查看: 1007|回复: 0
[LISP程序]:一个简单的程序
发表于 2006-5-21 16:02:08 | 显示全部楼层 |阅读模式
(defun C:LayList ( );;;/acadobject activedocument LayerTable thelist
  (vl-load-com)
  (setq acadobject (vlax-get-Acad-Object))
  (setq activedocument (vla-get-activedocument acadobject))
  (setq LayerTable (vla-get-layers activedocument))
  (vlax-for each LayerTable
    (setq thelist (cons (vla-get-Name each) thelist))
  (if thelist
    (reverse thelist)
  thelist
(defun C:Layeron ( / acadDocument theLayers);;;开图层程序
(vl-load-com)
(setq acadDocument (vla-get-activedocument (vlax-get-acad-object)))
(setq theLayers (vla-get-layers acadDocument))
(vlax-for item theLayers (vlax-put-property item "LayerOn" ':vlax-true))
(princ)
GMT+8, 2026-11-22 10:42 , Processed in 0.461238 second(s), 10 queries , Gzip On, File On.
