查看: 3997|回复: 16
[分享]:各类面积查询
发表于 2006-2-21 16:18:53 | 显示全部楼层 |阅读模式
;;;;;三点面积
(defun c:3dmj (/ pt1 pt2 pt3)
  (command "undo" "be")                        ; 定义返回点
  (setvar "cmdecho" 0)                        ; 关闭命令提示
  (princ "\n测量三点面积;\n请依次选择三点:")
  (setq sl_mj_end 0)
  (setq pt1 (getpoint))
  (setq pt2 (getpoint pt1))
  (command "line" pt1 pt2 "")
  (setq pt3 (getpoint pt2))
  (command "line" pt2 pt3 pt1 "")
  (3d_mj_zx pt1 pt2 pt3)
  (setq 3l_chd_end (* 2 3l_chd_end))
  (princ "\n周长 ")
  (princ 3l_chd_end)
  (princ ";  面积 ")
  (princ 3l_mj_end)
  (princ)
  (alert "请确认")
  (command "ERASE" "l" "")
  (command "undo" "e")                        ; 定义返点
  (setvar "cmdecho" 1)                        ; 打开命令提示
  (princ)
;;;;;三点求面积
(defun 3d_mj_zx        (pt1 pt2 pt3 / la lb lc)
  (setq la (distance pt1 pt2))
  (setq lb (distance pt2 pt3))
  (setq lc (distance pt3 pt1))
  (3l_mj_zx la lb lc)
;;;;;三边长求面积
(defun 3l_mj_zx        (la lb lc /)
  (setq 3l_chd_end (* 0.5 (+ la lb lc)))
  (setq        3l_mj_end (sqrt        (* 3l_chd_end
                           (- 3l_chd_end la)
                           (- 3l_chd_end lb)
                           (- 3l_chd_end lc)
;;;;;弧线面积
(defun c:hmj (/ arc_ss arc_mj arc n)
  (princ "\n测量弧线面积;\n请选择弧线:")
  (setq arc_ss (ssget (list (cons 0 '"ARC"))))
  (setq arc_mj 0)
  (setq n 0)
  (while (< n (sslength arc_ss))
    (setq arc (ssname arc_ss n))
    (arc_mj_zx arc)
    (setq arc_mj (+ arc_mj arc_mj_jg))
    (setq n (1+ n))
  (princ "\n弧线数量")
  (princ n)
  (princ ";面积")
  (princ arc_mj)
  (princ)
;;;;;弧线面积执行
(defun arc_mj_zx (arc /)
  (command "pedit" arc "y" "")
  (command "AREA" "O" "l")
  (command "explode" "l")
  (setq arc_mj_jg (getvar "AREA"))
;;;;;圆面积
(defun c:ymj (/ arc_ss arc_mj circle n)
  (princ "\n测量圆面积;\n请选择圆:")
  (setq circle_ss (ssget (list (cons 0 '"CIRCLE"))))
  (setq circle_mj 0)
  (setq n 0)
  (while (< n (sslength circle_ss))
    (setq circle (ssname circle_ss n))
    (circle_mj_zx circle)
    (setq circle_mj (+ circle_mj circle_mj_jg))
    (setq n (1+ n))
  (princ "\n圆数量")
  (princ n)
  (princ ";面积")
  (princ circle_mj)
  (princ)
;;;;;圆面积执行
(defun circle_mj_zx (circle / r)
  (setq r (cdr (assoc '40 (entget circle))))
  (setq circle_mj_jg (* r r pi))
;;;;;多段线面积
(defun c:plmj (/ arc_ss arc_mj pline n)
  (princ "\n测量多段线面积;\n请选择多段线:")
  (setq pline_ss (ssget (list (cons 0 "LWPOLYLINE"))))
  (setq pline_mj 0)
  (setq n 0)
  (while (< n (sslength pline_ss))
    (setq pline (ssname pline_ss n))
    (pline_mj_zx pline)
    (setq pline_mj (+ pline_mj pl_mj_jg))
    (setq n (1+ n))
  (princ "\n多段线数量")
  (princ n)
  (princ ";面积")
  (princ pline_mj)
  (princ)
;;;;;多段线面积执行
(defun pline_mj_zx (pline /)
  (command "AREA" "O" pline)
  (setq pl_mj_jg (getvar "AREA"))
;;;;;面域面积
(defun c:mymj (/ arc_ss arc_mj pline n)
