查看: 860|回复: 2
[求助] [求助]:为啥执行不了,帮忙看看
发表于 2005-12-15 13:59:47 | 显示全部楼层 |阅读模式
目的:已知date中是pl的顶点列表(例如:((91.3672 162.024) (182.995 101.687) (328.245 123.013) (400.089 81.9221)),想在pl的中点插入文字
(defun c:bz(a b / ii pp ppt bp)
    (setvar "cmdecho" 0)
    (setq pp (nth 0 date))
    (setq ii 1)
  (repeat (1- (length date))
    (setq ppt (nth ii date)
    (setq bp (mapcar '(lambda(a b) (/ (+ a b) 2)) pp ppt))
    (command "text" bp "3.0" "" "DN200")
    (setq pp ppt)
    (setq ii (1+ ii))
(prin1)
发表于 2005-12-15 15:16:32 | 显示全部楼层
有两个问题:
1、你定义的是一个命令,后面不要带自变量
2、在REPEAT一行少了一个括号
更改后为:
  1.   [FONT=courier new]
  2. (defun c:bz (/ ii pp ppt bp)
  3.   (setvar "cmdecho" 0)
  4.   (setq pp (nth 0 date))
  5.   (setq ii 1)
  6.   (repeat (1- (length date))
  7.     (setq ppt (nth ii date))
  8.     (setq bp (mapcar '(lambda (a b) (/ (+ a b) 2)) pp ppt))
  9.     (command "text" bp "3.0" "" "DN200")
  10.     (setq pp ppt)
  11.     (setq ii (1+ ii))
  12.   )
  13.   (princ)
  14. )
  15.   [/FONT]
 楼主| 发表于 2005-12-15 17:08:44 | 显示全部楼层
谢谢
GMT+8, 2026-10-17 02:19 , Processed in 0.711274 second(s), 36 queries , Gzip On.
