查看: 1867|回复: 9
[建议]:我也改了一个显示钢筋面积的LISP,
发表于 2005-11-29 00:16:09 | 显示全部楼层 |阅读模式
我也改了一个显示钢筋面积的LISP,请LISP高手改进一下
就是%%1308@200(2)显示不了;不知是什么原因
(DEFUN C:DISAPPEARBAR ()
(SETQ SS (SSGET "X" '((0 . "TEXT")))
       I 0)
(REPEAT (SSLENGTH SS)
  (SETQ ENT (ENTGET (SSNAME SS I))
        STR (CDR (ASSOC 1 ENT))
        SL (STRLEN STR)
        J 1 I (1+ I))
  (IF (AND (NOT (WCMATCH STR "*/*")) (WCMATCH STR "*!*")) (PROGN
   (WHILE (AND (< J SL) (/= (SUBSTR STR J 1) "(")) (SETQ J (1+ J)))
   (IF (< J SL) (PROGN
    (SETQ ENT (SUBST (CONS 1 (SUBSTR STR 1 (1- J))) (CONS 1 STR) ENT))
    (ENTMOD ENT)
(PRINC)
(DEFUN C:SHOWBAR ()
       I 0)
        SL (STRLEN STR)
        J 1 S3 0 I (1+ I))
   (WHILE (< J SL)
    (SETQ S1 "" S2 "")
    (WHILE (AND (>= (SETQ ST (SUBSTR STR J 1)) "0") (<= ST "9"))
     (SETQ S1 (STRCAT S1 ST) J (1+ J))
    (SETQ J (+ J 1))
     (SETQ S2 (STRCAT S2 ST) J (1+ J))
    (SETQ S3 (+ (FIX (* (ATOI S1) PI (ATOI S2) (ATOI S2) 0.25)) S3))
    (SETQ J (1+ J))
   (SETQ ENT (SUBST (CONS 1 (STRCAT STR "(" (ITOA (FIX S3)) "mm2)")) (CONS 1 STR) ENT))
   (ENTMOD ENT)
(PRINC)
(defun C:vb(/ myerr dxf toang fx add_solid add_text dis olderr oldos oldfill ss pd gr pt ent entold)
  (defun myerr(msg)
    (setq *error* olderr)
    (command "_.undo" "_b")
    (princ)
  (defun dxf(ent i)
    (if (= (type ent) 'ename)
      (setq ent (entget ent))
    (cdr (assoc i ent))
  (defun toang(ang i)
    (if (= i 1)
      (* ang (/ 180 pi))
      (* ang (/ pi 180))
  (defun fx(ang)
    (cond
      ((>= (/ pi 2) ang 0) (list pi (+ pi (/ pi 2)) 1))
      ((>= pi ang (/ pi 2)) (list 0 (+ pi (/ pi 2)) 1))
      ((>= (+ pi (/ pi 2)) ang pi) (list 0 (/ pi 2) 0))
      ((>= (* 2 pi) ang (+ pi (/ pi 2))) (list pi (/ pi 2) 0))
  (defun add_solid(p1 p2 p3 p4)
    (entmakex (list (cons 0 "SOLID") (cons 100 "AcDbEntity") (cons 62 250) (cons 100 "AcDbTrace")
                    (cons 10 p1) (cons 11 p2) (cons 12 p3) (cons 13 p4)
  (defun add_text(pt h ang txt style jus)
    (entmakex (list (cons 0 "TEXT") (cons 100 "AcDbEntity") (cons 62 2) (cons 100 "AcDbText") (if (= jus 0) (cons 10 pt) (list 10 0.0 0.0 0.0)) (cons 40 h)
                    (cons 1 txt) (cons 50 ang) (cons 7 style) (cons 72 (cond ((= jus 0) 0) ((= jus 1) 1) ((= jus 2) 1) ((= jus 3) 2))) (if (= jus 0)
                    (list 11 0.0 0.0 0.0) (cons 11 pt)) (cons 100 "AcDbText") (cons 73 (cond ((= jus 0) 0) ((= jus 1) 2) ((= jus 2) 3) ((= jus 3) 2)))
  (defun dis (ent / obj laynm name st1 st2 st3 lst h ang n)
    (setq obj (vlax-ename->vla-object ent))
    (setq laynm (strcat "图层:" (dxf ent 8)) name (dxf ent 1))
    ;;;;;;首先取得文字容
    ;(setq tc_txt (vla-get-textstring obj))
  (cond
      ((wcmatch (STRCASE (dxf ent 1)) "#`%`%13[0-4]##,##`%`%13[0-4]##,##`%`%13[0-4]##")
        (progn
          ;(setq tc_mj (tc_tctc1 name))
        (setq lst (list "====纵筋面积====" laynm
                        ;(strcat "钢筋标注:" (vla-get-textstring obj))
