查看: 1078|回复: 2
[求助] [求助]:怎样把一个长列表分成几个列表?
发表于 2006-3-30 08:18:42 | 显示全部楼层 |阅读模式
怎样将列表("A:""123""deg""*8""B:""586""bfh""C:""n9""5/9""666""H")分成三个列表?
列表1("123""deg""*8"")
列表2("586""bfh")
列表3("n9""5/9""666""H")
其中"A:""B:""C:"是固定不变的,其余元素的数量和长短是变量。
搜索没有找到有关帖子,只有请各位出手了。
实在不行,把("**""123""deg""*8""**""586""bfh""**""n9""5/9""666""H")这种形式变成三个列表也可以
已领礼包: 9347个
发表于 2006-3-30 09:38:57 | 显示全部楼层
(setq aa '("A:""123""deg""*8""B:""586""bfh""C:""n9""5/9""666""H"))
Command: (cdr (reverse (cdr (member "B:" (reverse  aa)))))
("123" "deg" "*8")
Command: (cdr (reverse (cdr (member "C:" (reverse (member "B:" aa))))))
("586" "bfh")
Command: (cdr (member "C:" aa))
("n9" "5/9" "666" "H")
发表于 2006-3-30 09:54:52 | 显示全部楼层
  1. [FONT=courier new](defun ABC-test        (lst)
  2.   (setq        C1  (member "C:" lst)
  3.         l1  (length c1)
  4.         lst (reverse lst)
  5.   )
  6.   (repeat l1
  7.     (setq lst (cdr lst))
  8.   )
  9.   (setq        lst (reverse lst)
  10.         B1  (member "B:" lst)
  11.         l1  (length b1)
  12.         lst (reverse lst)
  13.   )
  14.   (repeat l1
  15.     (setq lst (cdr lst))
  16.   )
  17.   (setq A1 (reverse lst))
  18.   (princ "\nA: ")
  19.   (print (cdr A1))
  20.   (princ "\nB: ")
  21.   (print (cdr B1))
  22.   (princ "\nC: ")
  23.   (print (cdr C1))
  24.   (princ)
  25. )[/FONT]
测试:
Command: (setq lst '("A:" "123" "deg" "*8" "B:" "586" "bfh" "C:" "n9" "5/9" "666" "H"))
Command: (abc-test lst)
A:
("123" "deg" "*8")
B:
("586" "bfh")
C:
GMT+8, 2026-11-7 01:47 , Processed in 0.498749 second(s), 36 queries , Gzip On.
