查看: 860|回复: 0
[求助] [求助]:求救毕业设计
发表于 2006-6-22 03:31:27 | 显示全部楼层 |阅读模式
怎么把这个旋转函数(defun c:LTMS()
  (command "ucs" "w" "vpoint" "1,-1,1" )
(command "shademode")
加到这个三维图的程序中的,三维图程序如下:
  1. (defun C:drawaxle1 (/ shuju fp xy js0)
  2. (setq shuju
  3.   '(
  4.    ("轴颈"  ("直径" 120 +0.059 +0.037 )
  5.             ("长度" 191 +0.5 0  )
  6.             ("形状" ("zdj" ("x" 10 0 0.2) 1 "圆滑过渡") ("ydy" "j"  20))
  7.             ("表面粗糙度" ("duanmian" 6.3)("zdj" 3.2)("zhumian" 1.6)("aocao" 1.6) )
  8.             ("行位公差" ("tzd" 0.010 ("yz")) ("yzd" 0.006) )
  9.             ("定位点" ("s1" 10 ~ 30) ("s2" 85 ~ 105)("S3" 28 ~ 40 "y"))
  10.      )
  11.    ("防尘板座" ("直径" 145.0 +0.015 +0.011)
  12.                 ("长度" 64 0 0 )
  13.                 ("形状" ("zdj" 1 1 )("ydy" "j" 30 "圆滑过渡细砂布打光"))
  14.                 ("表面粗糙度" ("duanmian" 3.2)("zhumian" 1.6)("ydy" 1.6 2.5) )
  15.                 ("行位公差"  ("圆跳度" 0.020 "A-B" "duanmian"))
  16.                 ("定位点"    )
  17.      )
  18.    ("轮座"  ("直径" 178 +1 -2)
  19.             ("长度"  198 0 0)
  20.             ("形状" ("zdj" ("x" 12 +4.0 0 ) 0.5) (0))
  21.             ("表面粗糙度" ("zdj" 3.2)("zhumian" 1.6) )
  22.             ("行位公差" ("直线度" 0.015 ) ("圆柱度" 0.050 ("yz"))
  23.                         ("圆度" 0.018)("同轴度" "fai" 0.015 "A-B"))
  24.             ("定位点" ("s4" 12 ~ 20)("s5" 95 105)("s6" 12 ~ 20 "y") )
  25.      )
  26.
  27.   ("轴身"   ("直径" 158 +2 0)
  28.             ("长度" 1204 0 0)
  29.             ("形状" ("zdy" "j" 75 "圆滑过渡细砂布打光") ("ydy" "j" 75) )
  30.             ("表面粗糙度" 6.3 6.3)
  31.             ("行位公差"   )
  32.             ("定位点"    )
  33.      )
  34.
  35.   ("轮座2" ("直径" 178 +1 -2)
  36.             ("长度"  198 0 0)
  37.             ("形状" ("ydj" ("x" 10 0 -2) 0.5) (0))
  38.             ("表面粗糙度" 3.2 1.6 )
  39.             ("行位公差" ("圆柱度" 0.015 ) ("圆跳度" 0.05 "A-B"))
  40.             ("定位点"    )
  41.      )
  42.   ("防尘板座2" ("直径" 145.0 +0.20 +0.12)
  43.                 ("长度" 78 0 0 )
  44.                 ("形状" ("ydj" 1 1) ("zdy" "j" 30 "圆滑过渡细砂布打光"))
  45.                 ("表面粗糙度" 1.6 )
  46.                 ("行位公差" ("圆柱度" 0.010 ) ("圆跳度" 0.02 "A-B"))
  47.                 ("定位点"    )
  48.       )
  49.   ("轴颈2"  ("直径" 120 0.068 +0.043)
  50.             ("长度" 191 +0.5 0  )
  51.             ("形状" ("ydj" ("x" 10 0 0.2) 1 "圆滑过渡") ("zdy" "j" 20))
  52.             ("表面粗糙度" 1.6 2.5 )
  53.             ("行位公差"  "A" )
  54.             ("定位点"    )
  55.      )
  56.   )
  57. )
  58.
