查看: 1492|回复: 2
[LISP函数]:層控制的命令
发表于 2006-5-3 08:27:31 | 显示全部楼层 |阅读模式
層刪除,層移動,層復制
可以篩選你想要的實體進行刪除,移動,復制
層刪除:
  1. (DEFUN C:DELYER()
  2. (IF (= (TYPE F1) 'FILE ) "YES"  (STOP))
  3. (IF (= (TYPE F2) 'FILE ) "YES" (STOP))
  4. (GRAPHSCR) (TERPRI)                   ;GRAPHICS MODE
  5. (SETQ OB (ENTSEL"\nSelect layer to be delete:"))
  6. (SETQ V1 (CDR (ASSOC 8 (ENTGET (CAR OB))))) ;LAYER
  7. (PROMPT"\nLayer <") (PROMPT V1) (PROMPT"> will be delete")
  8. (PROMPT"\nSelect objects :")
  9. (COMMAND "SELECT" "AU" "\")
  10. (SETQ SA (SSGET "P" ))                ;select entity
  11. (SETQ N (SSLENGTH SA))                ;LIST HOW MANY SELECT
  12. (SETQ I 0)                                 ;FIRST ENTITY
  13. (REPEAT N
  14.   (SETQ NA (ENTGET (SSNAME SA I)))      ;GET ENTITY NAME
  15.   (SETQ I (+ 1 I))
  16.   (SETQ NB (ASSOC 8 NA))
  17.   (IF (= V1 (CDR NB)) (ENTDEL (CDR (CAR NA))))
  18. )
  19. )
  20.
層移動:
  1. ;-------
  4. ;Move the entities having the same layer of selected entity
  5. (DEFUN C:MVLYER()
  6.   (SETVAR "CMDECHO" 0)
  7.   (MENUCMD "S=X")
  8.   (setq ob (entsel "\nSelect layer to be moved :"))
  9.   (SETQ D1 (CDR (ASSOC 8 (ENTGET (CAR ob)))))
  10.   (PROMPT"\nLayer <") (PROMPT D1)(PROMPT"> will be moved")
  11.   (prompt"\nSelect objects :")
  12.   (COMMAND "SELECT" "AU" "\")
  13.   (SETQ SA (SSGET "P" ))                ;select entity
  14.   (SETQ D3 (GETPOINT "\nBase point"))
  15.   (SETQ D4 (GETPOINT D3 "\nTo point:"))
  16.   (SETQ N (SSLENGTH SA))                ;LIST HOW MANY SELECT
  17.   (SETQ I 0)                                 ;FIRST ENTITY
  18.   (SETQ ALLOB (SSADD))
  19.   (REPEAT N
  20.     (SETQ NA (ENTGET (SSNAME SA I)))      ;GET ENTITY NAME
  21.     (SETQ I (+ 1 I))
  22.     (SETQ NB (ASSOC 8 NA))
  23.     (IF (= D1 (CDR NB)) (SETQ ALLOB (SSADD (CDR (ASSOC -1 NA)) ALLOB)) )
  24.   )
  25.   (COMMAND "MOVE" ALLOB "" D3 D4)
  26. )
  27.
層復制:
  1. (vmon)
  2. ;-----------------------------------------------------------|
  3. ;Move the entities having the same layer of selected entity |
  4. ;-----------------------------------------------------------|
  5. (IF (= (TYPE F1) 'FILE ) "YES"  (STOP))
  6. (IF (= (TYPE F2) 'FILE ) "YES" (STOP))
  7. (DEFUN C:cplyer()
  8.   (SETVAR "CMDECHO" 0)
  9. ; (MENUCMD "S=X")
  10.   (SETQ D5 (ENTSEL "\nSelect layer to be copied:"))
  11.   (SETQ D1 (CDR (ASSOC 8 (ENTGET (CAR D5)))))
  12.   (PROMPT"\nLayer <")(PROMPT D1)(PROMPT"> will be copied")
  13.   (SETQ ANS (STRCAT "\nCopy to whith layer <" D1 "> ?"))