  (princ "\n测量面域面积;\n请选择面域:")
  (setq my_ss (ssget (list (cons 0 "REGION"))))
  (setq my_mj 0)
  (setq n 0)
  (while (< n (sslength my_ss))
    (setq my (ssname my_ss n))
    (my_mj_zx my)
    (setq my_mj (+ my_mj my_mj_jg))
    (setq n (1+ n))
  (princ "\n面域数量")
  (princ n)
  (princ ";面积")
  (princ my_mj)
  (princ)
;;;;;面域面积执行
(defun my_mj_zx        (my /)
  (command "AREA" "O" my)
  (setq my_mj_jg (getvar "AREA"))
;;;;;填充面积
(defun c:tcmj (/ arc_ss arc_mj pline n)
  (princ "\n测量填充面积;\n请选择闭合填充:")
  (setq tc_ss (ssget (list (cons 0 "HATCH"))))
  (setq tc_mj 0)
  (setq n 0)
  (while (< n (sslength tc_ss))
    (setq tc (ssname tc_ss n))
    (tc_mj_zx tc)
    (setq tc_mj (+ tc_mj tc_mj_jg))
    (setq n (1+ n))
  (princ "\n面域数量")
  (princ n)
  (princ ";面积")
  (princ tc_mj)
  (princ)
;;;;;填充面积执行
(defun tc_mj_zx        (tc /)
  (command "AREA" "O" tc)
  (setq tc_mj_jg (getvar "AREA"))
;;;;;面积
(defun c:mj (/ n1 n2 n3 n4 arc_ss arc_mj pline n)
  (princ "\n测量面积;\n请选择弧线/圆/多段线/面域/闭合填充:")
  (setq get_ss (ssget))
  (setq        get_ss_mj
         0
        n 0
  (setq        n1 0
        n2 0
        n3 0
        n4 0
        n5 0
  (setq
    arc_mj 0
    circle_mj 0
    pline_mj 0
    my_mj 0
    tc_mj 0
  (while (< n (sslength get_ss))
    (setq get_ss_n (ssname get_ss n))
    (cond
      ((eq "ARC" (cdr (assoc '0 (entget get_ss_n))))
       (arc_mj_zx get_ss_n)
       (setq n1 (1+ n1))
      ((eq "CIRCLE" (cdr (assoc '0 (entget get_ss_n))))
       (circle_mj_zx get_ss_n)
       (setq n2 (1+ n2))
      ((eq "LWPOLYLINE" (cdr (assoc '0 (entget get_ss_n))))
       (pline_mj_zx get_ss_n)
       (setq n3 (1+ n3))
      ((eq "REGION" (cdr (assoc '0 (entget get_ss_n))))
       (my_mj_zx get_ss_n)
       (setq n4 (1+ n4))
      ((eq "HATCH" (cdr (assoc '0 (entget get_ss_n))))
       (tc_mj_zx get_ss_n)
       (setq n5 (1+ n5))
    (setq n (1+ n))
  (setq n0 (+ n1 n2 n3 n4 n5))
  (setq n (- n n0))
  (setq get_ss_mj (+ arc_mj circle_mj pline_mj my_mj tc_mj))
  (princ "\n  弧线数量")
  (princ n1)
  (princ ";面积")
  (princ arc_mj)
  (princ "\n    圆数量")
  (princ n2)
  (princ ";面积")
  (princ circle_mj)
  (princ "\n多段线数量")
  (princ n3)
  (princ ";面积")
  (princ pline_mj)
  (princ "\n  面域数量")
  (princ n4)
  (princ ";面积")
  (princ my_mj)
  (princ "\n  填充数量")
  (princ n5)
  (princ ";面积")
  (princ tc_mj)
  (princ "\n----------------------\n有效对象数量")
  (princ n0)
  (princ ";无效对象数量")
  (princ n)
  (princ ";\n面积")
  (princ get_ss_mj)
  (princ)
                                        ;点选查询面积
(DEFUN C:DMJ (/ TXTH PT LastHand EN AA)
  (SETvar "CMDECHO" 0)
  (SETQ TXTH (CDR (ASSOC 40 (TBLSEARCH "STYLE" (GETvar "CMLSTYLE")))))
                                        ;当前字体高度
  (COMMAND ".UNDO" "BE")
  (SETvar "CECOLOR" "1")
  (WHILE (SETQ PT (GETPOINT "\n请选择内部点"))
