查看: 929|回复: 2
[求助] [求助]:分析源代码---求助高手
发表于 2006-5-28 11:14:17 | 显示全部楼层 |阅读模式
  1. (Defun C:Checkj()
  2.   (Vl-Load-Com)
  3.   (Setvar "Cmdecho" 0)
  4.   (setq ptd '(-4890.5 828.38 00000.00))
  5.   (setq cc 6)
  6.   (Setq Sslabel (Ssget "X" '((0 . "Polyline"))))
  7.   (Setq Ssn (Sslength Sslabel))
  8.   (Setq M 0 L 0)
  9.   (Repeat Ssn             ;1求顶点坐标
  10.     (Setq En (Ssname Sslabel M))
  11.                (Setq Obj (Vlax-Ename->Vla-Object En))
  12.         (Setq Vtx (Vla-Get-Coordinates Obj))
  13.         (Setq Vtxlst (Vlax-Safearray->List (Vlax-Variant-Value Vtx)))
  14.         (Setq Ll (/ (Length Vtxlst) 3))
  15.         (Setq N 0 )
  16.         (Repeat        Ll            ;11
  17.           (Setq Pt (List (Nth N Vtxlst) (Nth (+ N 1) Vtxlst)))
  18.           (setq ptla (strcat (Rtos (Nth 0 Pt)) (Rtos (Nth 1 Pt))))
  19.           (Setq ssyuan (ssget "x" '((0 . "Circle"))))
  20.           (setq ssyuanl (sslength ssyuan))
  21.           (repeat ssyuanl;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;过滤圆
  22.             (setq eny (ssname ssyuan l))
  23.             (setq enydata (entget eny ))
  24.             (setq yuan (cdr (assoc 10 enydata)))
  25.             (setq ptyu (strcat (Rtos (Nth 0 yuan)) (Rtos (Nth 1 yuan))))
  26.             (command "PLINE" pt ptd "")
  27.             (setq pl (entlast))
  28.               (If (= ptyu ptla)
  29.                 (COMMAND "CHPROP" PL "" C CC "")  ;;;???不能变颜色???
  30.                 )
  31.             (setq l (1+ l))
  32.
  33.             );;;yuan
  34.
  35.
  36.         (Setq N (+ N 3))
  37.          );11
  38.         (Setq M (1+ M))
  39.     );;;;;;;;;;;;;;1
  40.   (setq se (ssget "x" '((62 . cc ))))  ;;;要删除改变颜色后的项
  41.   (command "erase" se "");;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;这里有问题,不能执行命令,可能这两句的位置不合适
  42.   (Princ "\n.命令:...The End...")
  43.   (princ "\n.")
  44.   ;(Prin1)
  45.   )
已领礼包: 593个
发表于 2006-5-28 11:44:48 | 显示全部楼层
'((62 . cc ))  -> (list (cons 62 cc))
(COMMAND "CHPROP" PL "" C CC "") ->  (COMMAND "CHPROP" PL "c"  CC "")
先要看清命令怎么使用!
 楼主| 发表于 2006-5-28 15:40:08 | 显示全部楼层
(COMMAND "CHPROP" PL "c" CC "")  这个也不行哟  命令行提示:命令: (COMMAND "CHPROP" PL "c" CC "")
窗口说明无效。
; 错误: *error* 函数中出错参数太多
GMT+8, 2026-11-7 04:11 , Processed in 0.381666 second(s), 36 queries , Gzip On.