  59.   (setq bp '(100 100))
  60.   (setq n3 (- (length shuju) 1))
  61.   (setq n 0)
  62. (while (<= n n3)
  63.   (setq zd1 (nth n shuju))
  64.   (setq zd1 (cdr zd1))
  65.   (setq zj1 (assoc "直径" zd1))
  66.   (setq zj1 (cdr zj1))
  67.   (setq d1 (car zj1))
  68.   (setq l (car(cdr(assoc "长度" (cdr (nth n shuju))))))
  69.   (setq xzp (assoc "形状" zd1))
  70.   (setq xzp (cdr xzp))
  71.   (setq n0 0)
  72.   (setq n1 1)
  73.   (setq xz1 (car (nth n0 xzp)))
  74.   (setq xz2 (car (nth n1 xzp)))
  75.   (if (or (= xz1 "zdj") (= xz1 "ydj" ))
  76.     (progn
  77.         (setq xb (cadr (nth n0 xzp)))
  78.         (if (listp xb)
  79.           (progn
  80.            (setq x1 (cadr xb))
  81.            (setq x1s (caddr xb))
  82.            (setq x1x (cadddr xb))
  83.            (setq y1 (caddr (nth n0 xzp)))
  84.           );;end progn 是表 并赋值
  85.          (progn
  86.           (setq x1 xb)
  87.           (setq y1 (caddr (nth n0 xzp)))
  88.          );;不为表
  89.         );;end if listp 是否为表
  90.         (if (= xz1 "zdj")
  91.            (Progn
  92.              (setq k 1)
  93.              (drawdjiao1 bp x1 y1 d1 k)
  94.              (if (= xz2 "ydy")
  95.               (progn
  96.                (setq k 1)
  97.                (setq bp (polar bp 0 x1))
  98.                (setq l (- l x1))
  99.                (setq dyp (cadr (nth n1 xzp)))
  100.                (setq r (caddr (nth n1 xzp)))
  101.                (princ r)
  102.                  (if (= dyp "q")
  103.                    (drawdaoyuan1 bp r d1 l k) ;;相切
  104.                    (progn
  105.                      (setq n2 (+ n 1))
  106.                      (setq d2 (car (cdr(assoc "直径" (cdr(nth n2 shuju))))))
  107.                      (setq d2 (- d2 (* 2 (caddr (nth n0 (cdr(assoc "形状" (cdr (nth n2 shuju)))))))))
  108.                      (drawdy1 bp r d1 d2 l k)
  109.                     );end progn 相交
  110.                   ) ;end if     判断是相切还是相交;
  111.                 (setq bp (polar bp 0 l))
  112.                );end progn
  113.               (progn
  114.                (setq k 1)
  115.                (setq bp (polar bp 0 x1))
  116.                (setq l (- l x1))
  117.                (drawjuxing1 bp d1 l k)
  118.                (setq bp (polar bp 0 l))
  119.               );end progn
  120.              );end if ydy
  121.             ) ;end progn 如果是左倒角
  122.            (progn
  123.                  (setq k -1)
  124.                  (setq bp (polar bp 0 l))
  125.                  (drawdjiao1 bp x1 y1 d1 k )
  126.                  (if (= xz2 "zdy")
  127.                    (progn
  128.                      (setq k -1)
  129.                      (setq bp (polar bp pi x1))
  130.                      (setq l (- l x1))
  131.                      (setq dyp (cadr (nth n1 xzp)))
  132.                      (setq r (caddr (nth n1 xzp)))
  133.                       (if (= dyp "q")
  134.                        (drawdaoyuan1 bp r d1 l k) ;;相切
  135.                        (progn
  136.                          (setq n2 (- n 1))
  137.                          (setq d2 (car (cdr(assoc "直径" (cdr(nth n2 shuju))))))
  138.                          (setq d2 (- d2 (* 2 (caddr (nth n0 (cdr(assoc "形状" (cdr (nth n2 shuju)))))))))
  139.                          (drawdy1 bp r d1 d2 l k)
  140.                         );end progn 相交
  141.                        ) ;end if     判断是相切还是相交;
  142.                      (setq bp (polar bp 0 x1))
  143.                      );end progn 如果是左倒圆
  144.                    (progn
  145.                      (setq k -1)
  146.                      (setq bp (polar bp pi x1))
  147.                      (setq l (- l x1))
  148.                      (drawjuxing1 bp d1 l k)
  149.                      (setq bp (polar bp 0 x1))
  150.                    );end progn不是倒圆
  151.                   );end if zdy
  152.                );;end progn 如果是右倒角
  153.             );;end if zdj
  154.         );; end progn 是左倒角或是右倒角
  155.           (progn
  156.                    (if (and (= xz2 "ydy") (= xz1 "zdy"))
  157.                      (progn
  158.                       (setq dyp (cadr (nth n0 xzp)))
  159.                       (setq r (caddr (nth n0 xzp)))
  160.                       (if (= dyp "q")
  161.                        (drawd1 bp r d1 l ) ;;相切
  162.                        (progn
  163.                          (setq n2 (- n 1))
  164.                          (setq d2 (car (cdr(assoc "直径" (cdr(nth n2 shuju))))))
  165.
