查看: 974|回复: 0
[求助] [求助]:批处理形心计算程序出错的问题
发表于 2006-6-14 19:17:27 | 显示全部楼层 |阅读模式
程序不稳定,多次不能完成计算.
  1.   [FONT=courier new]
  2. ((defun c:zx (/ se ss n entname ent rg f xxx xxy xxx1 xxy1 xxx2 xxy2 cep)
  3.   (setvar "CMDECHO" 0)
  4.   (setvar "FILEDIA" 0)
  5.   (setvar "LUPREC" 8)                        ;(setq se (entsel "\n 请选取欲求形心的多义线:"))
  6.   (princ "\n请选取欲求形心的多义线")
  7.   (setq se (ssget '(( 0 . "LWPOLYLINE"))))
  8.   (setq        n   (sslength se)
  9.         index 0
  10.   )
  11.   (repeat n
  12.     (setq
  13.       entname (ssname se index)
  14.       ent     (entget entname)
  15.       index   (+ 1 index)
  16.       ss      (assoc 0 ent)
  17.     )
  18.     ;(if        (= "PLINE" (cdr ss))
  19.       (progn                                ;if start
  20.         (command "copy" se "" "0,0" "0,0")
  21.         (command "region" se "")
  22.         (setq rg (entget (entlast)))
  23.         (command "massprop" "l" "" "y" "d:/ZZX.mpr")
  24.         (command "erase" "l" "")
  25.         (setq f (open "d:/ZZX.mpr" "r"))
  26.         (read-line f)
  27.         (read-line f)
  28.         (read-line f)
  29.         (read-line f)
  30.         (read-line f)
  31.         (read-line f)
  32.         (read-line f)
  33.         (setq xxx (read-line f))
  34.         (setq xxy (read-line f))
  35.         (close f)
  36.         (setq xxx1 (substr xxx 25 20))
  37.         (setq xxy1 (substr xxy 25 20))
  38.         (setq xxx2 (atof xxx1))
  39.         (setq xxy2 (atof xxy1))
  40.         (setq cep (list xxx2 xxy2 0))
  41.         (entmake
  42.           (list (cons 0 "point") (cons 8 "temp") (cons 10 cep))
  43.         )
  44.   ;    )                                        ;if end
  45.     )  ;progn end
  46.   )                                        ;repeat end
  47.   (setvar "FILEDIA" 1)
  48.   (setvar "LUPREC" 2)
  49.   (princ)
  50. )  [/FONT]
请问我这个程序哪有问题,
GMT+8, 2026-11-3 07:25 , Processed in 0.642777 second(s), 32 queries , Gzip On.