    (setq LastHand (cdr (assoc 5 (entget (entlast)))))
    (COMMAND "BPOLY" PT "")
    (SETQ EN (ENTLAST))
    (IF        (/= LastHand (cdr (assoc 5 (entget en))))
                                        ;不等于才能说明已经有实体生成
      (PROGN
        (COMMAND "AREA" "O" EN)
        (SETQ AA (GETvar "AREA"))
        (IF (> TXTH 0)
          (COMMAND "TEXT" PT 0 (RTOS AA 2 3))
          (COMMAND "TEXT" PT 3 0 (RTOS AA 2 3))
        (ENTDEL EN)
      (alert "请选择内部点")
  (COMMAND ".UNDO" "E")
  (SETvar "CECOLOR" "BYLAYER")
  (PRIN1)
发表于 2006-2-21 22:10:30 | 显示全部楼层
辛苦老兄了,小弟这厢谢了
发表于 2006-2-21 22:29:33 | 显示全部楼层
再整理
  1. [FONT=courier new];;;三点面积
  2. (defun c:3dmj (/ pt1 pt2 pt3)
  3.   (command "undo" "be")
  4.   (setvar "cmdecho" 0)
  5.   (princ "\n测量三点面积;\n请依次选择三点:")
  6.   (setq        sl_mj_end 0
  7.         pt1          (getpoint)
  8.         pt2          (getpoint pt1)
  9.   )
  10.   (command "line" pt1 pt2 "")
  11.   (setq pt3 (getpoint pt2))
  12.   (command "line" pt2 pt3 pt1 "")
  13.   (3d_mj_zx pt1 pt2 pt3)
  14.   (setq 3l_chd_end (* 2 3l_chd_end))
  15.   (princ "\n周长 ")
  16.   (princ 3l_chd_end)
  17.   (princ "; 面积 ")
  18.   (princ 3l_mj_end)
  19.   (princ)
  20.   (alert (strcat "请确认: "
  21.                  "\n周长 "
  22.                  (rtos 3l_chd_end 2)
  23.                  "\n面积 "
  24.                  (rtos 3l_mj_end 2)
  25.          )
  26.   )
  27.   (command "ERASE" "l" "")
  28.   (command "ERASE" "l" "")
  29.   (command "ERASE" "l" "")
  30.   (command "undo" "e")
  31.   (setvar "cmdecho" 1)
  32.   (princ)
  33. )
  34. ;;;三点求面积
  35. (defun 3d_mj_zx        (pt1 pt2 pt3 / la lb lc)
  36.   (setq        la (distance pt1 pt2)
  37.         lb (distance pt2 pt3)
  38.         lc (distance pt3 pt1)
  39.   )
  40.   (3l_mj_zx la lb lc)
  41. )
  42. ;;;三边长求面积
  43. (defun 3l_mj_zx        (la lb lc /)
  44.   (setq        3l_chd_end (* 0.5 (+ la lb lc))
  45.         3l_mj_end  (sqrt (* 3l_chd_end
  46.                             (- 3l_chd_end la)
  47.                             (- 3l_chd_end lb)
  48.                             (- 3l_chd_end lc)
  49.                          )
  50.                    )
  51.   )
  52. )
  53. ;;;弧线面积
  54. (defun c:hmj (/ arc_ss arc_mj arc n)
  55.   (command "undo" "be")
  56.   (setvar "cmdecho" 0)
  57.   (princ "\n测量弧线面积;\n请选择弧线:")
  58.   (setq        arc_ss (ssget (list (cons 0 '"ARC")))
  59.         arc_mj 0
  60.         n      0
  61.   )
  62.   (while (< n (sslength arc_ss))
  63.     (setq arc (ssname arc_ss n))
  64.     (arc_mj_zx arc)
  65.     (setq arc_mj (+ arc_mj arc_mj_jg)
  66.           n         (1+ n)
  67.     )
  68.   )
  69.   (princ "\n弧线数量")
  70.   (princ n)
  71.   (princ ";面积")
  72.   (princ arc_mj)
  73.   (command "undo" "e")
