查看: 1054|回复: 2
[讨论]:交叉选择时尽管物体在交叉框内,但不在当前窗口,就不能被选中,是有系统变量
发表于 2005-10-12 22:09:03 | 显示全部楼层 |阅读模式
交叉选择时尽管物体在交叉框内,但不在当前窗口,就不能被选中,是有系统变量控制吗?我编了一个程序共享,不知大家还有没有更好的主意!
(DEFUN GETTEXT (/ P1 P2 SS4 GR I A D N1 N2 N3 NT)
  (SETVAR "OSMODE" 0)
  (SETQ SS (SSADD))
  (SETQ SS4 (SSADD))
  (INITGET "P")
  (SETQ P1 (ENTSEL))
  (SETQ GR (GRREAD 2 4 2))
  (WHILE (/= (GETVAR "ERRNO") 52)
    (COND
      ((= P1 "P")
       (SETQ SS4 (SSGET "_P"))
      ((SETQ P1 (CADR GR))
       (SETQ P2 (GETCORNER P1))
       (SETQ A (ANGLE P1 P2)
      D (* 0.1 (DISTANCE P1 P2))
       (COMMAND "_ZOOM" (POLAR P1 A (* -1 D)) (POLAR P2 A D))
       (IF (< (CAR P1) (CAR P2))
  (SETQ SS4 (SSGET "_W" P1 P2 '((0 . "TEXT"))))
  (SETQ SS4 (SSGET "_C" P1 P2 '((0 . "TEXT"))))
    (SETQ N1 (SSLENGTH SS4))
    (SETQ N2 (SSLENGTH SS))
    (IF SS4
      (PROGN
(SETQ I 0)
(REPEAT (SSLENGTH SS4)
   (REDRAW (SSNAME SS4 I) 3)
   (SETQ SS (SSADD (SSNAME SS4 I) SS))
   (SETQ I (1+ I))
    (SETQ N3 (SSLENGTH SS))
    (SETQ N2 (- (+ N1 N2) N3))
    (IF (NOT NT)
      (IF (= P1 "P")
(IF SS4
   (SETQ NT (STRCAT "\n找到 " (ITOA N3) " 个"))
   (SETQ NT (STRCAT "\n没有上一个选择集。"))
(SETQ
   NT
    (STRCAT "\n选择对象: 指定对角点: 找到 "
     (ITOA N3)
     " 个"
      (PROGN
(IF (= N2 0)
   (SETQ NT (STRCAT ",总计 " (ITOA N3) " 个"))
   (SETQ NT
   (STRCAT " (" (ITOA N2) " 个重复),总计 " (ITOA N3) " 个")
(IF (= P1 "P")
   (SETQ NT (STRCAT "\n找到 " (ITOA N1) " 个" NT))
   (SETQ NT (STRCAT "\n选择对象: 指定对角点: 找到 "
      (ITOA N1)
      " 个"
      NT
    (PRINC NT)
    (INITGET "P")
    (SETQ P1 (ENTSEL))
  (SETQ I 0)
  (REPEAT N3
    (REDRAW (SSNAME SS I) 4)
    (SETQ I (1+ I))
已领礼包: 593个
发表于 2005-10-15 09:43:13 | 显示全部楼层
没办法,这是规则,先判断 Points  都在当前视口
发表于 2005-10-15 21:09:48 | 显示全部楼层
先zoom all   或 zoom obj
或者按选中物体的最大包围框
GMT+8, 2026-11-2 22:15 , Processed in 0.462513 second(s), 36 queries , Gzip On.
