查看: 1197|回复: 5
[LISP程序]:请高手解释一下
发表于 2005-9-25 19:43:49 | 显示全部楼层 |阅读模式
小弟初学不久,搞不懂,请高手解释一下从(repeat....以下的程式是什么意思;另外,这个程式如果最后能将不同的图层改成不同的顏色就好了.
(defun c:disCir( / ss ent ents lay i r rs item zin)
  (setq zin (getvar "dimzin"))
  (setvar "dimzin" 0)
  (setvar "cmdecho" 0)
  (command "_.purge" "la" "*" "n")
  (setq ss (ssget "x" '((0 . "CIRCLE"))))
  (setq i 0)
  (setq lay 0)
  (repeat (sslength ss)
    (setq ent (ssname ss i))
    (setq ents (entget ent))
    (setq r (cdr (assoc 40 ents)))
    (if (assoc r rs)
      (progn
(setq item (reverse (assoc r rs)))
(setq item (reverse (cons (1+ (car item)) (cdr item))))
(setq rs (subst item (assoc r rs) rs))
      (progn
(setq rs (append rs (list (list r (strcat "mylayer_" (rtos lay 2 0)) 1))))
(command "_.layer" "m" (strcat "mylayer_" (rtos lay 2 0)) "")
(setq lay (1+ lay))
    (command "_.change" ent "" "p" "la" (cadr (assoc r rs)) "")
    (setq i (1+ i))
  (princ "\n图层\t\t直径\t\t孔数")
  (princ "\n------------------------------")
  (mapcar '(lambda(e) (princ (strcat "\n" (rtos (car e) 2 2) "\t" (cadr e) "\t" (rtos (last e) 2 0)))) rs)
  (setvar "dimzin" zin)
  (textscr)
  (princ)
----------------------在此多谢了----------------------
发表于 2005-9-25 20:35:57 | 显示全部楼层
修改如下:
  1. [FONT=courier new](defun c:test (/ ss i lay s1 es r lnm rs item)
  2.   (setvar "dimzin" 0)
  3.   (setvar "cmdecho" 0)
  4.   (command "_.purge" "la" "*" "n")
  5.   (setq        ss  (ssget "x" '((0 . "CIRCLE")))
  6.         i   -1
  7.         lay 0
  8.   )
  9.   (command "undo" "be")
  10.   (repeat (sslength ss)
  11.     (setq lay (1+ lay)
  12.           s1  (ssname ss (setq i (1+ i)))
  13.           es  (entget s1)
  14.           r   (cdr (assoc 40 es))
  15.           lnm (strcat "mylayer_" (rtos lay 2 0))
  16.     )
  17.     (if        (assoc r rs)
  18.       (progn
  19.         (setq item (reverse (assoc r rs))
  20.               item (reverse (cons (1+ (car item)) (cdr item)))
  21.               rs   (subst item (assoc r rs) rs)
  22.         )
  23.         (command "_.layer" "m" lnm "c" lay lnm "")
  24.       )
  25.       (progn
  26.         (setq rs
  27.                (append rs
  28.                        (list (list r lnm 1))
  29.                )
  30.         )
  31.         (command "_.layer" "m" lnm "c" lay lnm "")
  32.       )
  33.     )
  34.     (command "_.change" s1 "" "p" "la" (cadr (assoc r rs)) "c" lay "")
  35.   )
  36.   (command "undo" "e")
  37.   (princ "\n图层\t\t直径\t\t孔数")
  38.   (princ "\n------------------------------")
  39.   (mapcar '(lambda (e)
  40.              (princ (strcat "\n"
  41.                             (rtos (car e) 2 2)
  42.                             "\t"
  43.                             (cadr e)
  44.                             "\t"
  45.                             (rtos (last e) 2 0)
  46.                     )
  47.              )
  48.            )
  49.           rs
  50.   )
  51.   (textscr)
  52.   (princ)
  53. )[/FONT]
 楼主| 发表于 2005-9-25 21:52:35 | 显示全部楼层
楼上的朋友将同一层上的圆又改成不同的顏色了,能不能一个层只用一种顏色啊
发表于 2005-9-25 22:52:49 | 显示全部楼层
这样:
[php](defun c:test (/ ss i lay s1 es r lnm rs item)
  (setvar "dimzin" 0)
        i   -1
        lay 0
    (setq lay (1+ lay)
          es  (entget s1)
    (if        (assoc r rs)
      (progn
      (progn
        (setq rs
               (append rs
    ;(command "_.change" s1 "" "p" "la" (cadr (assoc r rs)) "c" lay "");;修改此处
    (command "_.change" s1 "" "p" "la" (cadr (assoc r rs)) "")
             (princ (strcat "\n"
                            (rtos (car e) 2 2)
                            "\t"
                            (cadr e)
                            "\t"
                            (rtos (last e) 2 0)
          rs
  (textscr)
  (princ)
)[/php]
 楼主| 发表于 2005-9-25 23:00:39 | 显示全部楼层
非常感谢楼上的朋友.
能否解释下面的是什么意思
    (setq lay (1+ lay)
      es  (entget s1)
    (if    (assoc r rs)
      (progn
      (progn
    (setq rs
           (append rs
发表于 2005-9-26 00:48:10 | 显示全部楼层
太深奥,一点都不懂。要再研究研究。
GMT+8, 2026-11-3 01:00 , Processed in 0.436964 second(s), 42 queries , Gzip On.
