查看: 857|回复: 0
[求助] [求助]:[0210]修正图层输出与输入程序问题
发表于 2006-2-10 06:26:39 | 显示全部楼层 |阅读模式
请教各位高手们
以下这程序是用来输出及输入图档内图层的设定
但目前这程序有各问题
就是已存在的图层会出现些讯息
如果要改正这问题该怎样处理呢?
另外请教关于串列读取问题,假设为
   A B C D ...
1. 2 8 1 6 ...
2. 5 7 3 4 ...
3. 7 5 4 3 ...
如果说要读取的位置是 B-3 ,或 D-2 ;
请问该怎样选取到要读取的位置?
另外关于程式中用到数值记忆时,
有位高手说可以用这种读写档案的方式存取数值,
该怎样由这种方式存取呢?
最后,请问外部档案内可以设定注解吗?
以上问题烦请各位帮忙解答一下
谢谢~
[PHP]
(defun c:kP1()
       (setvar "cmdecho" 0)
       (setq ffn "c:\\layall.txt")
       (initget "r w")
       (setq ans (getkword "\n(W)图层写出 (R)读取外档<W>:"))
       (if (null ans)(setq ans "w"))
       (if (= ans "w")
           (w_lay)
           (r_lay)
      (prin1)
(defun w_lay()
       (setq ff (open ffn "w"))
       (close ff)
         (setq ff (open ffn "a"))
         (princ "图层名称    颜色    线型" ff)
         (princ "\n" ff)
          (close ff)
       (setq lay_a (tblnext "layer" t))
        (while lay_a
          (setq layname (cdr (assoc 2 lay_a)))
          (setq laycolor (cdr (assoc 62 lay_a)))
          (setq laylitype (cdr (assoc 6 lay_a)))
          (princ layname ff)
          (princ "," ff)
          (princ laycolor ff)
          (princ "," ff)
          (princ laylitype ff)
           (princ "\n" ff)
          (close ff)
          (setq lay_a (tblnext "layer"))
(defun r_lay()
       (setq ffk (open ffn "r"))
         (setq kaka (read-line ffk))
         (while kaka
           (setq pk 1 k "" kk "" kkk '())
           (repeat (strlen kaka)
           (setq k (substr kaka pk 1))
           (if (/= k ",")
           (setq kk (strcat kk k))
           (setq kkk (cons kk kkk) kk "")
           )   ; 结束if
           (setq pk (+ 1 pk))
           )  ;结束repeat
           (setq kkk (cons kk kkk))
           (setq keyt (reverse kkk))
         (setq tx0 (nth 0 keyt))
         (setq tx1 (nth 1 keyt))
         (setq tx2 (nth 2 keyt))
         (setq tstyle (tblsearch "ltype" tx2))
(if (= tstyle nil)
(command "linetype" "L" tx2 "acadiso" "" "")
(command "layer" "n" tx0 "c" tx1 tx0 "l" tx2 tx0 ""))
) ;;_(if
(close ffk)
(prin1)
[/PHP]
GMT+8, 2026-11-6 23:37 , Processed in 0.391030 second(s), 32 queries , Gzip On.
