查看: 1129|回复: 0
[LISP函数]:请教高手指点(贴源码)
发表于 2006-5-25 15:34:53 | 显示全部楼层 |阅读模式
请教高手这个程序错在那里!请帮忙修改!
(defun pst(b)
   (cdr(assoc 10 b))
(defun pen(b)
   (cdr(assoc 11 b))
(defun perp(pt1 pt2 pt3)
     (inters pt1 (polar pt1 (+ (angle pt2 pt3) (/ pi 2)) 0.01) pt2 pt3 nil)
(defun inl1()
    (setq lx nil l1 nil)
    while (/= "LINE" (cdr (assoc 0 l1)))
     (setq l1 nil lx nil)
    while (= lx nil)
    (setq lx(car (entsel "\nPlease choose a boundary of a segment of the route:")))
    (setq l1(entget lx))
    (setq pa1(pst l1))
    (setq pa2(pen l1))
(defun inl2()
  (setq l2 nil lt nil)
  while (/= "LINE" (cdr (assoc 0 l2)))
   while (= lt nil)
   (setq lt(car (entsel "\nPlease choose another boundary of segment of the route:")))
    (setq l2(entget lt))
    (setq pb1(pst l2))
    (setq pb2(pen l2))
(defun iput()
    (inl1)
    (command "line" pa1 pa2 "")
    (ssadd (entlast) ss)
    (setq pb1 pa1)
    (while (or (equal pa1 pb1) (equal pa1 pb2) (equal pa2 pb1) (equal pa2 pb2))
     (inl2)
    (command "line" pb1 pb2 "")
  (setq l1(distance pa1 pa2))
  (setq l2(distance pb1 pb2))
(defun itsl1()
     (setq perp1(perp pa1 pb1 pb2))
     (setq perp2(perp pa2 pb1 pb2))
     (setq top(distance pa1 perp1))
     (setq bot(distance pa2 perp2))
     (setq l(distance perp1 perp2))
(defun itsl2()
     (setq perp1(perp pb1 pa1 pa2))
     (setq perp2(perp pb2 pa1 pa2))
     (setq top(distance pb1 perp1))
     (setq bot(distance pb2 perp2))
(defun compare()
  (if (< l1 l2)
     (itsl1)
     (itsl2)
(defun main()
  (iput)
  (compare)
  (setq lastr(computer top bot l))
  (setq res(+ res lastr))
  (prompt "\nThe electrical resistance of the segment is:(Kohm)")
  (prin1 lastr)
  (prompt "\nThe totol electrical resistances is:(Kohm) ")
  (prin1  res)
  (setq x(getstring "\nContinue?(No/<Yes>)"))
     if (and (/= x "No") (/= x "N") (/= X "n") (/= X "no") (/= X "nO") (/= X "NO"))
       (main)
       (setq l1 nil l2 nil l nil top nil bot nil pa1 nil pa2 nil pb1 nil pb2 nil)
(defun computer(top bot l)
  (if (> 0.05 (abs(- top bot)))
     (* g_res (/ l top))
     (* l (* g_res (/ (-(log top) (log bot)) (- top bot))))
(defun c:rs(/ g_res)
     (setq old_lay (getvar "clayer"))
         (if (tblsearch "layer" "S")
         (command "-layer" "set" "s" "")
         (command "-layer" "m" "s" "c"  "6" "" "")
     (setq ss(ssadd))
     (setq scmde(getvar "cmdecho"))
     (setvar "cmdecho" 0)
     (setq res 0)
     (setq g_res (getreal"\n设置玻璃表面电阻<100om>"))
     (if (not g_res)
         (setq g_res 0.1)
         (setq g_res (/ g_res 1000))
     (main)
         (setq i (sslength ss) j 0)
              (while (< j i)
         (entdel (ssname ss j))
         (setq j (1+ j))
         (setq ss nil)
     (setvar "cmdecho" scmde)
     (command "layer" "set" old_lay "")
     (PRINC)
GMT+8, 2026-11-22 08:21 , Processed in 0.300102 second(s), 10 queries , Gzip On, File On.
