查看: 1543|回复: 2
[VLISP函数]:自带字符串转换的sendkeys
发表于 2005-9-12 08:23:47 | 显示全部楼层 |阅读模式
  1. ;;自带特殊字符转换的sendkeys
  2. (defun XD_SENDKEYS (str / re n char ws)
  3.   (if (and str (= 'STR (type str)))
  4.     (progn
  5.       (setq re "")
  6.       (repeat (setq n (strlen str))
  7.         (setq char (substr str n 1)
  8.               n           (1- n)
  9.         )
  10.         (if
  11.           (member char
  12.                   '("+" "^" "%" "~" "(" ")" "{" "}" "[" "]" "\n" "\r")
  13.           )
  14.            (setq re (strcat "{" char "}" re))
  15.            (setq re (strcat char re))
  16.         )
  17.       )
  18.       (setq re (strcat re " "))
  19.       (setq ws (vlax-create-object "WScript.Shell"))
  20.       (vlax-invoke-method ws 'sendkeys re)
  21.       (vlax-release-object ws)
  22.     )
  23.   )
  24.   (princ)
  25. )
发表于 2005-9-12 22:02:44 | 显示全部楼层
{F3} {enter} 就得自己加了
发表于 2006-8-2 22:11:37 | 显示全部楼层
xp sp2  cad2005  测试没通过
(XD_SENDKEYS “F3”)——》3未知命令“3”。按 F1 查看帮助
GMT+8, 2026-11-22 10:28 , Processed in 0.354296 second(s), 14 queries , Gzip On, File On.
