查看: 1321|回复: 2
[LISP函数]:一个通过对话框绘制腰孔的程序
发表于 2003-5-20 16:47:14 | 显示全部楼层 |阅读模式
绘制遥控程序,原创,稍作修改可以改为绘制其他图形(比如矩形)等。
LISP文件:
  1. (defun c:edrawyk (/ tl th bl dcl_id next x y p1 p3 pa pb pc pd s1 oang)
  2.   (setq bl (getvar "dimlfac"))  ;;读取比例
  3.   (princ "\n当前绘图比例: 1: ")
  4.   (princ bl)
  5.   (princ " .")
  6.   (edraw11a)
  7. )
  8. (defun edraw11a        (/)
  9.   (setq bl (getvar "dimlfac"))
  10.   (setq dcl_id (load_dialog "edraw11.dcl"))
  11.   (if (not (new_dialog "EDRAW1101" DCL_ID))
  12.     (exit)
  13.   )
  14.   (set_tile "BLM"
  15.             (strcat "当前绘图比例:  1:" (rtos bl) " 。")
  16.   )
  17.   (if (/= h nil)
  18.     (set_tile "H" (rtos h))
  19.   )
  20.   (if (/= l nil)
  21.     (set_tile "L" (rtos l))
  22.   )
  23.   (setq        x (dimx_tile "CK")
  24.         y (dimy_tile "CK")
  25.   )
  26.   (start_image "CK")
  27.   (slide_image
  28.     0
  29.     0
  30.     x
  31.     y
  32.     "EDRAW1101")
  33.   )
  34.   (end_image)
  35.   (action_tile "L" "(setq  l (distof (get_tile "L")))")
  36.   (action_tile "H" "(setq  h (distof (get_tile "H")))")
  37.   (action_tile "accept" "(done_dialog 1)")
  38.   (action_tile "cancel" "(done_dialog 0)")
  39.   (setq next (start_dialog))
  40.   (if (/= next 0)
  41.     (edraw1101)
  42.     (princ "\n用户取消程序!")
  43.   )
  44.   (unload_dialog dcl_id)
  45.   (princ)
  46. )
  47. (defun edraw1101 ()
  48.   (if (or (= l nil) (= l ""))
  49.     (progn (alert "\n您未输入有效的L值!") (edraw11a))
  50.   )
  51.   (if (or (= h nil) (= h ""))
  52.     (progn (alert "\n您未输入有效的H值!") (edraw11a))
  53.   )
  54.   (if (<= l h)
  55.     (progn
  56.       (alert "\n对不起,L值必须大于H值!")
  57.       (edraw11a)
  58.     )
  59.     (edraw1103)
  60.   )
  61. )
  62. (defun edraw1103 ()
  63.   (setq tl (/ l bl))
  64.   (setq th (/ h bl))
  65.   (setq s1 1)
  66.   (while s1
  67.     (setq p1 (getpoint "\n腰孔的中心点:/<退出>"))
  68.     (if        (= p1 nil)
  69.       (setq s1 nil)
  70.       (edraw1104)
  71.     )
  72.   )
  73. )
  74. (defun edraw1104 ()
  75.   (if (= ang nil)
  76.     (setq ang (/ pi 2))
  77.   )
  78.   (setq oang ang)
  79.   (setq        ang
  80.          (getangle
  81.            p1
  82.            (strcat "\n绘制方向<" (rtos (* (/ ang pi) 180)) " °>:")
  83.          )
  84.   )
  85.   (if (= ang nil)
  86.     (setq ang oang)
  87.   )
  88.   (setq p3 (polar p1 ang (/ th 2)))
  89.   (setq pa (polar p3 (+ ang (/ pi 2)) (/ (- tl th) 2)))
  90.   (setq pd (polar p3 (- ang (/ pi 2)) (/ (- tl th) 2)))
  91.   (setq pb (polar pa (+ ang pi) th))
  92.   (setq pc (polar pd (+ ang pi) th))
  93.   (command ".pline"
  94.            pa
  95.            "Arc"
  96.            "R"
  97.            (/ th 2)
  98.            pb
  99.            "L"
  100.            pc
  101.            "Arc"
  102.            "R"
  103.            (/ th 2)
  104.            pd
  105.            "L"
  106.            pa
  107.            ""
  108.   )
  109. )
  110. ;;
  111. DCL 文件如下:
  112. dcl_settings : default_dcl_settings { audit_level = 3; }
  113. EDRAW1101 : dialog {
  114.    initial_focus = "L" ;
  115.    label = "工程绘图" ;
  116.    : boxed_column {
  117.       fixed_width = true ;
  118.       fixed_height = true ;
  119.       width = 28 ;
  120.       height = 9 ;
  121.       : image {
  122.          color = black ;
  123.          key = "CK" ;
  124.          fixed_width = true ;
  125.          fixed_height = true ;
  126.          width = 28 ;
  127.          height = 9 ;
  128.       }
  129.    }
  130.    : boxed_column {
  131.       fixed_width = true ;
  132.       width = 29 ;
  133.       height = 5 ;
  134.       : edit_box {
  135.          edit_width = 12 ;
  136.          key = "L" ;
  137.          label = "长度(mm)L=" ;
  138.          width = 3 ;
  139.          height = 1 ;
  140.       }
  141.       : edit_box {
  142.          edit_width = 12 ;
  143.          key = "H" ;
  144.          label = "高度(mm)H=" ;
  145.          width = 3 ;
  146.          height = 1 ;
  147.       }
  148.    }
  149.    : text {
  150.       key = "BLM" ;
  151.       value="当前比例";
  152.       fixed_width = true ;
  153.       width = 36 ;
  154.       height = 1 ;
  155.    }
  156.
  157.     ok_cancel ;
  158. }
  159. ;;;结束,请把文件保存为:edraw11.dcl,放在LISP文件的同一目录下
  160. .
附件中的文件是幻灯片图。请放在程序同一目录下即可。
发表于 2003-6-6 06:29:22 | 显示全部楼层
是不是太繁琐了些?
 楼主| 发表于 2003-8-1 15:55:12 | 显示全部楼层
可能有点繁吧,不过使用中不会太麻烦吧。我的原意是想类似特定的图形,都可以用这样的方式来制作个程序,以后在使用中会方便些。这个程序本来是给在板式塔的塔板上打腰孔用的。
GMT+8, 2026-11-22 10:40 , Processed in 0.318031 second(s), 14 queries , Gzip On, File On.
