查看: 1308|回复: 4
[试用]:在新贴的函数 加入 以前已经有的函数的 链接
已领礼包: 488个
发表于 2005-9-14 23:35:46 | 显示全部楼层 |阅读模式
已经贴过的函数,如果以后要用,在论坛里很难找
做了一个字典,转换一下,新贴中就会有链接.
  1. ;;;===========================================================================
  2. (defun c:xd( /  file file1 ext h1 h2 line get-url-fromtext string->Url)
  3. ;;;---------------------------------------
  4. (defun xd-string_parse (str delimiter / post strlst)
  5.   (if str
  6.     (progn
  7.       (setq strlst '())
  8.       (while (vl-string-search delimiter str)
  9.         (setq post (vl-string-search delimiter str))
  10.         (setq strlst (append strlst (list (substr str 1 post))))
  11.         (setq str (substr str (+ post 2)))
  12.       )
  13.       (vl-remove "" (append strlst (list str)))
  14.     )
  15.   )
  16. )
  17. ;;;--------------------------------------------------------------------------
  18. ;;;按字符拆分字符串,可以多个字符
  19. ;;;保留拆分字符
  20. ;;;(XD-STRING_PARSE1 "df,34:4sf ere 45" " ,:")->("df" "," "34" ":" "4sf" " " "ere" " " "45")
  21. ;;;----------------------------------------------
  22. (defun xd-string_parse1 (str chars / a new return)
  23.    (setq str(vl-string->list str)
  24.          chars(vl-string->list chars)
  25.    )
  26.    (while str
  27.      (setq a (car str) str(cdr str))
  28.      (if(member a chars)
  29.        (setq return(cons(list a)
  30.                           (cons(reverse new)return)
  31.                     )
  32.              new nil
  33.        )
  34.        (setq new(cons a new))
  35.      )
  36.     )
  37.    (if new(setq return(cons(reverse new)return)))
  38.    (mapcar ' vl-list->string (vl-remove 'nil(reverse return)))
  39. )
  40. ;;;--------------从"xd-url.txt"得到地址  $all-xd-url
  41. (defun get-url-fromtext( / h line)
  42.   (if(setq h(open (findfile "xd-url.txt") "r"))
  43.    (progn
  44.      (while(setq line(read-line h))
  45.            (setq line (xd-string_parse line " "))
  46.            (if(= 2(length line))
  47.              (setq $all-xd-url(cons(cons(strcase(car line))(cadr line))$all-xd-url))
  48.            )
  49.      )
  50.      (close h)
  51.    )
  52. ))
  53. ;;;---------------地址转换
  54. (defun string->Url(str / str1 x y)
  55.   (setq str1(xd-string_parse1 str " ()"\;"))
  56.   (apply 'strcat
  57.     (mapcar '(lambda(x)
  58.        (if(setq y(assoc (strcase x)$all-xd-url))
  59.          (strcat "[URL="(cdr y)"][U][COLOR=red]" x "[/COLOR][/U][/URL]")
  60.          x
  61.        ))
  62.      str1)
  63.   )
  64. )
  65. ;;;----------------main
  66.   (or $all-xd-url(get-url-fromtext))
  67.   (if (and $all-xd-url
  68.            (setq file(getfiled "选择一个要加入url的文件" "" "*" 8))
  69.            (if(setq ext( vl-filename-extension file))
  70.               (setq file1(strcat(substr file 1(-(strlen file)(strlen ext)))"-url"ext))
  71.               (setq file1(strcat file "-url"))
  72.             )
  73.            (setq h1(open file "r"))
  74.            (setq h2(open file1"w"))
  75.       )
  76.       (while(setq line(read-line h1))
  77.             (setq line(string->Url line))
  78.             (write-line line h2)
  79.       )
  80.   )
  81.   (if h2(progn(close h1)(close h2)(princ "...Done!"))
