查看: 2488|回复: 8
[LISP程序]:老外寫的修改圓半徑程序
发表于 2005-11-30 08:41:15 | 显示全部楼层 |阅读模式
[php]; =============================================================================
; Filename    :   ChgRad.lsp
; Datum       :   07.11.01
; Author      :   jme
; Copyright   :   MENZI ENGINEERING GmbH
; Revision  1 :   18.01.05 jme - Selection mode added
; Revision  2 :   __.__.__ ___ -
; Description:
; Function to change the radius of circles.
; Known bugs:
; - None
; Global variables:
; Me:Err  Me:Nra  Me:Ora  Me:Smd  Me:Svr
; Internal LISP-functions:
; MeEndFunction  MeGetAssoc  MeGetRadius  MeStartFunction  MeUserError
; External LISP-functions:
; Version notes:
; AutoCAD:        Version:        Language:        AddIns:
; 14+                1.01                English                ...
; -- Message on loading -------------------------------------------------------
(princ "\nChgRad v1.01")
; == Main =====================================================================
(defun c:chgrad( / CurEnt CurSet EntLst FltLst TmpStr)
(MeStartFunction '("APERTURE" "AUTOSNAP" "CURSORSIZE" "OSMODE"))
(initget "Match Select")
(setq Me:Ora (cond
               (Me:Ora)
               ((> (getvar "CIRCLERAD") 0) (getvar "CIRCLERAD"))
               (1.0)
       Me:Nra (cond
               (Me:Nra)
               (1.0)
       Me:Smd (cond (Me:Smd) ("Select"))
       TmpStr (strcat "\nSelection mode [Match/Select] <" Me:Smd ">: ")
       Me:Smd (cond ((getkword TmpStr)) (Me:Smd))
(if (eq Me:Smd "Select")
  (progn
   (princ "\nSelect circle(s)...")
   (setq CurSet (ssget '((0 . "CIRCLE"))))
  (setq Me:Ora (MeGetRadius "\nSelect Circle or enter radius to match" Me:Ora)
        FltLst (list
               '(0 . "CIRCLE")
               '(-4 . ">=") (cons 40 (- Me:Ora 1E-6))
               '(-4 . "<=") (cons 40 (+ Me:Ora 1E-6))
        CurSet (ssget "X" FltLst)
(if CurSet
  (progn
   (setq Me:Nra (MeGetRadius "\nSelect Circle or enter new radius" Me:Nra))
   (while (setq CurEnt (ssname CurSet 0))
    (setq EntLst (entget CurEnt)
          EntLst (subst (cons 40 Me:Nra) (assoc 40 EntLst) EntLst)
    (entmod EntLst)
    (ssdel CurEnt CurSet)
  (if (eq Me:Smd "Match") (alert "No matching circle(s) found..."))
(MeEndFunction)
; == Subs =====================================================================
; -- Function MeGetRadius
; Get the default radius by object or number.
; Arguments [Typ]:
;   Pmt = Prompt [STR]
;   Rad = Default radius [REAL]
; Return [Typ]:
;   > New radius [REAL]
; Notes:
;   None
(defun MeGetRadius (Pmt Rad / EntLst GoLoop RetVal TmpStr TmpVal)
(setq GoLoop T)
(while GoLoop
  (setvar "OSMODE" 512)
  (setvar "APERTURE" (getvar "PICKBOX"))
  (setvar "AUTOSNAP" 0)
  (setvar "CURSORSIZE" 1)
  (initget 128)
  (setq RetVal (getpoint (strcat Pmt " <" (rtos Rad) ">: ")))
  (setvar "OSMODE" 0)
  (setvar "APERTURE" (MeGetAssoc "APERTURE" Me:Svr))
  (setvar "AUTOSNAP" (MeGetAssoc "AUTOSNAP" Me:Svr))
  (setvar "CURSORSIZE" (MeGetAssoc "CURSORSIZE" Me:Svr))
  (cond
   ((= (type RetVal) 'LIST)
    (if (= (type (setq TmpVal (car (nentselp RetVal)))) 'ENAME)
     (progn
      (setq EntLst (entget TmpVal))
      (if (= (MeGetAssoc 0 EntLst) "CIRCLE")
       (setq RetVal (MeGetAssoc 40 EntLst)
             GoLoop nil
       (prompt "selected object is not a Circle. ")
     (prompt "1 selected, 0 found. ")
   ((= (type RetVal) 'STR)
    (cond
     ((wcmatch RetVal "*[~0-9.-]*")
      (prompt "requires a decimal number. ")
     ((minusp (atof RetVal))
      (prompt "number must be positive. ")
     ((zerop (atof RetVal))
      (prompt "requires a number >0. ")
     (T
      (setq RetVal (atof RetVal)
            GoLoop nil
   (T
    (setq GoLoop nil
          RetVal Rad
RetVal
; -- Function MeGetAssoc
; Returns the assoc value of a DottedPair list.
