查看: 807|回复: 2
[求助] [求助]:[0319]怎样由两点产生pline线呢?
发表于 2006-3-19 08:14:38 | 显示全部楼层 |阅读模式
如附图中(图1)所示,
已由程序求出两点,
但该怎样由pline 产生如(图2)所示,
的完成图面呢?
烦请各位高手帮忙解答一下~
谢谢!
(setq p:pt1 (getpoint "\n第一点:"))
(setq p:pt2 (getpoint p:pt1 "\n第二点:"))
(setq p:ss (ssget "f" (list p:pt1 p:pt2) '((0 . "line")) ))
(setq p:ss:01 (mapcar '(lambda (x) (/ x 2)) (mapcar '+ (cdr (assoc 10 (entget (ssname p:ss 0 )))) (cdr (assoc 11
(entget (ssname p:ss 0 )))) )) )
(setq p:ss:02 (mapcar '(lambda (x) (/ x 2)) (mapcar '+ (cdr (assoc 10 (entget (ssname p:ss 1 )))) (cdr (assoc 11
(entget (ssname p:ss 1 )))) )) )
(setq p:ss:03 (mapcar '(lambda (x) (/ x 2)) (mapcar '+ p:ss:01 p:ss:02 )) )
(command "_.point" p:ss:03 )
发表于 2006-3-19 12:03:33 | 显示全部楼层
“p:ss:02”这种变量写法看起来很累!
图片有问题,还是说清楚。
  1. [FONT=courier new](defun c:test ()
  2.   (setq        pt1 (getpoint "\n第一点:")
  3.         pt2 (getpoint pt1 "\n第二点:")
  4.         ss  (ssget "F" (list pt1 pt2))
  5.         ss  (ssget "p" '((0 . "LINE")))
  6.         e1  (entget (ssname ss 0))
  7.         e2  (entget (ssname ss 1))
  8.         s1  (mapcar '(lambda (x) (/ x 2))
  9.                     (mapcar '+ (cdr (assoc 10 e1)) (cdr (assoc 11 e1)))
  10.             )
  11.         s2  (mapcar '(lambda (x) (/ x 2))
  12.                     (mapcar '+ (cdr (assoc 10 e2)) (cdr (assoc 11 e2)))
  13.             )
  14.         pt3 (mapcar '(lambda (x) (/ x 2)) (mapcar '+ s1 s2))
  15.   )
  16.   (command "_.point" pt3)
  17. )[/FONT]
 楼主| 发表于 2006-3-19 12:20:50 | 显示全部楼层
再次上傳圖片
论坛的贴图怪怪的所以贴个连结的图
登录/注册后可看大图
GMT+8, 2026-11-7 01:32 , Processed in 0.391447 second(s), 34 queries , Gzip On.