  14.   (PROMPT ANS )(PROMPT (CHOSELA D1))
  15.   (PROMPT"\nSelect objects :")
  16.   (COMMAND "SELECT" "AU" "\")
  17.   (SETQ SA (SSGET "P" ))                ;select entity
  18.   (SETQ N (SSLENGTH SA))                ;LIST HOW MANY SELECT
  19.   (SETQ I 0)                                 ;FIRST ENTITY
  20.   (SETQ ALLOB (SSADD))
  21.   (REPEAT N
  22.     (SETQ NA (ENTGET (SSNAME SA I)))      ;GET ENTITY NAME
  23.     (SETQ I (+ 1 I))
  24.     (SETQ NB (ASSOC 8 NA))
  25.     (IF (= D1 (CDR NB)) (SETQ ALLOB (SSADD (CDR (ASSOC -1 NA)) ALLOB)))
  26.   )
  27.   (IF (/= (ssname ALLOB 0) 'nil )
  28.     (PROGN
  29.       (SETQ D3 (GETPOINT "\nBase point :"))
  30.       (SETQ D4 (GETPOINT D3 "\nTo point <Don't move>:"))
  31.       (IF (= D4 'NIL) (SETQ D4 D3))
  32.       (COMMAND "CHANGE" ALLOB "" "P" "LA" CHLY "")
  33.       (COMMAND "COPY" ALLOB "" D3 D4 )
  34.       (COMMAND "CHANGE" ALLOB "" "P" "LA" D1 "")
  35.     )
  36.     (progn
  37.       (prompt "\n** Warning ** :No objects in layer <")
  38.       (prompt d1)
  39.       (prompt"> are selected\n")
  40.     )
  41.   )
  42.   (grtext)
  43. )
  44. (DEFUN CHOSELA(OLDLAY)
  45. ;---------------|
  46. ;GET ALL LAYERS |
  47. ;---------------|
  48.   (SETQ LANAME (CDR (ASSOC 2 (TBLNEXT "LAYER" T))))
  49.   (SETQ ALLNAME '())
  50.   (SETQ LANU 0)
  51.   (WHILE LANAME
  52.     (SETQ ALLNAME (CONS LANAME ALLNAME))
  53.     (SETQ LANU (1+ LANU))
  54.     (SETQ LANAME (CDR (ASSOC 2 (TBLNEXT "LAYER"))))
  55.   )
  56. ;----------------|
  57. ;SORT THE LAYERS |
  58. ;----------------|
  59. ; (SETQ I 0)
  60. ; (SETQ J 1)
  61. ; (SETQ L 1)
  62. ; (SETQ K (1- LANU))
  63. ; (REPEAT K
  64. ;   (REPEAT K
  65. ;     (SETQ ST1 (NTH I ALLNAME))
  66. ;     (SETQ ST2 (NTH J ALLNAME))
  67. ;     (IF (> ST1 ST2)
  68. ;       (PROGN
  69. ;         (SETQ ALLNAME (SUBST "@@@@@" ST1 ALLNAME))
  70. ;         (SETQ ALLNAME (SUBST ST1 ST2 ALLNAME))
  71. ;         (SETQ ALLNAME (SUBST ST2 "@@@@@" ALLNAME))
  72. ;     ) )
  73. ;     (SETQ J (1+ J))
  74. ;   )
  75. ;   (SETQ K (1- K))
  76. ;   (SETQ L (1+ L))
  77. ;   (SETQ J L)
  78. ;   (SETQ I (1+ I))
  79. ; )
  80.   (setq allname (sort1 allname))
  81. ;------------------------------------|
  82. ;GET THE NUMBER OF SCREEN MENU 'SCUN |
  83. ;------------------------------------|
  84.   (SETQ SCNU 10)
  85.   (WHILE (= "" (GRTEXT SCNU "")) (SETQ SCNU (1+ SCNU)))
  86.   (SETQ SCNU (1- SCNU))
  87. ;----------------------|
  88. ;WRITE THE SCREEN MENU |
  89. ;----------------------|
  90.   (GRTEXT 2 "  ")
  91.   (GRTEXT 3 "LAYER-NA")
  92.   (GRTEXT 4 "--------")
  93.   (SETQ I 5)
  94.   (SETQ J 0)
  95.   (IF (<= LANU (- SCNU 4))
  96.     (PROGN
  97.       (WHILE (<= I SCNU)
  98.         (SETQ LN (NTH J ALLNAME))
  99.         (IF (= LN 'nil)
  100.           (GRTEXT I " ")
  101.           (GRTEXT I LN)
  102.         )
  103.         (SETQ I (1+ I))
  104.         (SETQ J (1+ J))
  105.       )
  106.       (SETQ ANS (GRREAD))
  107.       (WHILE (NOT (OR (AND (= 4 (CAR ANS)) (<= (CADR ANS) SCNU) (>= (CADR ANS) 5))
  108.                       (EQUAL ANS '(6 0))
  109.                       (EQUAL ANS '(2 13))
  110.                       (EQUAL ANS '(2 32))
  111.              )    )
  112.         (SETQ ANS (GRREAD))
  113.       )
  114.       (IF (OR (EQUAL ANS '(6 0)) (EQUAL ANS '(2 13)) (EQUAL ANS '(2 32)))
  115.         (SETQ CHLY OLDLAY)