  82.         (princ "...Error")
  83.   )
  84.   (princ)
  85. )
  86. ;;;xd_GetObjectBoundingBox 后面只是示意一下
  87. ;;;xd-mktxt
其中string->Url一段有问题,因为有url标记
请下附件
命令xd
已领礼包: 488个
 楼主| 发表于 2005-9-14 23:37:22 | 显示全部楼层
下面是把上面的用本代码转换后的,看看效果:
  4. (defun [URL=http://www.xdcad.net/forum/showthread.php?s=&threadid=456505][U][COLOR=red]xd-string_parse[/COLOR][/U][/URL] (str delimiter / post strlst)
  5.   (if str
  6.     (progn
  12.       )
  14.     )
  15.   )
  16. )
  19. ;;;保留拆分字符
  20. ;;;([URL=http://www.xdcad.net/forum/showthread.php?s=&threadid=456505][U][COLOR=red]XD-STRING_PARSE1[/COLOR][/U][/URL] "df,34:4sf ere 45" " ,:")->("df" "," "34" ":" "4sf" " " "ere" " " "45")
  22. (defun [URL=http://www.xdcad.net/forum/showthread.php?s=&threadid=456505][U][COLOR=red]xd-string_parse1[/COLOR][/U][/URL] (str chars / a new return)
  25.    )
  26.    (while str
  31.                     )
  32.              new nil
  33.        )
  35.      )
  36.     )
  39. )
  42.   (if(setq h(open "xd-url.txt" "r"))
  43.    (progn
  45.            (setq line ([URL=http://www.xdcad.net/forum/showthread.php?s=&threadid=456505][U][COLOR=red]xd-string_parse[/COLOR][/U][/URL] line " "))
  48.            )
  49.      )
  50.      (close h)
  51.    )
  52. ))
  53. ;;;----------------main
  54.   (or $all-xd-url(get-url-fromtext))
  55.   (if (and $all-xd-url
  56.            (setq file(getfiled "选择一个要加入url的文件" "" "*" 8))
  57.            (if(setq ext( vl-filename-extension file))
  58.               (setq file1(strcat(substr file 1(-(strlen file)(strlen ext)))"-url"ext))
  59.               (setq file1(strcat file "-url"))
  60.             )
  61.            (setq h1(open file "r"))
  62.            (setq h2(open file1"w"))
  63.       )
  64.       (while(setq line(read-line h1))
  65.             (setq line(string->Url line))
  66.             (write-line line h2)
  67.       )
  68.   )
  69.   (if h2(progn(close h1)(close h2)(princ "...Done!"))
  70.         (princ "...Error")
  71.   )
  72.   (princ)
  73. )
  74. ;;;[URL=http://www.xdcad.net/forum/showthread.php?s=&threadid=458086][U][COLOR=red]xd_GetObjectBoundingBox[/COLOR][/U][/URL] 后面只是示意一下
  75. ;;;[URL=http://www.xdcad.net/forum/showthread.php?s=&threadid=456499][U][COLOR=red]xd-mktxt[/COLOR][/U][/URL]
已领礼包: 488个
 楼主| 发表于 2005-9-14 23:57:16 | 显示全部楼层
方法:
1.下字典,有空的朋友把所有链接都放里面,再贴出来.(不要改文件名,cad要找得到它)
2.把要贴的代码存成文件
3.cad里加载一楼的代码,命令xd,会自动生成 文件名-url.???的文件,
4. 把文件里的贴出来就会有象我一样的链接.
贴的时候用 code 比较好
下面为字典
有空的朋友,拜托把字典完善一下.
已领礼包: 488个
 楼主| 发表于 2005-9-15 00:02:01 | 显示全部楼层
字典示意:
因为没法贴,只能给个截图.
注释可以不要。
函数和地址以空格分割.不要加引号.
以后只要保持字典最新,就会有所有链接
发表于 2005-9-16 13:56:32 | 显示全部楼层
如果晓东改一下网页,把“函数链接词典”放在网上,贴帖子的时候,自动生成有链接的格式就更好了:)
GMT+8, 2026-11-3 10:38 , Processed in 0.482959 second(s), 41 queries , Gzip On.
