查看: 1805|回复: 2
[求助] [求助]:怎么把我的输出的X1 Y1 X2 Y2 x3 y3写到一个表中,再写入一个文件(问题我自己
发表于 2005-9-10 11:23:13 | 显示全部楼层 |阅读模式
;;;;(princ "\dmx,用于读取地面线(桩号&高程,用于绝对坐标系下).Writen by lyc in 08/09/2005.")
(defun c:dmx (/ pd zbx scx sxy pl ss n i st x2 y2 x1 y1 var st1 var1 x3 y3)
(princ "\n请选择地面线:")
(setq pl (ssget))
(setq pd 0)
(princ "\n请输入X方向绘图比例:(100)")
(setq scx (getreal))
(if (= scx nil) (setq scx 100))
(princ "\n请输入Y方向绘图比例:(100)")
(setq scy (getreal))
(if (= scy nil) (setq scy 100))
;;;;;;;判断是否是PL
(setq st1 (entget (ssname pl 0)))
(setq var1  (cdr (assoc 0 st1)) )
(if (= var1 "LWPOLYLINE")
(progn
(command "EXPLODE" pl "" )
(setq ss (ssget "p"))
(setq pd 1)
(setq ss pl)
;;;;读取数据
(setq n (sslength ss))
(setq i 0)
(princ "桩号   高程")
(while (< i n)
(setq st (entget (ssname ss i)))
(setq var  (cdr (assoc 0 st)) )
( if (= pd 1)
(progn
    (if (= var "LINE")
       (progn
;;;;;;输出
所    (if (= i 0)
         (progn
         (setq x1 (cadr (assoc 10 st)))
         (setq y1 (caddr (assoc 10 st)))
         (setq x2 (cadr (assoc 11 st)))
         (setq y2 (caddr (assoc 11 st)))
         (princ "\n")(princ (/ x1 scx) )(princ " ")(princ (/ y1 scy))(princ)
         (princ "\n")(princ (/ x2 scx) )(princ " ")(princ (/ y2 scy))(princ)
         (progn
         (setq x3 (cadr (assoc 11 st)))
         (setq y3 (caddr (assoc 11 st)))
          (princ "\n")(princ (/ x3 scx) )(princ " ")(princ (/ y3 scy))(princ)
(progn
    (if (= var "LINE")
       (progn
;;;;;;输出
所    (if (= i 0)
         (progn
         (setq x1 (cadr (assoc 11 st)))
         (setq y1 (caddr (assoc 11 st)))
         (setq x2 (cadr (assoc 10 st)))
         (setq y2 (caddr (assoc 10 st)))
         (progn
         (setq x3 (cadr (assoc 10 st)))
         (setq y3 (caddr (assoc 10 st)))
(setq i (+ i 1))
(princ "\n读取完毕!")
(princ)
;;;;;;END!
呵呵,为什么没有人理我,唉!研究了一下午,输出大概了解了
现在有一点想不懂
我的程序改成:
(defun c:dmx (/ pd zbx scx sxy pl ss n i st x2 y2 x1 y1 var st1 var1 x3 y3 lst1)
(princ "\n请选择地面线:")
(setq pl (ssget))
(setq pd 0)
;;;;;;;判断是否是PL
(progn
(setq pd 1)
(setq ss pl)
;;;;读取数据
(setq i 0)
(princ "桩号   高程")
(while (< i n)
( if (= pd 1)
(progn
    (if (= var "LINE")
       (progn
;;;;;;输出
所    (if (= i 0)
         (progn
         (progn
(progn
    (if (= var "LINE")
       (progn
;;;;;;输出
所    (if (= i 0)
         (progn
         (progn
         (setq  lst1 (strcat (itoa x3)   "  "  (itoa y3) ) )
         (princ lst1)
(setq i (+ i 1))
(princ "\n读取完毕!")
(princ)
;;;;;;END!
为什么会有 参数类型错误: fixnump:
如果把"(setq lst1 (strcat (itoa x3) " " (itoa y3) ) )
(princ lst1)"
换成"(princ "\n")(princ (/ x3 scx) )(princ " ")(princ (/ y3 scy))(princ)"
一切正常! 不明白
请赐教
原来是ITOA只返回整数,唉!
那有小数的数怎么返回字符串
已领礼包: 12493个
发表于 2005-9-10 22:43:08 | 显示全部楼层
浮点数用RTOS函数转换:(RTOS X 2 3)转换为保留3位小数的十进制字串。
输出到文件:
先用OPEN函数打开文件:(SETQ FP (OPEN "FILENAME" "w"))为写文件
                     :(SETQ FP (OPEN "FNANE.TXT" "r"))为读文件
用(PRINC XXX FP)写文件,(READ-LINE FP)为读文件一行。
在读写完文件后用(CLOSE FP)关闭文件。
发表于 2005-9-11 00:53:55 | 显示全部楼层
多看看autolisp的帮助文档,函数都在里面了
GMT+8, 2026-11-6 12:17 , Processed in 0.380617 second(s), 34 queries , Gzip On.
