查看: 1073|回复: 3
[求助] [求助]:对话框信息不能显示
发表于 2005-11-9 12:20:32 | 显示全部楼层 |阅读模式
程序如下(已简化),运行到(setq str2 (strcat "线长 = " (itoa pnx)))
时在命令行提示:参数类型错误: fixnump: 257.1.其中257.1是线长pnx的值,这一行我是照着书上抄的啊,怎么会有错误呢?烦请告知原因.
(defun c:pm(/ )
        (setq n 0)
        (setq p0 (getpoint "\n请确定剖面线起点:"))
        (setq pn (getpoint "\n请确定剖面线终点:"))
        (while (<= n 3)
               (setq p1 (getpoint "\n请确定下一点:")
                     pnx (car p1)
                     n (+ n 1)
       (setq str1  (strcat "*****剖面参数*****"))
       (alert (strcat str1 "\n"str2 ))
   (prin1)
发表于 2005-11-9 13:00:27 | 显示全部楼层
itoa后面跟整数做参数
实数用rtos
发表于 2005-11-9 13:06:38 | 显示全部楼层
Returns the conversion of an integer into a string
(itoa int)
Arguments
int
An integer.
Return Values
A string derived from int.
 楼主| 发表于 2005-11-9 15:02:49 | 显示全部楼层
谢谢二楼的,按你说的办,问题已解决!
三楼说的我就不明白了,因是E文,越看越糊涂.
GMT+8, 2026-11-6 16:45 , Processed in 0.413023 second(s), 38 queries , Gzip On.
