查看: 1553|回复: 2
[LISP函数-Text]:获取text实体的实际外框
发表于 2005-9-1 12:25:34 | 显示全部楼层 |阅读模式
  1. (setq _pi2 (/ pi 2)
  2.       _pi4 (/ pi 4)
  3.       _2pi (* pi 2)
  4.       _3pi (* 1.5 pi)
  5. )
  6. (defun xd-ZeroSmallNum (num)
  7.   (setq num (rtos num 2 24))
  8.   (distof
  9.     (if        (or (wcmatch num "*e-*")
  10.             (wcmatch num "*E-*")
  11.         )
  12.       "0.0"
  13.       num
  14.     )
  15.   )
  16. )
  17. (defun xd-dxf (code el) (cdr (assoc code el)))
  18. ;; e = text dxf list
  19. (defun xd-GetTextBox (e / box ang pt p1)
  20.   (if (or (= (xd-dxf e 0) "TEXT")
  21.           (= (xd-dxf e 0) "ATTRIB")
  22.       )
  23.     (progn (setq box (textbox (entget e))
  24.                  ang (xd-dxf e 50)
  25.                  pt  (xd-dxf e 10)
  26.            )
  27.            (setq box
  28.                   (mapcar '(lambda (x)
  29.                              (mapcar '(lambda (y) (xd-ZEROSMALLNUM y)) x)
  30.                            )
  31.                           box
  32.                   )
  33.            )
  34.            (list pt
  35.                  (setq p1 (polar pt ang (car (last box))))
  36.                  (polar p1 (+ ang _pi2) (cadr (last box)))
  37.                  (polar pt (+ ang _pi2) (cadr (last box)))
  38.            )
  39.     )
  40.   )
  41. )
发表于 2005-9-1 23:30:31 | 显示全部楼层
肯定不对!
光看第一点:
pt  --> (ea:dxf e 10)
(textbox (entget e))  ;;得出的第一点不一定刚好 '(0 0)
所以后面(list pt ...肯定错.
应该:
textbox求出box
把box绕 '(0 0)转dxf50
再从'(0 0)移到dxf10.
发表于 2005-9-6 10:10:54 | 显示全部楼层
[php]
[/php]
应该是:
[php]
(defun xd-dxf (el code) (cdr (assoc code (entget el))))
[/php]
;; e = text dxf list也有误
应该是e为实体名
或者增加个判断
[php]  (defun dxf (ent i)
    (if        (= (type ent) 'ename)
      (setq ent (entget ent))
    ) ;_ 结束if
    (cdr (assoc i ent))
  ) ;_ 结束defun
[/php]
一般程序中已开始就会 (entget ent) ,没必要两次 entget    eachy
GMT+8, 2026-11-22 10:38 , Processed in 0.413214 second(s), 14 queries , Gzip On, File On.