  74.   (setvar "cmdecho" 1)
  75.   (princ)
  76. )
  77. ;;;弧线面积执行
  78. (defun arc_mj_zx (arc /)
  79.   (command "pedit" arc "y" "")
  80.   (command "AREA" "O" "l")
  81.   (command "explode" "l")
  82.   (setq arc_mj_jg (getvar "AREA"))
  83. )
  84. ;;;圆面积
  85. (defun c:ymj (/ arc_ss arc_mj circle n)
  86.   (command "undo" "be")
  87.   (setvar "cmdecho" 0)
  88.   (princ "\n测量圆面积;\n请选择圆:")
  89.   (setq        circle_ss (ssget (list (cons 0 '"CIRCLE")))
  90.         circle_mj 0
  91.         n          0
  92.   )
  93.   (while (< n (sslength circle_ss))
  94.     (setq circle (ssname circle_ss n))
  95.     (circle_mj_zx circle)
  96.     (setq circle_mj (+ circle_mj circle_mj_jg)
  97.           n            (1+ n)
  98.     )
  99.   )
  100.   (princ "\n圆数量")
  101.   (princ n)
  102.   (princ ";面积")
  103.   (princ circle_mj)
  104.   (command "undo" "e")
  105.   (setvar "cmdecho" 1)
  106.   (princ)
  107. )
  108. ;;;圆面积执行
  109. (defun circle_mj_zx (circle / r)
  110.   (setq        r             (cdr (assoc '40 (entget circle)))
  111.         circle_mj_jg (* r r pi)
  112.   )
  113. )
  114. ;;;多段线面积
  115. (defun c:plmj (/ arc_ss arc_mj pline n)
  116.   (command "undo" "be")
  117.   (setvar "cmdecho" 0)
  118.   (princ "\n测量多段线面积;\n请选择多段线:")
  119.   (setq        pline_ss (ssget (list (cons 0 "LWPOLYLINE")))
  120.         pline_mj 0
  121.         n         0
  122.   )
  123.   (while (< n (sslength pline_ss))
  124.     (setq pline (ssname pline_ss n))
  125.     (pline_mj_zx pline)
  126.     (setq pline_mj (+ pline_mj pl_mj_jg)
  127.           n           (1+ n)
  128.     )
  129.   )
  130.   (princ "\n多段线数量")
  131.   (princ n)
  132.   (princ ";面积")
  133.   (princ pline_mj)
  134.   (command "undo" "e")
  135.   (setvar "cmdecho" 1)
  136.   (princ)
  137. )
  138. ;;;多段线面积执行
  139. (defun pline_mj_zx (pline)
  140.   (command "AREA" "O" pline)
  141.   (setq pl_mj_jg (getvar "AREA"))
  142. )
  143. ;;;面域面积
  144. (defun c:mymj (/ arc_ss arc_mj pline n)
  145.   (command "undo" "be")
  146.   (setvar "cmdecho" 0)
  147.   (princ "\n测量面域面积;\n请选择面域:")
  148.   (setq        my_ss (ssget (list (cons 0 "REGION")))
  149.         my_mj 0
  150.         n     0
  151.   )
  152.   (while (< n (sslength my_ss))
  153.     (setq my (ssname my_ss n))
  154.     (my_mj_zx my)
  155.     (setq my_mj        (+ my_mj my_mj_jg)
  156.           n        (1+ n)
  157.     )
  158.   )
  159.   (princ "\n面域数量")
  160.   (princ n)
  161.   (princ ";面积")
  162.   (princ my_mj)
  163.   (princ)
  164. )
  165. ;;;面域面积执行
  166. (defun my_mj_zx        (my /)
  167.   (command "AREA" "O" my)
  168.   (setq my_mj_jg (getvar "AREA"))
  169. )
  170. ;;;填充面积
  171. (defun c:tcmj (/ arc_ss arc_mj pline n)
  172.   (command "undo" "be")
