查看: 739|回复: 2
[VBA程序]:输出一系列圆的半径和座标到EXCLE
发表于 2005-9-27 11:48:33 | 显示全部楼层 |阅读模式
我的CAD图中有很多圆,我想循环找出孔的特性,孔径、坐标,然后输出到EXCLE中,代码????????先谢谢了
发表于 2005-10-9 20:50:51 | 显示全部楼层
这个功能不难实现,把具体情况发到我信箱吧,最好附张图.gjilang01@163.com。
看了下面朋友的例子,改了一下,应该可以使用了.
Sub test()
  On Error Resume Next
  Dim ent As Object
  Dim m As Integer
  Dim xl As Excel.Application
  Dim xb As Excel.Workbook
  Dim xs As Excel.Worksheet
  Set xl = GetObject(, "excel.application")
  If Err Then
    Err.Clear
    Set xl = CreateObject("eccel.application")
    If Err Then
      MsgBox "excel isn't started"
      Exit Sub
    End If
   End If
  Set xb = xl.Workbooks.Add
  Set xs = xb.ActiveSheet
For Each ent In ThisDrawing.ModelSpace
If TypeOf ent Is AcadCircle Then
Dim r As Variant
Dim centpt As Variant
Dim cpt(0 To 2) As Double
r = ent.Radius
centpt = ent.Center
cpt(0) = centpt(0): cpt(1) = centpt(1)
End If
m = m + 1
  xl.Visible = True
  xs.Cells(1, 1) = ("半径")
  xs.Cells(1, 2) = ("X坐标")
  xs.Cells(1, 3) = ("Y坐标")
  xs.Cells(m + 1, 1) = r
  xs.Cells(m + 1, 2) = cpt(0)
  xs.Cells(m + 1, 3) = cpt(1)
  Next
End Sub
基本上能满足你所说的要求,如果有其它的需求,请说明!使用时,请先把引用excel库
 楼主| 发表于 2005-10-14 10:26:41 | 显示全部楼层
试一下,先谢谢了
GMT+8, 2026-11-3 19:13 , Processed in 0.707584 second(s), 36 queries , Gzip On.
