查看: 1013|回复: 3
[分享]:用于建筑施工图中清点门窗个数,能力有限请各位大侠多请意见!
发表于 2003-4-13 14:13:39 | 显示全部楼层 |阅读模式
(defun c:ccm (/                ccm_ob          ccm_len   ccm_ct    ccm_l1
              ccm_ct1        ccm_en          ccm_tn1   ccm_l2    ccm_ctt
              ccm_tn1        ccm_en1          ccm_tn    ccm_th    ccm_ts
              ccm_name        ccm_no
  (while
    (not
      (setq ccm_ob                        ;on--"object name"
             (ssget (list '(0 . "text")))
     (princ "\nselect again:")
  (setq        ccm_len         (sslength ccm_ob)
        ccm_ct         0
        ccm_sure (getstring "\n print? Y/N:<Y>")
        ccm_l1         '()
  (if (or (= ccm_sure "y") (= ccm_sure "Y") (= ccm_sure ""))
    (setq tlp (getpoint "\n top/left point please:"))
  (ccm_var_0)
  (cubegin)
  (cbl_var_0)
  (while (< ccm_ct ccm_len)
    (setq ccm_en  (entget (ssname ccm_ob ccm_ct))
          ccm_tn1 (cdr (assoc 1 ccm_en))
    (if        (= nil (member ccm_tn1 ccm_l1))
      (setq ccm_l1 (cons ccm_tn1 ccm_l1))
    (setq ccm_ct (1+ ccm_ct))
  (setq ccm_l1 (acad_strlsort ccm_l1))
  (while
    (setq ccm_l2  '()
          ccm_ctt 0
          ccm_tn1 (car ccm_l1)
     (while (< ccm_ctt ccm_len)
       (setq ccm_en1 (entget (ssname ccm_ob ccm_ctt))
             ccm_tn  (cdr (assoc 1 ccm_en1))
             ccm_th  (cdr (assoc 40 ccm_en1))
             ccm_ts  (cdr (assoc 7 ccm_en1))
       (setvar "textsize" ccm_th)
       (setvar "textstyle" ccm_ts)
       (if (= ccm_tn ccm_tn1)
         (progn        (setq ccm_l2 (cons ccm_tn ccm_l2))
                (setq ccm_ctt (1+ ccm_ctt))
     (progn (setq ccm_no (itoa (length ccm_l2)))
            (princ ccm_tn1)
            (princ "   ")
            (princ ccm_no)
            (princ "    \n")
              (progn
                (setq
                  tlp  (list (car tlp) (- (cadr tlp) (* 2.5 ccm_th)))
                  tlp1 (list (+ (car tlp) (* 15 ccm_th)) (cadr tlp))
                (command "text" tlp "" "" ccm_tn1)
                (command "text" tlp1 "" "" ccm_no)
     (setq ccm_l1 (cdr ccm_l1))
  (cuend)
  (cbl_var_1)
  (ccm_var_1)
  (princ)
发表于 2003-4-15 09:12:24 | 显示全部楼层
1。以字为实体选择,可以加上图层过滤。
2。最后结果要排序统计。
3。内部函数未贴出。
 楼主| 发表于 2003-4-15 11:37:52 | 显示全部楼层
哦!忘了!
谢谢指教,你所说的排序具体指什么?
再看看这个统计天正自动生成门窗个数的小程序:
(defun c:cm (/              cm_ob    cm_len        cm_ct         cm_l1          cm_ct1
             cm_en    cm_tn1   cm_l2        cm_ctt         cm_tn1          cm_en1
             cm_tn    cm_th    cm_ts        cm_name         cm_no
  (while
    (not
      (setq cm_ob                        ;on--"object name"
             (ssget (list '(0 . "insert") '(66 . 1)))
  (setq        cm_len        (sslength cm_ob)
        cm_ct        0
        cm_l1        '()
  (ccm_var_0)
  (cbl_var_0)
  (cubegin)
  (while (< cm_ct cm_len)
    (setq cm_en         (entget (entnext (ssname cm_ob cm_ct)))
          cm_tn1 (cdr (assoc 1 cm_en))
    (if        (= nil (member cm_tn1 cm_l1))
      (setq cm_l1 (cons cm_tn1 cm_l1))
    (setq cm_ct (1+ cm_ct))
  (setq cm_l1 (acad_strlsort cm_l1))
  ;;(if (null cm_thh)
                                        ; ; (setq cm_thh_temp cm_th))
  (if (or (= cm_sure "y") (= cm_sure "Y") (= cm_sure ""))
    (setq tlp (getpoint "\n pick point:"))
  (while
    (setq cm_l2         '()
          cm_ctt 0
          cm_tn1 (car cm_l1)
     (while (< cm_ctt cm_len)
       (setq cm_en1 (entget (entnext (ssname cm_ob cm_ctt)))
             cm_tn  (cdr (assoc 1 cm_en1))
             cm_th  (cdr (assoc 40 cm_en1))
             cm_ts  (cdr (assoc 7 cm_en1))
       (if (= cm_tn cm_tn1)
         (progn        (setq cm_l2 (cons cm_tn cm_l2))
                (setq cm_ctt (1+ cm_ctt))
     (progn (setq cm_no (itoa (length cm_l2)))
            (princ cm_tn1)
            (princ "   ")
            (princ cm_no)
            (princ "    \n")
              (progn (setq tlp        (list (car tlp) (- (cadr tlp) (* 2 cm_th)))
                           tlp1        (list (+ (car tlp) (* 24 cm_th)) (cadr tlp))
                     (setvar "textsize" cm_th)
                     (setvar "textstyle" cm_ts)
                     (command "text" "j" "tl" tlp cm_th "" cm_tn1)
                     (command "text" "j" "tl" tlp1 cm_th "" cm_no)
     (setq cm_l1 (cdr cm_l1))
  (cuend)
  (cbl_var_1)
  (ccm_var_1)
  (princ)
(defun cubegin ()
  (command "undo" "begin")
(defun cuend ()
  (command "undo" "end")
(defun cos_var_0 ()
  (setq os (getvar "osmode"))
  (setvar "osmode" 0)
(defun cos_var_1 ()
  (setvar "osmode" os)
(defun cbl_var_0 ()
  (setq bl (getvar "blipmode"))
  (setvar "blipmode" 0)
(defun cbl_var_1 ()
  (setvar "blipmode" bl)
(defun cla_get ()
  (setq cla (getvar "clayer"))
(defun cla_set ()
  (setvar "clayer" cla)
(defun ccm_var_0 ()
  (setq cm (getvar "cmdecho"))
  (setvar "cmdecho" 0)
(defun ccm_var_1 ()
  (setvar "cmdecho" cm)
已领礼包: 488个
发表于 2003-4-19 17:59:40 | 显示全部楼层
学一下理正的方法.很符合画图的习惯.(当然也有不足)
天正用的是属性.用text不好.
你写的好象没画格子线,所有楼层要统计一下.
GMT+8, 2026-11-3 17:03 , Processed in 0.661171 second(s), 38 queries , Gzip On.