                        (strcat "钢筋面积:" (rtos (/ (tc_tctc1 (vla-get-textstring obj)) 100) 2 3)) "cm^2"
                         ;(strcat "钢筋面积:" (rtos (vla-get-ScaleFactor obj) 2 1))
      ((wcmatch (STRCASE (dxf ent 1)) "#`%`%13[0-4]##/#`%`%13[0-4]##,#`%`%13[0-4]##/##`%`%13[0-4]##,##`%`%13[0-4]##/#`%`%13[0-4]##;##`%`%13[0-4]##/##`%`%13[0-4]##")
        (progn
                        (strcat "钢筋面积:" (rtos (/ (tc_tctc2 (vla-get-textstring obj)) 100) 2 3)) "cm^2"
      ((wcmatch (STRCASE (dxf ent 1)) "`%`%13*[50-250]")
        (progn
        (setq lst (list "====板筋面积====" laynm
                        (strcat "钢筋面积:" (rtos (tc_tctc3 (vla-get-textstring obj))  2 3)) "mm^2"
;;;;调试部分
      ((wcmatch (STRCASE (dxf ent 1)) "`%`%13*[50-250]`(*`)")
        (progn
        (setq lst (list "====箍筋面积====" laynm
                        (strcat "钢筋面积:" (rtos(/ (tc_tctc5 (vla-get-textstring obj)) 100) 2 3) "/"
                        (rtos (/ (/ (* (tc_tctc5 (vla-get-textstring obj)) tc_t8)tc_t9a) 100) 2 3)) "cm^2"
;;;;调试部分
       ((wcmatch (STRCASE (dxf ent 1)) "#`%`%13[0-4]##+#`%`%13[0-4]##,#`%`%13[0-4]##+##`%`%13[0-4]##,##`%`%13[0-4]##+#`%`%13[0-4]##;##`%`%13[0-4]##+##`%`%13[0-4]##")
        (progn
                        (strcat "钢筋面积:" (rtos (/ (tc_tctc4 (vla-get-textstring obj)) 100) 2 3)) "cm^2"
      );end cond
    (setq ss (ssadd) h (/ (getvar "viewsize") 35))
    (setq ang (fx (angle (getvar "viewctr") pt)))
    (setq n (* 1.4 (1+ (/ (apply 'max (mapcar 'strlen lst)) 2.0))))
    (ssadd (add_solid pt (polar pt (car ang) (* n h)) (setq pt (polar pt (cadr ang) (+ h (* 1.8 h (length lst))))) (polar pt (car ang) (* n h))) ss)
    (setq pt (polar pt (car ang) (/ (* n h) 2)))
    (if (= (caddr ang) 0)
      (setq pt (polar pt (/ pi 2) (* 0.4 h)))
      (setq pt (polar pt (/ pi 2) (+ (* 1.4 h) (* 1.8 h (length lst)))))
    (setq n -1)
    (repeat (length lst)
      (ssadd (add_text (setq pt (polar pt (+ pi (/ pi 2)) (* 1.8 h))) h 0 (nth (setq n (1+ n)) lst) "钢筋显示" 1) ss)
  (vl-load-com)
  (command "_.undo" "_m")
  (prompt "\n***移动鼠标掠过对象查看信息!***")
  (setq olderr *error* *error* myerr)
  (setq oldos (getvar "osmode"))
  (setq oldfill (getvar "fillmode"))
  (setvar "osmode" 0)
  (setvar "fillmode" 1)
  (setvar "cmdecho" 0)
  (tc_jzhz)
  (setq ss (ssadd))
  (while (not pd)
    (while (not (progn
                  (setq gr (grread T 1))
    (if (= (car gr) 5)
      (setq pt (cadr gr)
            ent (nentselp pt)
            ent (if (and ent (= (type (last (last ent))) 'ename))
                  (last (last ent))
                  (car ent)
      (setq pd T)
    (if (and (not pd) (not (equal ent entold)) (not (ssmemb ent ss)))
      (progn
        (if entold (redraw entold 4))
        (if ss (command "_.erase" ss ""))
        (redraw ent 3)
(dis ent)
(setq entold ent)
  (setvar "osmode" oldos)
  (setvar "fillmode" oldfill)
  (princ)
(princ)
;;下列程序与这程序类似!
