查看: 901|回复: 4
[LISP程序]:一段简单的DCL,提示说参数太多
发表于 2005-11-8 13:47:32 | 显示全部楼层 |阅读模式
;;1;LSP
(defun c:nnd ( )
(setq dcl_id (load_dialog "nnd.dcl"))
(if (not (new_dialog "nnd1" dcl_id))
(exit)
(action_tile "1" "(setq a "WL")")
(action_tile "2" "(setq a "WE")")
(if (= 1 (start_dialog))
(progn
(while
(setq po (getpoint "\n**点:"))
(command "text" po  ""  ""  (strcat  a))
(unload_dialog dcl_id)
(print)
;;;;;;;2-- DCL
//编写DCL程序//
nnd1 : dialog {
label = "对话框";
:button {label = "WL"; key = "1";}
:button {label = "WE"; key = "2";}
ok_cancel;
学写的,麻烦哪位看看怎么修改.
谢谢
发表于 2005-11-8 17:46:23 | 显示全部楼层
;;nnd(奶奶的).lsp程序修改如下
;;1;LSP
(defun c:nnd ()
    (exit)
  (setq        wl "WL"
        we "WE"
  (action_tile "1" "(setq a  WL)")
  (action_tile "2" "(setq a WE)")
    (progn
      (while
  (print)
 楼主| 发表于 2005-11-9 09:41:51 | 显示全部楼层
ha 谢谢了;
好用还有个过分想法;
想改这样:
(action_tile "1" "(setq a "1al-1")")
(action_tile "2" "(setq a "建施-1")")
怎么办啊
发表于 2005-11-9 10:36:50 | 显示全部楼层
这个简单么,你先看看上边两个程序的区别:
;;1;LSP
(defun c:nnd ()
    (exit)
  (setq        wl "1al-1"
        we "建施-1"
    (progn
      (while
  (print)
;;大致改了一下
 楼主| 发表于 2005-11-10 08:55:12 | 显示全部楼层
这个问题IC
再次感谢---shuiwuhen.
GMT+8, 2026-11-6 16:46 , Processed in 0.491448 second(s), 40 queries , Gzip On.
