查看: 983|回复: 2
[求助] [求助]:转贴一个很好的“标注程序”,帮忙“升级”一下。
发表于 2006-3-24 10:26:22 | 显示全部楼层 |阅读模式
(defun c:da (/ p1 p2 tf p3 an)
(setvar "cmdecho" 0)
(SETQ OLDL (GETVAR "CLAYER"))
(setvar "clayer" "DIM")
  (if (and (setq p1 (getpoint "\n点取第一点: "))
    (setq p2 (getpoint p1 "\n点取第一点: "))
    (progn
      (setq an (+ (/ pi 2) (angle p1 p2)))
      (vl-cmdf ".dim" "al" p1 p2 pause "")
      (setq tf t)
      (while tf
(vl-cmdf "co")
(if (setq p3 (getpoint p2 "\n下一点<exit>: "))
   (progn (setq p3 (inters p1 p2 p3 (polar p3 an 1.) nil))
   (vl-cmdf p3)
   (vl-cmdf "")
   (setq p2 p3)
   (progn
     (command)
     (command)
     (setq tf nil))
(command "chprop" "la" "DIM" "")
(SETVAR "CLAYER" OLDL)
  (princ)
在点取第二点时,如果距离第一点比较近的话它有时会出错(标不出来),而且如果在操作途中按Esc的话,要按好几次才行,执行(setvar "clayer" "DIM"),如果按Esc就会把当前层改为“DIM”了,(SETQ OLDL (GETVAR "CLAYER"))好像没用。
发表于 2006-3-24 22:50:32 | 显示全部楼层
都用了change了,可以先dim-con后再一起ch,不必设clayer
 楼主| 发表于 2006-3-25 00:30:12 | 显示全部楼层
问题解决,谢谢楼上。
GMT+8, 2026-11-7 01:44 , Processed in 0.540850 second(s), 36 queries , Gzip On.