;;转贴自从XDCAD,作者忘了!是你嗎?
;;当鼠标移动到满足过滤条件的像素上时,像素会闪动
;;USAGE:(CS_EntSel "\n请选Polyline物件: " '((0 . "*Polyline")))
(defun CS_ENTSEL (STR FILTER / PT SS_NAME SS)
  (if (/= (type STR) 'STR)
    (progn
      (princ "\n变量类型不对,STR应为字符串。\n")
      (eval NIL)
    (progn
      (if (/= (type FILTER) 'list)
(progn
   (princ "\n变量类型不对,FILTER应为表。\n")
   (eval NIL)
(progn
   (princ STR)
   (setq PT (grread t 4 2))
   (while (/= 3 (car PT))
     (if (= 5 (car PT))
       (progn
  (setq PT (cadr PT))
  (setq SS (ssget PT FILTER))
  (if SS_NAME
    (redraw SS_NAME 4)
  (setq SS_NAME NIL)
  (if SS
    (progn
      (setq SS_NAME (ssname SS 0))
      (redraw SS_NAME 3)
   (setq PT (cadr PT))
   (if SS_NAME
     (redraw SS_NAME 4)
   (setq SS_NAME NIL)
   (if SS
     (progn
       (list SS_NAME PT)
     (eval CS_NAME)
  (defun set-description (a d /  b e)
    (if (car (atoms-family 1 '("vl-load-com"))) (vl-load-com))
    (setq a (vlax-ename->vla-object a))
    (setq b (vla-get-Hyperlinks a))
    (vlax-for item b
      (vla-delete item)
    (setq e (vla-add b "DescriptionOnly"))
    (vla-put-URLDescription e d)
    (command "redraw")
;;;;;;tc_makestyle 加载字体并作当前字体样式====
(defun tc_jzhz ()
  (if (not (tblobjname "style" "钢筋显示"))
    (entmake
      '((0 . "STYLE")
        (100 . "AcDbSymbolTableRecord")
        (100 . "AcDbTextStyleTableRecord")
        (2 . "钢筋显示")
        (70 . 0)
        (40 . 0)
        (41 . 0.6)
        (50 . 0)
        (71 . 0)
        (42 . 0.2)
        (41 . 1)
        (3 . "黑体")
        ;(4 . "常规")
  (setvar "textstyle" "钢筋显示")
;;;;;;;;第一种钢筋面积显示已完成
(defun tc_tctc1 (txt3 / N1 t1 t2 TC_GJMJ1)
   (setq n1 (vl-string-search "%"  txt3)) ;在字符串中搜索指定子串的位置编号
      (setq t1 (atoi (substr txt3 1 n1))
            t2 (atoi (substr txt3 (+ n1 6))))
    (setq tc_gjmj1 (* t1 (/ (* t2 t2 3.1415926) 4)))
(defun tc_tctc2 (txt3 / N2 t3 t4 TC_GJMJ2)
   (setq n2 (vl-string-search "/"  txt3)) ;在字符串中搜索指定子串的位置编号
      (setq t3 (substr txt3 1 n2)
            t4 (substr txt3 (+ n2 2)))
    (setq tc_gjmj2 (+ (tc_tctc1 t3) (tc_tctc1 t4)))
(defun tc_tctc3 (txt3 / N3 N4 T5 T6 TC_GJMJ3 )
