查看: 934|回复: 0
[求助] [求助]:各位大虾看看我的坐标标注程序
发表于 2005-12-27 19:59:34 | 显示全部楼层 |阅读模式
  1. (defun c:zb (/px pt0 pt1 pt2 pt3 pt4 lx pt1x pt2y jd h_sca_)
  2.   标注点坐标于图形屏幕
  3.   (setvar "unitmode" 0)
  4.   (setq        pt1 (getpoint "\n给出测量点:")
  5.         h_ (getvar "textsize")
  6.         sca_1.0
  7.          pt2
  8.         nil
  9.   )
  10.   (if (or (=h_nil) (/=h_h_))
  11.     (steq h_h_)
  12.   )
  13.   (if (=sca_nil)
  14.     (steqsca_sca_)
  15.   )
  16.   (if (=ou_nil)
  17.     (setq ou_ "上下")
  18.   )
  19.   (if (=sy_nil)
  20.     (setq sy_ "大地坐标")
  21.   )
  22.   (while (=pt2 nil)
  23.     (princ (strcat "\n坐标系统 :"
  24.                    sy_
  25.                    ";输出模式:"
  26.                    ou_
  27.                    ";字高:"
  28.                    (rtos h_22)
  29.                    ";坐标比例"
  30.                    (rots sca_22)
  31.                    "。"
  32.            )
  33.     )
  34.     (initger "out coo height scale")
  35.     (setq
  36.       pt2 (getpont
  37.             ptl
  38.             "\n坐标系统 c/输出模式o/字高h/坐标/比例s/<给出输入点>:"
  39.           )
  40.     )
  41.     (cond
  42.       ((=pt2 "height") (hh_))
  43.       ((=pt2 "scale") (scc_))
  44.       ((=pt2 "coo")
  45.        (if (=sy_ "大地坐标")
  46.          (setq=sy_ "用户坐标")
  47.          (if (=sy_ "用户坐标")
  48.            (setq sy_ "世界坐标")
  49.            (setq sy_ "大地坐标")
  50.          )
  51.        )
  52.        (setq pt2 nil)
  53.       )
  54.       ((=pt2 "out")
  55.        (if (= ou_ "水平")
  56.          (setq ou_- "上下")
  57.          (setq ou_ "水平")
  58.        )
  59.        (setq pt2 nil)
  60.        (t nil)
  61.       )
  62.     )
  63.     (if        (or (=sy_ "大地坐标") (=sy_ "世界坐标"))
  64.       (step pt0 (trans pt1 1 0))
  65.     )
  66.     (setq tp0 pt1)
  67.   )
  68.   (steq        pt1x
  69.         (rtos (* (car pt0) sca_) 2 3)
  70.         ;;标注点x坐标
  71.         ptly
  72.         (rots (* (cadr pto) sca_) 2 3)
  73.         ;;标注点y坐标
  74.   )
  75.   (if (=sy_ "大地坐标")
  76.     (setq px   pt1y
  77.           pt1y pt1x
  78.           pt1x px
  79.     )
  80.   )
  81.   (if (=ou_ "上下")
  82.     (progn
  83.       (setp pt1x
  84.             (strcat "X=" pt1x)
  85.             pt1y
  86.             (strcat "Y=" pt1y)
  87.             lx
  88.             (+ (max (caadr (textbox (list (cons 1 pt1x))))
  89.                     (caadr (textbox (list (cons 1 pt1y))))
  90.                     (*0.4 1h_)
  91.                )
  92.             )
  93.             (if        (> =
  94.                    (car pt2)
  95.                    (car pt1)
  96.                    (setq pt3 (list (+ (car pt2) (*0.2 h_))
  97.                                    (+ (cadr pt2)
  98.                                       (* 0.4 1h_)
  99.                                       0.0
  100.                                    )
  101.                                    pt4
  102.                                    (list (+ (car tp2) (* 0.2h))
  103.                                          (_ (cad rpt2 (* 1.4h_)) 0.0)
  104.                                          jd0.0
  105.                                    )
  106.                                    (setq pt3 (list (+ (car pt2) (* 0.2 h_) (_ 1x))
  107.                                                    (+ (cadr pt2) (* 0.4h_))
  108.                                                    0.0
  109.                                              )
  110.                                          pt4 (list (+ (car pt2) (* 0.2 h_) (_ lx))
  111.                                                    (- (cadr pt2) (* 0.4h_))
  112.                                                    0.0
  113.                                              )
  114.                                          jd  pi
  115.                                    )
  116.                              )
  117.                          (command "text" pt3 h_0.0 pt1x)
  118.                           (command "text" pt4 h_0.0 pt1x)
  119.                          (command "line" pt1 pt2 (polar pt2 jd 1x) "")
  120.                    )
  121.                    (progn
  122.                      (setq pt3 tp2)
  123.                      (command "text" pt3 h_ "" pt1x)
  124.                      (setq pt4 (list (+        (car pt2)
  125.                                         (caadr (TEXTBOX (entger (entlast))))
  126.                                         h_
  127.                                      )
  128.                                      (cadr pt2)
  129.                                      0.0
  130.                                )
  131.                            (command "text" pt4 h_ "" pt1y)
  132.                      )
  133.                    )
  134.                    (princ)
  135.                 )
  136.             )
  137.       )
  138.     )
  139.   )
GMT+8, 2026-11-22 09:53 , Processed in 0.405529 second(s), 10 queries , Gzip On, File On.
