查看: 1548|回复: 4
[LISP程序]:修改线宽的程序
发表于 2006-1-5 10:32:04 | 显示全部楼层 |阅读模式
(DEFUN  c:CHW( / k vl wid plist ename newwid pline)
  (setvar "cmdecho" 0)
  (setvar "blipmode" 0)
  (setq k(getvar "handles"))
  (if (= k 0)  (command"handles" "on"))
  (initget 4 "0 0.1 0.2 0.3 0.4 0.5 0.25")
  (setq wid (getreal "\nObjects' old_width(0/0.1/0.2/0.3/0.4/0.5/0.25/1.0)<ALL>:"))
  (if (= wid nil)(setq wid 10))
  (initget (+ 1 4))
  (setq newwid (getreal "\nNew width:"))
  (cond
    ((= wid 0)
      (setq vl(ssget'((-4 . "<AND")
            (0 . "LWPOLYLINE")
            (40 . 0)
          (-4 . "AND>")
        );ssget
      );setq
    ((= wid 0.1)
            (0 . "LWPOLYLINE")
            (40 . 0.1)
          (-4 . "AND>")
        );ssget
      );setq
    ((= wid 0.2)
            (0 . "LWPOLYLINE")
            (40 . 0.2)
          (-4 . "AND>")
        );ssget
      );setq
    ((= wid 0.3)
            (0 . "LWPOLYLINE")
            (40 . 0.3)
           (-4 . "AND>")
         );ssget
      );setq
    ((= wid 0.4)
            (0 . "LWPOLYLINE")
            (40 . 0.4)
          (-4 . "AND>")
            );ssget
      );setq
    ((= wid 0.5)
            (0 . "LWPOLYLINE")
            (40 . 0.5)
          (-4 . "AND>")
        );ssget
      );setq
    ((= wid 0.3999)
            (0 . "LWPOLYLINE")
            (40 . 0.3999)
          (-4 . "AND>")
        );ssget
      );setq
    ((= wid 0.25)
            (0 . "LWPOLYLINE")
            (40 . 0.25)
          (-4 . "AND>")
        );ssget
      );setq
    ((= wid 1.0)
            (0 . "LWPOLYLINE")
            (40 . 1.0)
          (-4 . "AND>")
        );ssget
      );setq
    ((= wid 10)
      (setq vl(ssget'((0 . "LWPOLYLINE")));ssget
      );setq
    (t
      (progn
        (print"...........Bad width value!")
        (setq k "fail")
      );progn
  );cond
  (if (/= k "fail")
    (progn
      (setq vl(gethand vl))
      (foreach ename vl
        (setq ename(handent ename))
        (chplw ename newwid)
      );foreach
    );progn
  );if k
  (setvar "cmdecho" 1)
  (setvar "blipmode" 1)
  (princ)
);defun
(princ "\n***** 函数c:chw()已加载")
发表于 2006-3-16 16:24:56 | 显示全部楼层
鼓励一下 感谢楼主 很好用
发表于 2006-3-21 00:40:25 | 显示全部楼层
一个小程序,需要写得这么烦吗?
发表于 2006-3-26 15:45:31 | 显示全部楼层
请问前辈这个程序怎么样用啊~~~~~~?
发表于 2009-5-31 14:02:24 | 显示全部楼层
不能用
GMT+8, 2026-11-22 11:01 , Processed in 0.273828 second(s), 18 queries , Gzip On, File On.
