查看: 4441|回复: 6
[LISP函数]:获取多边形各边中点的座标
已领礼包: 2个
发表于 2005-12-29 13:36:27 | 显示全部楼层 |阅读模式
[PHP](defun th-get-midptofpoly (ename / n ptlist pp)
  (setq ptlist (get-allvertexs ename))
  (setq n 0)
  (while (< n (1- (length ptlist)))
    (setq pp (append
               pp
               (list (mid-point (nth n ptlist) (nth (1+ n) ptlist)))
    (setq n (1+ n))
  pp
(defun get-allvertexs (e / n lst)
  (repeat (setq n (fix (1+ (vlax-curve-getendparam e))))
    (setq lst (cons (vlax-curve-getpointatparam e (setq n (1- n))) lst))
(defun mid-point (p1 p2)
  (mapcar
    '(lambda (x)
       (/ x 2)
    (mapcar
      p1
      p2
)[/PHP]
已领礼包: 593个
发表于 2005-12-29 14:22:31 | 显示全部楼层
  1. (defun xdl-poly-midp (ename / n ptlist pp)
  2.   (setq ptl (xdl-pl-vertexs ename))
  3.   (mapcar '(lambda (a b) (xdl-midp a b))
  4.           ;;ptl
  5.           ;;(append (cdr ptl) (list (car ptl)))
  6.           (cdr ptl)
  7.           ptl
  8.   )
  9. )
下面的两个函数在前面的帖子可以找到
  1. (defun xdl-pl-vertexs (e / n lst)
  2.   (repeat (setq n (fix (1+ (vlax-curve-getendparam e))))
  3.     (setq lst (cons (vlax-curve-getpointatparam e (setq n (1- n))) lst))
  4.   )
  5. )
  6. (defun xdl-midp        (p1 p2)
  7.   (mapcar '(lambda (x) (/ x 2)) (mapcar '+ p1 p2))
  8. )
发表于 2005-12-30 10:42:41 | 显示全部楼层
[php]
;; 取多义线各段中点坐标;支持有凸度的多义线。
(defun xdl-plmpts (e / n m mpts);; by 狂刀
  (setq n (fix (vlax-curve-getendparam e))
        m (+ n 0.5))
  (repeat n
    (setq mpts(cons (vlax-curve-getpointatparam e (setq m (1- m))) mpts))
[/php]
发表于 2006-6-10 20:19:32 | 显示全部楼层
还是 狂刀 的好用.
已领礼包: 3191个
发表于 2013-6-12 14:44:16 | 显示全部楼层
感谢tanger的程序函数
已领礼包: 305个
发表于 2014-3-23 22:25:53 | 显示全部楼层
谢谢老师的分享
发表于 2015-2-12 10:57:35 | 显示全部楼层
谢谢老师的分享;P
GMT+8, 2026-11-5 13:11 , Processed in 0.434379 second(s), 43 queries , Gzip On.