   (setq n3 (vl-string-search "%"  txt3)) ;在字符串中搜索指定子串的位置号
   (setq n4 (vl-string-search "@"  txt3))
      (setq t5 (atof (substr txt3 (+ n3 6) (1- n4)))
            t6 (atof (substr txt3  (+ n4 2)))
    (setq tc_gjmj3 (* (/ 1000 t6) (/ (* t5 t5 3.1415926) 4)))
(defun tc_tctc4 (txt3 / N2 t3 t4 TC_GJMJ4)
   (setq n2 (vl-string-search "+"  txt3)) ;在字符串中搜索指定子串的位置编号
    (setq tc_gjmj4 (+ (tc_tctc1 t3) (tc_tctc1 t4)))
(defun tc_tctc5 (txt3 / N5 N5A N6 N6A N7 N7A N8 N8A N9A TC_AREA1 TC_AREA2 TC_GJMJ5 TC_NUM1 TC_T10A TC_T7 TC_T7A TC_T9)
  (setq tc_num1 (vl-string-search "/"  txt3))
  (if (= tc_num1 nil)
    (progn
  (setq n5 (vl-string-search "%"  txt3)) ;在字符串中搜索指定子串的位置号
  (setq n6 (vl-string-search "@"  txt3))
  (setq n7 (vl-string-search "("  txt3))
  (setq n8 (vl-string-search ")"  txt3))
      (setq tc_t7 (atoi (substr txt3 (+ n5 6) (- n6 (+ n5 5)))))
      (setq tc_t8 (atoi (substr txt3  (+ n6 2) (- n7 (+ n6 1))))
            tc_t9 (atoi (substr txt3  (+ n7 2) (- n8 (1+ n7))))
  (setq tc_t9a tc_t8)
  (setq tc_area1 (/ (* tc_t7 tc_t7 3.1415926) 4))
  (setq tc_gjmj5 (/ (* tc_area1 200 tc_t9) tc_t8))
  (if (>= tc_t7 10) (setq tc_gjmj5 (/ (* tc_gjmj5 300) 210)))
(progn
  (setq n5a (vl-string-search "%"  txt3)) ;在字符串中搜索指定子串的位置号
  (setq n6a (vl-string-search "@"  txt3))
  (setq n7a (vl-string-search "/"  txt3))
  (setq n8a (vl-string-search "("  txt3))
  (setq n9a (vl-string-search ")"  txt3))
        (setq tc_t7a (atoi (substr txt3 (+ n5a 6) (- n6a (+ n5a 5)))))
      (setq tc_t8 (atoi (substr txt3  (+ n6a 2) (- n7a (+ n6a 1))))
            tc_t9a (atoi (substr txt3  (+ n7a 2) (- n8a (1+ n7a))))
            tc_t10a (atoi (substr txt3  (+ n8a 2) (- n9a (1+ n8a))))
  (setq tc_area2 (/ (* tc_t7a tc_t7a 3.1415926) 4))
     (setq tc_gjmj5 (/ (* tc_area2 200 tc_t10a) tc_t8))
     (if (>= tc_t7a 10) (setq tc_gjmj5 (/ (* tc_gjmj5 300) 210)))
     ;(setq tc_gjmj6 (/ (* tc_area 200 tc_t10) tc_t9))
     ;(if (>= tc_t7 10) (setq tc_gjmj6 (/ (* tc_gjmj6 300) 210)))
发表于 2005-11-29 11:34:59 | 显示全部楼层
程序较长,没仔细看。
现在贴出来的程序不能运行。
“2%%13118”能显示吗?
