查看: 946|回复: 3
[LISP函数]:xyp大虾请进
发表于 2005-12-22 11:55:25 | 显示全部楼层 |阅读模式
;;;曲线交点插块
(defun c:test (/ ptlst)
  (CMDLA0)
  (setvar"osmode"0)
  (setq  dwgname (USTR 1 "\n图块名称" dwgname NIL)
    ss (ssget '((0 . "CIRCLE,ELLIPSE,*LINE,ARC")))
        i  -1
        j  0
  (mkla "图块" 3)
  (while (setq s1 (ssname ss (setq i (1+ i))))
    (setq j i)
    (while (setq s2 (ssname ss (setq j (1+ j))))
      (setq ptlst (X_INTERS s1 s2))
      (while (setq pt (car ptlst))
        (setq ptlst (cdr ptlst))
        (command "insert" dwgname pt "" "" "")
  (CMDLA1)
(DEFUN mkla (A B)
  (IF (= (TBLSEARCH "layer" A) NIL)
    (COMMAND "layer" "m" A "c" B A "")
    (COMMAND "layer" "t" A "s" A "c" B A "")
(DEFUN CMDLA0 ()
  (SETQ CMD (GETVAR "CMDECHO"))
  (SETQ OOM (GETVAR "orthomode"))
  (SETQ OSM (GETVAR "osmode"))
  (SETQ HLT (GETVAR "highlight"))
  (SETQ RMODE (GETVAR "regenmode"))
  (SETVAR "regenmode" 0)
  (SETVAR "CMDECHO" 0)
  (PRINC)
(DEFUN CMDLA1 ()
  (SETVAR "CMDECHO" CMD)
  (SETVAR "orthomode" OOM)
  (SETVAR "osmode" OSM)
  (SETVAR "highlight" HLT)
  (SETVAR "regenmode" RMODE)
  (PRINC)
能不能告诉我一下,这个程序在r14运行的方法,
这个对我非常重要
最好是把调用的其他函数贴一下,谢谢
已领礼包: 2个
发表于 2005-12-22 13:25:09 | 显示全部楼层
在14里没法运行,还是升级你的cad吧
 楼主| 发表于 2005-12-22 15:44:32 | 显示全部楼层
我知道   ,但是这个问题应该不难解决,只要把没有的函数补齐就应该可以了
已领礼包: 2个
发表于 2005-12-22 16:16:59 | 显示全部楼层
X_INTERS这个函数用纯lisp写有点困难
试试这个地方http://www.mjtd.com/bbs/dispbbs. ... 9&page=1之3楼
GMT+8, 2026-11-6 20:45 , Processed in 0.398064 second(s), 38 queries , Gzip On.
