命令函数,可是用IF好像别能实现:(,请各位高手指点!!!
发表于 2003-3-28 21:28:22 | 显示全部楼层
你这样试试:
  1. (defun c:gz ()
  2.   (prompt "输入要修改高度的文字")
  3.   (setq a1 (ssget '((0 . "text"))))
  4.   (if (/= a1 nil)
  5.     (progn
  6.       (setq as (sslength a1))
  7.       (setq a2 (getdist "\n输入新字高:"))
  8.       (setq
  9.         xz (getstring "\n输入文字对其方式:a为左下角对其/右下角<任意键>")
  10.       )
  11.       (if (= xz "a")
  12.         (progn
  13.           (command ".scaletext" a1 "" "BL" a2)
  14.           (princ "\n选区内")
  15.           (princ as)
  16.           (princ "个文字被成功修改!!!")
  17.           (princ)
  18.         )
  19.         (progn
  20.           (princ "执行右下角对齐方式")
  21.           (command ".scaletext" a1 "" "BR" a2)
  22.           (princ "\n选区内")
  23.           (princ as)
  24.           (princ "个文字被成功修改!!!")
  25.           (princ)
  26.         )
  27.       )
  28.     )
  29.     (princ "\n没有文字被选择,请重新选择!!!")
  30.   )
  31. )
 楼主| 发表于 2003-3-29 00:46:00 | 显示全部楼层
严重感谢雷锋同志火一般的热情~~~~
原来不把第二个(progn闭合影响了第三个progn:)
GMT+8, 2026-11-3 19:08 , Processed in 0.724337 second(s), 36 queries , Gzip On.