先贴个能正常运行的上来。
再讨论“%%1308@200(2)显示不了”的问题。
 楼主| 发表于 2005-11-29 18:36:09 | 显示全部楼层
       I 0)
        SL (STRLEN STR)
        J 1 I (1+ I))
   (IF (< J SL) (PROGN
    (ENTMOD ENT)
(PRINC)
(DEFUN C:SHOWBAR ()
       I 0)
        SL (STRLEN STR)
        J 1 S3 0 I (1+ I))
   (WHILE (< J SL)
    (SETQ S1 "" S2 "")
    (SETQ J (+ J 1))
    (SETQ J (1+ J))
   (ENTMOD ENT)
(PRINC)
  (defun myerr(msg)
    (princ)
  (defun dxf(ent i)
    (cdr (assoc i ent))
  (defun toang(ang i)
    (if (= i 1)
      (* ang (/ 180 pi))
      (* ang (/ pi 180))
  (defun fx(ang)
    (cond
    ;;;;;;首先取得文字容
  (cond
        (progn
        (progn
        (progn
;;;;调试部分
        (progn
;;;;调试部分
        (progn
      );end cond
    (setq n -1)
  (vl-load-com)
  (setvar "osmode" 0)
  (tc_jzhz)
  (setq ss (ssadd))
  (while (not pd)
    (while (not (progn
    (if (= (car gr) 5)
      (setq pt (cadr gr)
            ent (nentselp pt)
                  (last (last ent))
                  (car ent)
      (setq pd T)
      (progn
        (redraw ent 3)
(dis ent)
(setq entold ent)
  (princ)
(princ)
;;下列程序与这程序类似!
    (progn
      (eval NIL)
    (progn
(progn
   (eval NIL)
(progn
   (princ STR)
     (if (= 5 (car PT))
       (progn
  (setq PT (cadr PT))
  (if SS_NAME
    (redraw SS_NAME 4)
  (setq SS_NAME NIL)
  (if SS
    (progn
      (redraw SS_NAME 3)
   (setq PT (cadr PT))
   (if SS_NAME
     (redraw SS_NAME 4)
   (setq SS_NAME NIL)
   (if SS
     (progn
       (list SS_NAME PT)
     (eval CS_NAME)
    (vlax-for item b
      (vla-delete item)
    (command "redraw")
(defun tc_jzhz ()
    (entmake
      '((0 . "STYLE")
        (2 . "钢筋显示")
        (70 . 0)
        (40 . 0)
        (41 . 0.6)
        (50 . 0)
        (71 . 0)
        (42 . 0.2)
        (41 . 1)
        (3 . "黑体")
        ;(4 . "常规")
  (if (= tc_num1 nil)
    (progn
  (setq tc_t9a tc_t8)
(progn
发表于 2005-11-30 09:22:58 | 显示全部楼层
试了下,还不错。
程序可以显示啊。
只是结果不正确。
应该是你的计算公式有问题。
因为程序没有太多注释,看起来较累,你还是自己找找吧。
另外建议:
1、增加判断,仅在鼠标划过有效的钢筋标注字符串时才让程序运行计算显示部分。
2、其实钢筋标注有很多类型,箍筋也还有%%13110@100/200(2)等的形式。
3、显示的字体太大了点。
4、因为俺也写了这个程序,其它不讲了。欢迎交流。。。。。。
它山大师,把你的码也贴上来不?呵呵  详情 回复 发表于 2013-11-26 16:29
发表于 2005-11-30 13:30:22 | 显示全部楼层
这么复杂,怎么用.能演示一下吗?
 楼主| 发表于 2005-11-30 23:47:46 | 显示全部楼层
我们院设计的时候输入的钢筋间距均为200。箍筋强度设计值均为210;所以这个显示的是PKPM输出时的值,用于校对箍筋
还有想请教它山之石,为什么像%%1308@100等以%%1308开头的钢筋显示不了
发表于 2005-12-1 00:27:49 | 显示全部楼层
还是没搞懂你的程序.
发表于 2005-12-1 11:18:24 | 显示全部楼层
当直径为8时也就是<=10时,
的值为nil
tc_tctc5 函数的定义中最后应该输出结果tc_gjmj5
修改为以下代码就可以了:
[php]
      (if (>= tc_t7 10)
        (setq tc_gjmj5 tc_gjmj5)
      ) ;_ 结束if
[/php]
 楼主| 发表于 2005-12-2 23:07:36 | 显示全部楼层
楼上的楼主,加你为什么加不上
发表于 2013-11-26 16:29:10 | 显示全部楼层
它山之石 发表于 2005-11-30 09:22
试了下,还不错。
程序可以显示啊。
只是结果不正确。
它山大师,把你的码也贴上来不?呵呵
GMT+8, 2026-11-22 10:42 , Processed in 0.372126 second(s), 28 queries , Gzip On, File On.