; Arguments [Typ]:
;   Key = Key name [ALL]
; Return [Typ]:
;   > Associated value from list [ALL]
; Notes:
;   None
(defun MeGetAssoc (Key Lst) (cdr (assoc Key Lst)))
; -- User Error
(defun MeUserError (Msg)
(command) (command)
(if (not
      (member Msg
      '("Function cancelled" "console break" "quit / exit abort")
  (princ (strcat "\nError: " Msg))
(MeEndFunction)
(princ)
; -- Start function
(defun MeStartFunction (Lst)
(setvar "CMDECHO" 0)
(if (= (logand (getvar "UNDOCTL") 4) 4) (command "_.UNDO" "_GROUP"))
(setq Me:Err  *error*
       *error* MeUserError
       Me:Svr  (mapcar '(lambda (l) (cons l (getvar l))) Lst)
(princ)
; -- End function
(defun MeEndFunction ()
(if Me:Svr (mapcar '(lambda (l) (setvar (car l) (cdr l))) Me:Svr))
(setq Me:Svr  nil
       *error* Me:Err
(if (= (logand (getvar "UNDOCTL") 4) 4) (command "_.UNDO" "_END"))
(princ)
; == Copyright - Note (May be never deleted) ==================================
(princ "\n------------------------------------------------")
(princ "\n ?001-2005 MENZI ENGINEERING GmbH, Switzerland ")
(princ "\nType ChgRad in the command line to start the programm...")
(princ)
; == End ChgCircRad ===========================================================[/php]
发表于 2005-12-1 02:07:22 | 显示全部楼层
改多个用ctrl+1特性管理工具就挺好用
改单个也可用夹点直接改
发表于 2006-11-10 16:34:54 | 显示全部楼层
感谢楼主精彩贡献
发表于 2006-12-7 17:42:28 | 显示全部楼层
16个隐藏在Windows XP系统背后的小窍门
http://www.sina.com.cn 2006年12月07日 09:44 eNet硅谷动力
  这些Windows XP的窍门你也许不知道,但有可能很有用:
  安装音乐:
  开始 > 运行 > “C:\Windows\system32\oobe\images\title.wma” > 确定
  让机器休眠(Hibernate):
  开始 > 关闭电脑… > 按Shift键”待机”就会变成”休眠”。
  隐藏的设备
  控制面板> 系统 > 硬件 > 设备管理器 > 选择菜单”查看”中”的显示隐藏的设备”。
  字符映射表
  开始 > 运行 > “charmap.exe” > 确定
  剪贴板查看器
  开始 > 运行 > “clipbrd.exe” &
gt; 确定
  Dr Watson
  开始 > 运行 > “drwtsn32.exe” > 确定
  IExpress Wizard(一个自解压包制作工具)
  开始 > 运行 > “iexpress.exe” > 确定
  老的Windows 媒体播放器 5.1
  开始 > 运行 > “mplay32.exe” > 确定
  ODBC 数据源管理器
  开始 > 运行 > “odbcad32.exe” > 确定
  对象包装程序
  开始 > 运行 > “packager.exe” > 确定
  系统性能监视器
  开始 > 运行 > “perfmon.exe” > 确定
  创建共享文件夹向导
  开始 > 运行 > “shrpubw.exe” > 确定
  文件签名验证工具
  开始 > 运行 > “sigverif.exe” > 确定
  系统配制编辑器
  开始 > 运行 > “sysedit.exe” > 确定
  驱动程序验证管理器
  开始 > 运行 > “verifier.exe” > 确定
  工作组聊天软件
  开始 > 运行 > “winchat.exe” > 确定
发表于 2007-2-5 07:57:15 | 显示全部楼层
谢楼主提供,思路值得学习哦
发表于 2009-8-31 19:20:44 | 显示全部楼层
感谢楼主
发表于 2009-9-6 16:40:17 | 显示全部楼层
感谢楼主,受益哦!
发表于 2009-10-9 18:54:54 | 显示全部楼层
看不懂
发表于 2009-11-7 14:37:27 | 显示全部楼层
感谢楼主,太神奇了!
GMT+8, 2026-11-22 10:42 , Processed in 0.389876 second(s), 26 queries , Gzip On, File On.
