查看: 1079|回复: 4
[原创]:公路线园对象源代码
发表于 2005-11-2 21:53:28 | 显示全部楼层 |阅读模式
class atomLine
public:
        int kind;
        double xb,yb,xe,ye,length;
        virtual point(double len,double &x,double &y,double &angle)=0;
        virtual void dump()=0;
        atomLine(double xb,double yb,double xe,double ye,double length){
                this->xb=xb;
                this->yb=yb;
                this->xe=xe;
                this->ye=ye;
                this->length=length;
class Line:public atomLine
public:
        double ang;
        point (double len,double &x,double &y,double &angle);
        Line(double xb,double yb,double xe,double ye,double length):atomLine(xb,yb,xe,ye,length){
                if (xe==xb)
                        ang=ye>yb?PI/2:-PI/2;
                else
                        ang=atan2(ye-yb,xe-xb);
        void dump(){ printf("Line---xb:%lf--yb:%lf--xe:%lf--ye:%lf--length::%lf\n",xb,yb,xe,ye,length);}
class Circle:public atomLine
public:
        double xc,yc,R,RS;
        point(double len,double &x,double &y,double &angle);
        void dump(){ printf("Circle---xb:%lf--yb:%lf--xe:%lf--ye:%lf--length::%lf\n",xb,yb,xe,ye,length);
                        printf("      ---xc:%lf--yc:%lf--R:%lf--RS:%lf\n",xc,yc,R,RS);}
        Circle(double xb,double yb,double xe,double ye,double length,
                    double xc,double yc,double R,double RS):atomLine(xb,yb,xe,ye,length){
                this->xc=xc;
                this->yc=yc;
                this->R=R;
                this->RS=RS;
class spiral :public atomLine
public:
        double xc,yc,Rb,aza,A,RS;
        void dump(){ printf("spiral---length:%lf--xc:%lf--yc:%lf\n",length,xc,yc);
                        printf("      ---A:%lf--Rb:%lf--aza:%lf\n",A,Rb,aza);}
        spiral(double length,double xc,double yc,
                double Rb,double RS,double aza,double A):atomLine(0,0,0,0,length){
                this->xc=xc;
                this->yc=yc;
                this->Rb=Rb;
                this->aza=aza;
                this->A=A;
                this->RS=RS;
Line::point (double len,double &x,double &y,double &angle)
        double        temp=sqrt( (xe-xb)*(xe-xb)+(ye-yb)*(ye-yb) );
        x=len*(xe-xb)/temp+xb;
        y=len*(ye-yb)/temp+yb;
        angle=ang;
        return TRUE;
Circle::point(double len,double &x,double &y,double &angle)
        double alpha=len*(-RS)/R;
        double x1,y1,x11,y11;
        x1=xb-xc;
        y1=yb-yc;
        y11=y1*cos(alpha)-x1*sin(alpha);
        x11=y1*sin(alpha)+x1*cos(alpha);
        x=x11+xc;
        y=y11+yc;
        x1=x-xc;
        y1=y-yc;
        if (x1==0)
                angle=y1>0?PI/2:-PI/2;
        else
                angle=atan2(y1,x1);
        if (RS>0)
                angle+=PI/2;
        else
                angle-=PI/2;
        return TRUE;
spiral::point(double len,double &x,double &y,double &angle)
        if (A<=0.01)
                return FALSE;
        double len2;
        if (Rb==0) //indicate MAXRADIUS
                len2=0;
        else
                len2=A*A/Rb;
        len2=fabs(len+len2);
        double R;
        if (len2==0)
                angle=0;
        else
                R=A*A/len2;
                angle=len2/R/2;
        double x1,y1,x2,y2,t1,t2;
        if (len2==0){
                x1=0;
                y1=0;
        else {
                x1=lbgX(A,len2);
                y1=lbgY(A,len2);
        double ls1;
        if (Rb>=0) //Rb is big radius include 0 (Line)
                ls1=1;
        else
                ls1=-1;
        if (ls1*RS<0)
                y1=-y1;
        if (ls1>0&&RS>0) //big and right
                angle=aza+angle;
        else if (ls1<0&&RS>0) //small and right
                angle=aza-angle+PI;
        else if (ls1>0&&RS<0) //big and left
                angle=aza-angle;
        else if (ls1<0&&RS<0)
                angle=aza+angle+PI;
        t1=cos(aza);
        t2=sin(aza);
        x2=x1*t1-y1*t2;
        y2=y1*t1+x1*t2;
        x=xc+x2;
        y=yc+y2;
        return TRUE;
double funx(double l,double A)//A!=0
        double t=l*l/2/A/A;
        return cos(t);
double funy(double l,double A)
        double t=l*l/2/A/A;
        return sin(t);
double lbgX(double A,double b)
        double h=b-0;//a=0
        double T[MAX_STEPS],m1,m2;
        T[0]=h*(funx(0,A)+funx(b,A))/2;
        int k=1,i,j;
        do {
                m1=T[0];
                T[0]=T[0]/2;
                for (i=0;i<pow(2,k-1);i++)
                        T[0]+=h*funx( (2*i+1)*h/2,A )/2;
                h/=2;
                for (j=1;j<=k;j++)
                        m2=T[j];
                        T[j]=( pow(4,j)/( pow(4,j)-1 ) )*T[j-1]-m1/(pow(4,j)-1);
                        m1=m2;
                if (fabs(T[k]-T[k-1])<EEE)
                        return T[k];
                k++;
        }        while (k<MAX_STEPS);
        return T[k-1];
double lbgY(double A,double b)
        double h=b-0;//a=0
        T[0]=h*(funy(0,A)+funy(b,A))/2;
        int k=1,i,j;
        do {
                m1=T[0];
                T[0]=T[0]/2;
                        T[0]+=h*funy( (2*i+1)*h/2,A )/2;
                h/=2;
                for (j=1;j<=k;j++)
                        m2=T[j];
                        m1=m2;
                        return T[k];
                k++;
        return T[k-1];
已领礼包: 3532个
发表于 2005-11-2 22:15:27 | 显示全部楼层
全是代码!头痛!给点相应的说明吧!
 楼主| 发表于 2005-11-3 08:40:36 | 显示全部楼层
公路上路线由三种线型组成:直线,圆弧,缓和曲线.atomline为他们的基类.直线创建:Line(double xb,double yb,double xe,double ye,double length)给出起点坐标,止点坐标,长度,圆弧创建:Circle(double xb,double yb,double xe,double ye,double length,
double xc,double yc,double R,double RS)给出起点坐标,止点坐标,长度,圆心坐标,半径,左偏右偏.缓和曲线创建:spiral(double length,double xc,double yc,
double Rb,double RS,double aza,double A)给出长度,止点处的圆心坐标,Rb:起点半径,左偏右偏,止点方位角,A值.point(...)函数为计算每个线园给定长度的坐标
发表于 2005-11-3 09:27:04 | 显示全部楼层
C++的代码发到VB版干什么?
发表于 2005-11-29 22:41:12 | 显示全部楼层
简单就是美,提倡节约!注意色彩丰富一些,表现出来就好了!
GMT+8, 2026-11-3 17:38 , Processed in 0.457648 second(s), 40 queries , Gzip On.
