查看: 1383|回复: 3
[原创]:从块中提取出任一属性的任一组码的值
发表于 2003-4-10 09:49:09 | 显示全部楼层 |阅读模式
版主帮忙缩进一下。。。
(defun getatgpcodevalue
                        (blockentname                 atstr
                         gpcode             /                 gpcodevalue
                         atstr_             gpcodels         found
  (setq gpcodevalue nil)
  (setq found nil)
                                        ;本函数在块中提取出想要的属性所具有的组码的值。传入值为块图元名
  (while (and (/= (cdr (assoc 0 (entget blockentname))) "SEQEND")
              (= found nil)
         )                                ;和想要的属性字符串和组码数值。回传为与组码对应的值。
    (setq blockentname (entnext blockentname))
                                        ;注:传入的属性为字符串,字符串是区分大小写的;
    (setq gpcodels (entget blockentname))
                                        ;调用语法:(getatgpcodevalue blockentname atstr gpcode)
;如(getatgpcodevalue (car (entsel)) "PAGE"  1)
    (setq atstr_ (cdr (assoc 2 gpcodels)))
    (if        (= atstr_ atstr)
      (progn
        (setq gpcodevalue (cdr (assoc gpcode gpcodels)))
        (setq found t)
  gpcodevalue                                )                                        ;如果块中无想要的属性或组码则会返回nil。
发表于 2003-4-10 10:37:09 | 显示全部楼层
顺便问一下,提出该值后,用entmod进行修改该组码好象不能成功啊。有什么好的方法?
发表于 2003-4-11 09:03:56 | 显示全部楼层
  1. ;;修改BLOCK REF单一属性性质
  2. ;;USAGE: (CHANGE_ATT1 "比例" "LAYER" "DIM")
  3. ;;USAGE: (CHANGE_ATT1 <属性标籤> <性质> <值>)
  4. (defun CHANGE_ATT1 (TAG PROPERTY VALUE / BLK BLKREF ENT)
  5.   (vl-load-com)
  6.   (while
  7.     (or        (not (setq BLK (car (entsel "\n选取带属性图块: "))))
  8.         (progn
  9.           (setq BLKREF (vlax-ename->vla-object BLK))
  10.           (not (= (vla-get-objectname BLKREF) "AcDbBlockReference"))
  11.         )
  12.     )
  13.   )
  14.   (foreach ENT (vlax-safearray->list
  15.                  (vlax-variant-value (vla-getattributes BLKREF))
  16.                )
  17.     (if        (= (strcase (vla-get-tagstring ENT)) (strcase TAG))
  18.       ((eval (read (strcat "vla-put-" PROPERTY))) ENT VALUE)
  19.     )
  20.   )
  21.   (princ)
  22. )
  23. ;;提取BLOCK REF单一属性性质
  24. ;;USAGE: (GET_ATT1 "比例" "LAYER")
  25. ;;USAGE: (GET_ATT1 <属性标籤> <性质>)
  26. (defun GET_ATT1        (TAG PROPERTY / VALUE BLK BLKREF ENT)
  27.   (vl-load-com)
  28.   (while
  29.     (or        (not (setq BLK (car (entsel "\n选取带属性图块: "))))
  30.         (progn
  31.           (setq BLKREF (vlax-ename->vla-object BLK))
  32.           (not (= (vla-get-objectname BLKREF) "AcDbBlockReference"))
  33.         )
  34.     )
  35.   )
  36.   (foreach ENT (vlax-safearray->list
  37.                  (vlax-variant-value (vla-getattributes BLKREF))
  38.                )
  39.     (if        (= (strcase (vla-get-tagstring ENT)) (strcase TAG))
  40.       (setq VALUE ((eval (read (strcat "vla-get-" PROPERTY))) ENT))
  41.     )
  42.   )
  43.   VALUE
  44. )
 楼主| 发表于 2003-4-11 09:04:19 | 显示全部楼层
在用entmod函数时格式要注意。
调用语法为:(entmod elist)
其中elist是一张表,其格式为与用entget返回的一样,仅组码的值不同。你可以看一下autocad的帮助。
GMT+8, 2026-11-3 19:15 , Processed in 0.499455 second(s), 38 queries , Gzip On.
