查看: 987|回复: 2
[LISP程序]:字符串倒置
发表于 2003-5-18 15:07:50 | 显示全部楼层 |阅读模式
  1. ;;字符串倒置
  2. (defun string_reverse (string / string0 cur tmp_str num)
  3.   (setq        cur        ""
  4.         string0        string
  5.   )
  6.   (while (/= (strlen string0) (strlen cur))
  7.     (progn
  8.       (setq tmp_str (substr string (strlen string)))
  9.       (if (> (ascii tmp_str) 159)
  10.         (progn
  11.           (setq tmp_str (substr string (- (strlen string) 1)))
  12.           (setq num 2)
  13.         )
  14.         (setq num 1)
  15.       )
  16.       (setq cur (strcat cur tmp_str))
  17.       (setq string (substr string 1 (- (strlen string) num)))
  18.     )
  19.   )
  20.   cur
  21. )
发表于 2005-2-17 23:44:01 | 显示全部楼层
实际应用不多
发表于 2006-5-18 13:08:54 | 显示全部楼层
怎样加载?
GMT+8, 2026-11-3 01:52 , Processed in 1.095523 second(s), 36 queries , Gzip On.
