查看: 1191|回复: 2
[编程申请]:求实线虚线互相变换程序
发表于 2006-6-1 14:46:39 | 显示全部楼层 |阅读模式
本人希望高手编个能在cad中应用的实线虚线互相变换程序,非常感谢,在线期盼您的好消息!
这是天正中的虚实变换lisp文件;
(defun chinslt (bn1 bn2 lt2 / e lt1 ll)
  (setq        lt2 (cons 6 lt2)
        ll  (tblsearch "block" bn1)
        e   (cdr (assoc -2 ll))
        ll  (subst (cons 2 bn2) (cons 2 bn1) ll)
  (entmake ll)
  (while e
    (setq ll  (cdr (entget e))
          e   (entnext e)
          lt1 (assoc 6 ll)
          ll  (if lt1
                (subst lt2 lt1 ll)
                (append ll (list lt2))
    (entmake ll)
  (entmake lbe)
(defun c:chdash        (/ lbe ss ssl e bn1 bn2 ll lbn tfbd tfbd1)
  (princ "\n请选取要变换线型的图元 <退出>: ")
  (if (setq ss (ssget))
    (progn
      (command ".undo" "a" "off" ".undo" "g")
      (setq lbe        '((0 . "ENDBLK"))
            ssl        (ssadd)
      (getss ss 0)
      (setq e         (namess 0)
            bn2         (if (= "INSERT" (socas 0))
                   (car (xdout e "LT_MARK"))
                   (socas 6)
            tfbd (and bn2 (wcmatch bn2 "DASH*"))
      (while e
          (progn
            (setq bn1        (socas 2)
                  ll        (xdout e "LT_MARK")
                  tfbd1        (and ll (wcmatch (car ll) "DASH*"))
            (if        (equal tfbd tfbd1)
              (progn
                (if ll
                  (progn
                    (setq bn2 (cadr ll))
                    (if        (or (not (tblsearch "block" bn2)) (= bn1 bn2))
                      (chinslt bn1 bn2 "BYLAYER")
                    (xdin e "LT_MARK")
                  (progn (if (setq ll (assoc bn1 lbn))
                           (setq bn2 (cdr ll))
                           (progn (setq        bn2 (rndname)
                                        lbn (cons (cons bn1 bn2) lbn)
                                  (chinslt bn1 bn2 "DASH")
                         (xdin e "LT_MARK" "DASH" bn1)
                (modent 2 bn2)
          (ssadd e ssl)
        (setq e (namess 0))
      (if (> (sslength ssl) 0)
        (command ".chprop"
                 ssl
                 "lt"
                 (if tfbd
                   "bylayer"
                   "dash"
      ;(setvar "ltscale" (* 1000 (schdim "normal")))
      (command ".undo" "e" ".undo" "a" "on")
  (princ)
(defun c:chltyp        (/     lbe   ss           ss1         e     bl    blc   na0         na1
                 n     d     str   fna         llt   llna  chna  getlt tfins
  (defun chna ()
    (getss ss 0)
    (while (and (setq e (namess 0)) (not (setq na0 (getlt)))))
    (if        na0
      (progn (setq n (strlen na0))
             (while (= 'INT (type (read (substr na0 n))))
               (setq n (1- n))
             (if (= "_" (substr na0 n 1))
               (setq blc (/ (atof (substr na0 (1+ n))) 100)
                     na0 (substr na0 1 (1- n))
               (setq blc 1.)
  (defun getlt (/ lay ltn)
    (if        (and (setq tfins (= "INSERT" (socas 0)))
             (setq ltn (xdout e "LT_MARK"))
      (car ltn)
      (if (and (not tfins) (setq ltn (socas 6)))
        (if (/= "CONTINUOUS" ltn)
          ltn
        (progn (setq lay (socas 8))
               (if (setq ltn (assoc lay llna))
                 (setq ltn (cdr ltn))
                 (setq ltn  (cdr (assoc 6 (tblsearch "layer" lay)))
                       ltn  (if        (/= "CONTINUOUS" ltn)
                              ltn
                       llna (cons (cons lay ltn) llna)
               ltn
  (princ "\n请选取要改变线型比例的图元 <退出>: ")
  (if (and (setq ss (ssget)) (chna))
    (progn
      (initget 6)
            bl        (getreal
                  (strcat "\n要改变线型的放大系数 <" (rtos blc 2 2) ">: ")
            bl        (if bl
                  bl
                  blc
            blc        (rtos (* 100 bl) 2 0)
            fna        (strcat (getcd) "oo_o.lin")
      (getss ss 0)
      (while (setq e (namess 0))
        (if (setq na0 (getlt))
          (progn
              (setq n (1- n))
              (setq na0 (substr na0 1 (1- n)))
            (setq na1 (if (= 1 bl)
                        na0
                        (strcat na0 "_" blc)
                  llt (tblsearch "LTYPE" na1)
            (if        (not llt)
              (progn
                (setq llt (tblsearch "LTYPE" na0)
                      n          (1- (cdr (assoc 73 llt)))
                      llt (member (assoc 49 llt) llt)
                      d          (* bl (cdar llt))
                      str (rtos d 2 4)
                (repeat        n
                  (setq        llt (cdr llt)
                        d   (* bl (cdar llt))
                        str (strcat str "," (rtos d 2 4))
                (setvar "expert" 3)
                (command ".linetype" "c" na1 fna "" str "l" na1 fna "")
                (setvar "expert" 0)
                (fdel fna)
            (if        tfins
              (progn
                (setq na0 (socas 2))
                (chinslt na0 na0 na1)
                (setq
                  ss1 (ssget "X" (list '(0 . "INSERT") (cons 2 na0)))
                (getss ss1 1)
                (while (setq e (namess 1)) (xdin e "LT_MARK" na1 na0))
              (modent 6 na1)
  (princ)
已领礼包: 838个
发表于 2006-6-3 21:30:38 | 显示全部楼层
我也很想知道,画水面线的时候应改很有用啊
 楼主| 发表于 2006-6-8 23:17:01 | 显示全部楼层
帮帮忙哦,老师们!
GMT+8, 2026-11-3 12:30 , Processed in 0.508980 second(s), 36 queries , Gzip On.