  116.         (SETQ CHLY (NTH (- (CADR ANS) 5) ALLNAME))
  117.       )
  118.     )
  119.     (PROGN
  120.       (SETQ PAGE 0)
  121.       (SETQ ONEPAGE (- SCNU 7))
  122.       (SETQ CPAGE "NEXT")
  123.       (SETQ CPAGE1 " ")
  124.       (WHILE (<= I (- SCNU 3))
  125.         (SETQ LN (NTH J ALLNAME))
  126.         (GRTEXT I LN)
  127.         (SETQ I (1+ I))
  128.         (SETQ J (1+ J))
  129.       )
  130.       (GRTEXT (- SCNU 2) "  ")
  131.       (GRTEXT (1- SCNU) CPAGE)
  132.       (GRTEXT SCNU " ")
  133.       (SETQ ANS (GRREAD))
  134.       (SETQ ANS1 (CAR ANS))
  135.       (SETQ ANS2 (CADR ANS))
  136.       (SETQ T 3)
  137.       (WHILE (NOT (OR (AND (= 4 ANS1) (<= ANS2 (- SCNU T)) (>= ANS2 5))
  138.                       (EQUAL ANS '(6 0))
  139.                       (EQUAL ANS '(2 13))
  140.                       (EQUAL ANS '(2 32))
  141.              )    )
  142.         (IF (OR (= ANS2 (1- SCNU)) (= ANS2 SCNU))
  143.           (PROGN
  144.             (COND ((AND (= ANS2 (1- SCNU)) (= CPAGE "NEXT"))
  145.                     (PROGN
  146.                       (SETQ PAGE (1+ PAGE))
  147.                       (SETQ ANSW "T")
  148.                   ) )
  149.                   ((AND (= ANS2 SCNU) (= CPAGE1 "PREVIOUS"))
  150.                     (PROGN
  151.                       (SETQ PAGE (1- PAGE))
  152.                       (SETQ ANSW "T")
  153.                   ) )
  154.               (SETQ ANSW 'nil)
  155.             )
  156.             (IF (EQUAL ANSW "T")
  157.               (PROGN
  158.                 (SETQ I 5)
  159.                 (SETQ J (* PAGE ONEPAGE))
  160.                 (WHILE (<= I (- SCNU 3))
  161.                   (SETQ LN (NTH J ALLNAME))
  162.                   (IF (= LN 'nil)
  163.                     (PROGN
  164.                       (GRTEXT I " ")
  165.                       (SETQ T (1+ T))
  166.                       (SETQ CPAGE " ")
  167.                     )
  168.                     (PROGN
  169.                       (GRTEXT I LN)
  170.                       (SETQ T 3)
  171.                       (SETQ CPAGE "NEXT")
  172.                   ) )
  173.                   (SETQ I (1+ I))
  174.                   (SETQ J (1+ J))
  175.                 )
  176.                 (IF (> J ONEPAGE) (SETQ CPAGE1 "PREVIOUS") (SETQ CPAGE1 " "))
  177.                 (GRTEXT (1- SCNU) CPAGE)
  178.                 (GRTEXT SCNU CPAGE1)
  179.         ) ) ) )
  180.         (SETQ ANS (GRREAD))
  181.         (SETQ ANS1 (CAR ANS))
  182.         (SETQ ANS2 (CADR ANS))
  183.       )
  184.       (IF (OR (EQUAL ANS '(6 0)) (EQUAL ANS '(2 13)) (EQUAL ANS '(2 32)))
  185.         (SETQ CHLY OLDLAY)
  186.         (SETQ CHLY (NTH (+ (* PAGE ONEPAGE) (- (CADR ANS) 5)) ALLNAME))
  187. ) ) ) )
  188. (DEFUN SORT1(LIST1 / ITEM1 ITEM2)
  189.   (SETQ ITEM1 (CAR LIST1))
  190.   (FOREACH ITEM2 (CDR LIST1)
  191.     (IF (> ITEM2 ITEM1)
  192.       (SETQ ITEM1 ITEM2)
  193.     )
  194.   )
  195.   (IF LIST1
  196.     (APPEND
  197.       (SORT1
  198.         (APPEND  (CDR (MEMBER ITEM1 LIST1))
  199.                  (CDR (MEMBER ITEM1 (REVERSE LIST1))))
  200.       )
  201.       (LIST ITEM1)
  202.     )
  203.   )
  204. )
  205.
发表于 2006-5-19 09:34:51 | 显示全部楼层
不是应用在ACAD2004的吧!
发表于 2006-11-15 02:55:17 | 显示全部楼层
谢谢,辛苦了
GMT+8, 2026-11-2 17:01 , Processed in 0.475974 second(s), 36 queries , Gzip On.