  173.   (setvar "cmdecho" 0)
  174.   (princ "\n测量填充面积;\n请选择闭合填充:")
  175.   (setq        tc_ss (ssget (list (cons 0 "HATCH")))
  176.         tc_mj 0
  177.         n     0
  178.   )
  179.   (while (< n (sslength tc_ss))
  180.     (setq tc (ssname tc_ss n))
  181.     (tc_mj_zx tc)
  182.     (setq tc_mj        (+ tc_mj tc_mj_jg)
  183.           n        (1+ n)
  184.     )
  185.   )
  186.   (princ "\n面域数量")
  187.   (princ n)
  188.   (princ ";面积")
  189.   (princ tc_mj)
  190.   (command "undo" "e")
  191.   (setvar "cmdecho" 1)
  192.   (princ)
  193. )
  194. ;;;填充面积执行
  195. (defun tc_mj_zx        (tc /)
  196.   (command "AREA" "O" tc)
  197.   (setq tc_mj_jg (getvar "AREA"))
  198. )
  199. ;;;面积
  200. (defun c:mj (/ n1 n2 n3 n4 arc_ss arc_mj pline n)
  201.   (command "undo" "be")
  202.   (setvar "cmdecho" 0)
  203.   (princ "\n测量面积;\n请选择弧线/圆/多段线/面域/闭合填充:")
  204.   (setq        get_ss (ssget)
  205.         get_ss_mj 0
  206.         n 0
  207.         n1 0
  208.         n2 0
  209.         n3 0
  210.         n4 0
  211.         n5 0
  212.         arc_mj 0
  213.         circle_mj 0
  214.         pline_mj 0
  215.         my_mj 0
  216.         tc_mj 0
  217.   )
  218.   (while (< n (sslength get_ss))
  219.     (setq get_ss_n (ssname get_ss n))
  220.     (cond
  221.       ((eq "ARC" (cdr (assoc '0 (entget get_ss_n))))
  222.        (arc_mj_zx get_ss_n)
  223.        (setq arc_mj (+ arc_mj arc_mj_jg)
  224.              n1            (1+ n1)
  225.        )
  226.       )
  227.       ((eq "CIRCLE" (cdr (assoc '0 (entget get_ss_n))))
  228.        (circle_mj_zx get_ss_n)
  229.        (setq circle_mj (+ circle_mj circle_mj_jg)
  230.              n2               (1+ n2)
  231.        )
  232.       )
  233.       ((eq "LWPOLYLINE" (cdr (assoc '0 (entget get_ss_n))))
  234.        (pline_mj_zx get_ss_n)
  235.        (setq pline_mj (+ pline_mj pl_mj_jg)
  236.              n3              (1+ n3)
  237.        )
  238.       )
  239.       ((eq "REGION" (cdr (assoc '0 (entget get_ss_n))))
  240.        (my_mj_zx get_ss_n)
  241.        (setq my_mj (+ my_mj my_mj_jg)
  242.              n4           (1+ n4)
  243.        )
  244.       )
  245.       ((eq "HATCH" (cdr (assoc '0 (entget get_ss_n))))
  246.        (tc_mj_zx get_ss_n)
  247.        (setq tc_mj (+ tc_mj tc_mj_jg)
  248.              n5           (1+ n5)
  249.        )
  250.       )
  251.     )
  252.     (setq n (1+ n))
  253.   )
  254.   (setq        n0          (+ n1 n2 n3 n4 n5)
  255.         n          (- n n0)
  256.         get_ss_mj (+ arc_mj circle_mj pline_mj my_mj tc_mj)
  257.   )
  258.   (princ "\n 弧线数量")
  259.   (princ n1)
  260.   (princ ";面积")
  261.   (princ arc_mj)
  262.   (princ "\n 圆数量")
  263.   (princ n2)
