查看: 2976|回复: 0
[求助] [求助][0614]关于"计算机"程序输入疑问?
发表于 2006-6-14 21:00:25 | 显示全部楼层 |阅读模式
请问在这计算机程序中,
该怎样让此计算机的输入,
可以支援键盘上的"num lock"数字区的输入呢?
烦请各位高手可以帮忙解答一下
谢谢~
DCL FILE:
[PHP]
exp6:dialog{
          label="数字计算机";
          :column{
           :concatenation{
            :edit_box{
               label="手动区";key="disp_user";edit_width=20;
            :button{label="↓计算↓";key="bans";width=2;}
            :edit_box{label="计算区";key="disp";edit_with=30;}
            spacer_1;
      // 第一列 共有五个框钮,分别为 ‘7’、8’、‘9’、‘%’ 、‘CE’
            :row{
              :button{label="7";key="key7";}
              :button{label="8";key="key8";}
              :button{label="9";key="key9";}
              :button{label="%";key="keyp";}
              :button{label="CE";key="keyce";}
      // 第二列 共有五个框钮,分别为 ‘4’、‘5’、‘6’、‘X’ 、‘/’
            :row{
              :button{label="4";key="key4";}
              :button{label="5";key="key5";}
              :button{label="6";key="key6";}
              :button{label="X";key="keys1";}
              :button{label="/";key="keys2";}
      // 第三列 共有五个框钮,分别为 ‘1’、‘2’、‘3’、‘+’ 、‘-’
            :row{                               // 第三列
              :button{label="1";key="key1";}
              :button{label="2";key="key2";}
              :button{label="3";key="key3";}
              :button{label="+";key="keys3";}
              :button{label="-";key="keys4";}
      // 第四列 共有三个框钮,分别为 ‘0’、‘.’ 、‘=’
            :row{                               // 第四列
              :button{label="0";key="key0";}
              :button{label=".";key="keys5";}
              :button{label="=";key="keys6";}
         spacer_1;
         ok_only;
[/PHP]
LSP FILE:
[PHP]
(if (null cal)(arxload"geomcal"))
(defun c:exp6()
   (setvar "cmdecho" 0)
   (setq dcl_id (load_dialog "exp6.dcl"))
   (dcl_exp6)
(defun dcl_exp6()
   (new_dialog "exp6" dcl_id)
   (set_tile "disp" "0")
   (setq lastinput "num" num1 "")
   (action_tile "key1" "(disp_nn \"1\")")
   (action_tile "key2" "(disp_nn \"2\")")
   (action_tile "key3" "(disp_nn \"3\")")
   (action_tile "key4" "(disp_nn \"4\")")
   (action_tile "key5" "(disp_nn \"5\")")
   (action_tile "key6" "(disp_nn \"6\")")
   (action_tile "key7" "(disp_nn \"7\")")
   (action_tile "key8" "(disp_nn \"8\")")
   (action_tile "key9" "(disp_nn \"9\")")
   (action_tile "key0" "(disp_nn \"0\")")
   (action_tile "keys1" "(keys1_n)")
   (action_tile "keys2" "(keys2_n)")
   (action_tile "keys3" "(keys3_n)")
   (action_tile "keys4" "(keys4_n)")
   (action_tile "keys5" "(keys5_n)")
   (action_tile "keys6" "(keys6_n)")
   (action_tile "keyp" "(keyp_n)")
   (action_tile "keyce" "(keyce_n)")
   (action_tile "bans" "(sub_bans)")
   (action_tile "accept" "(cal_ok)(done_dialog 1)")
   (setq dd1 (start_dialog))
   ans
(defun sub_bans()
   (setq disp_val 0)
   (setq calstr (get_tile "disp_user"))
   (if (/= calstr "")
       (progn
        (setq disp_val (cal calstr))
        (set_tile "disp"     (rtos disp_val 2 4))
       (alert "手动区,无计算式!")
(defun cal_ok()
   (setq ans (atof (get_tile "disp")))
(defun disp_nn(nn)
   (setq nn1 (get_tile "disp"))
   (if (/= nn1 "0")
      (if (= lastinput "num") (setq nn (strcat nn1 nn)))
   (set_tile "disp" nn)
   (setq lastinput "num")
(defun keyce_n()
   (setq num1 "" lastinput "num")
(defun keyp_n()
   (setq num1 (get_tile "disp"))
   (setq num1 (atof num1))
   (setq num1 (rtos (/ num1 100) 2))
   (set_tile "disp" num1)
   (setq lastinput "opt")
(defun keys1_n()
   (if (= num1 "")
      (keys6_n)
   (setq opt "*")
(defun keys2_n()
   (if (= num1 "")
      (keys6_n)
   (setq opt "/")
(defun keys3_n()
   (if (= num1 "")
      (keys6_n)
   (setq opt "+")
(defun keys4_n()
   (setq nnK (get_tile "disp"))
   (if (= num1 "")
       (cond ((= nnK "0")
                (progn
                   (set_tile "disp" "-")
             ((= nnK "")
                (progn
              (t (setq num1 (get_tile "disp") opt "-" lastinput "opt"))
       (cond ((= lastinput "opt")
             (progn
             (t (progn (keys6_n) (setq lastinput "opt" opt "-")))
(defun keys5_n()
   (setq nn (get_tile "disp"))
      (cond ((= nn "0") (set_tile "disp" "0."))
            ((= nn "")  (set_tile "disp" "0."))
            (t          (set_tile "disp" (strcat nn ".")))
(defun keys6_n()
   (setq num2 (get_tile "disp"))
   (cond ((= opt "*") (setq ans (* (atof num1) (atof num2))))
         ((= opt "/")
          (if (= (atof num2) 0)
             (progn
               (alert "Error !! Division by 0.")
               (setq ans (atof num1))
             (setq ans (/ (atof num1) (atof num2)))
         ((= opt "-") (setq ans (- (atof num1) (atof num2))))
         ((= opt "+") (setq ans (+ (atof num1) (atof num2))))
   (setq num1 (rtos ans 2))
   (setq lastinput "num" num2 "" opt "")
(prin1)
[/PHP]
GMT+8, 2026-11-7 04:50 , Processed in 0.276146 second(s), 32 queries , Gzip On.