  264.   (princ ";面积")
  265.   (princ circle_mj)
  266.   (princ "\n多段线数量")
  267.   (princ n3)
  268.   (princ ";面积")
  269.   (princ pline_mj)
  270.   (princ "\n 面域数量")
  271.   (princ n4)
  272.   (princ ";面积")
  273.   (princ my_mj)
  274.   (princ "\n 填充数量")
  275.   (princ n5)
  276.   (princ ";面积")
  277.   (princ tc_mj)
  278.   (princ "\n----------------------\n有效对象数量")
  279.   (princ n0)
  280.   (princ ";无效对象数量")
  281.   (princ n)
  282.   (princ ";\n面积")
  283.   (princ get_ss_mj)
  284.   (command "undo" "e")
  285.   (setvar "cmdecho" 1)
  286.   (princ)
  287. )
  288. ;;;点选查询面积
  289. (DEFUN C:DMJ (/ TXTH PT LastHand EN AA)
  290.   (SETvar "CMDECHO" 0)
  291.   (SETQ TXTH (CDR (ASSOC 40 (TBLSEARCH "STYLE" (GETvar "CMLSTYLE")))))
  292.   (COMMAND ".UNDO" "BE")
  293.   (SETvar "CECOLOR" "1")
  294.   (WHILE (SETQ PT (GETPOINT "\n请选择内部点"))
  295.     (setq LastHand (cdr (assoc 5 (entget (entlast)))))
  296.     (COMMAND "BPOLY" PT "")
  297.     (SETQ EN (ENTLAST))
  298.     (IF        (/= LastHand (cdr (assoc 5 (entget en))))
  299.       (PROGN
  300.         (COMMAND "AREA" "O" EN)
  301.         (SETQ AA (GETvar "AREA"))
  302.         (IF (> TXTH 0)
  303.           (COMMAND "TEXT" PT 0 (RTOS AA 2 3))
  304.           (COMMAND "TEXT" PT 3 0 (RTOS AA 2 3))
  305.         )
  306.         (ENTDEL EN)
  307.       )
  308.       (alert "请选择内部点")
  309.     )
  310.   )
  311.   (COMMAND ".UNDO" "E")
  312.   (SETvar "CECOLOR" "BYLAYER")
  313.   (PRIN1)
  314. )[/FONT]
发表于 2006-2-22 20:22:49 | 显示全部楼层
学了一个LASTHAND,以前不知道,谢谢。不明白的是填充面积也可以用AREA求吗?我用14.
发表于 2006-2-27 16:27:16 | 显示全部楼层
正苦于计算面积呢,谢谢各位。
发表于 2006-8-25 21:26:35 | 显示全部楼层
谢谢,就是用时仍然有点问题。谁有调试过的?烦请发给一个。
cxg121@sina.com
发表于 2006-8-26 11:59:01 | 显示全部楼层
很有意思
发表于 2006-8-31 16:53:34 | 显示全部楼层
没弄明白是怎么回事    麻烦给小弟发一个
shuo-365@163.com 谢谢
已领礼包: 1491个
发表于 2008-4-17 00:07:50 | 显示全部楼层
能把封闭的曲线 所在层的名称也一起写出来吗
发表于 2008-4-17 08:14:57 | 显示全部楼层
最初由 LADESIGNER 发布
[B]学了一个LASTHAND,以前不知道,谢谢。不明白的是填充面积也可以用AREA求吗?我用14. [/B]
对哦,软件不是自带有个吗
发表于 2008-4-17 09:52:01 | 显示全部楼层
能不能把结果输出到平幕上啊
发表于 2008-4-25 13:39:18 | 显示全部楼层
艰I 不,
发表于 2008-4-25 15:55:12 | 显示全部楼层
是不是用region命令更简单些
已领礼包: 2个
发表于 2008-4-26 19:00:14 | 显示全部楼层
也来凑个热闹
zml的截面特性计算.lsp  见:http://zml84.blog.sohu.com/77169816.html
[php]
;;第三部分  返回结果
    (list (cons "面积" Y面积)
          (cons "形心" (list X形心 Y形心))
          (cons "形心至上" 形心至上)
          (cons "形心至下" 形心至下)
          (cons "形心至左" 形心至左)
          (cons "形心至右" 形心至右)
          (cons "对X轴静矩" (- X静矩))
          (cons "对Y轴静矩" Y静矩)
          (cons "对X轴惯性矩" (- 对X轴惯性矩))
          (cons "对Y轴惯性矩" 对Y轴惯性矩)
          (cons "对形心X轴惯性矩" (- 对形心X轴惯性矩))
          (cons "对形心Y轴惯性矩" 对形心Y轴惯性矩)
[/php]
发表于 2008-5-7 14:39:15 | 显示全部楼层
3Q
GMT+8, 2026-10-19 00:57 , Processed in 0.503798 second(s), 59 queries , Gzip On.