  166.                          (drawd2 bp r d1 d2 l ) ;;对称结构r1=r2所以只考虑一个
  167.                         );end progn 相交
  168.                        ) ;end if     判断是相切还是相交;
  169.                       (setq bp (polar bp 0 l))
  170.                      ); end progn 是左右对称倒圆
  171.                     (progn
  172.                       (if (= xz1 "zdy")
  173.                        (progn
  174.                           (setq k -1)
  175.                           (setq bp (polar bp 0 l))
  176.                           (setq dyp (cadr (nth n1 xzp)))
  177.                           (setq r (caddr (nth n1 xzp)))
  178.                           (if (= dyp "q")
  179.                              (drawdaoyuan1 bp r d1 l k) ;;相切
  180.                              (progn
  181.                                (setq n2 (- 1 n))
  182.                                (setq d2 (car (cdr(assoc "直径" (cdr(nth n2 shuju))))))
  183.
  184.                                (drawdy1 bp r d1 d2 l k)
  185.                              );end progn 相交
  186.                           ) ;end if     判断是相切还是相交;
  187.                         ); end progn 是zdy
  188.                        (progn
  189.                         (if (= xz1 "ydy")
  190.                           (progn
  191.                             (setq k 1)
  192.                             (setq dyp (cadr (nth n1 xzp)))
  193.                             (setq r (caddr (nth n1 xzp)))
  194.                             (if (= dyp "q")
  195.                              (drawdaoyuan1 bp r d1 l k) ;;相切
  196.                              (progn
  197.                                (setq n2 (- 1 n))
  198.                                (setq d2 (car (cdr(assoc "直径" (cdr(nth n2 shuju))))))
  199.
  200.                                (drawdy1 bp r d1 d2 l k)
  201.                              );end progn 相交
  202.                             ) ;end if     判断是相切还是相交;
  203.                             (setq bp (polar bp 0 l))
  204.                            ); end progn ydy
  205.                           (progn
  206.                             (setq k 1)
  207.                             (drawjuxing1 bp d1 l k)
  208.                             (setq bp (polar bp 0 l))
  209.                            );;end progn
  210.                           );;end if
  211.                         );;end progn
  212.                       );;end if zdy
  213.                     ); end progn
  214.                    );end if quan
  215.             );;end progn 如果不是左倒角,也不是右倒角
  216.    );;end if 判断是否是左倒角 ,还是右倒角
  217.   (setq n (+ n 1))
  218. ) ;;end while
  219.   (COMMAND "UNION" "ALL" "")
  220. );;end defun
  221. (defun drawdjiao1( bp x1 y1 d1 k / p1 p2 p3 )
  222.   (setq p1 (list (+ (car bp) (* k x1)) (+ (cadr bp) (/ d1 2.0))))
  223.   (setq p2 (list (car bp) (- (cadr p1) y1)))
  224.   (setq p3 (list (car p1) (cadr bp)))
  225.   (command "pline" p1 p2 bp p3 p1 "")  ;;画倒角的
  226.   (command "revolve" "aLl" "" "100,100" "2224,100" "")
  227.   )
  228. (defun drawdaoyuan1 ( bp r d1 l k / p1 p2 p3 p4 p5 p6 )
  229.    (setq p1 (list (+ (car bp) (* k l)) (- (cadr bp) (* k (+ r (/ d1 2))))))
  230.    (setq p0 (list (car p1) (cadr bp)))
  231.    (setq p2 (list (+ (car bp) (* k (- l r))) (- (cadr bp) (* k (/ d1 2)))))
  232.    (setq p3 (list (car bp) (cadr p2)))
  233.    (setq p4 (list (car bp) (+ (cadr bp) (* k (/ d1 2)))))
  234.    (setq p5 (list (car p2) (cadr p4)))
  235.    (setq p6 (list (car p1) (+ (cadr bp) (* k (+ r (/ d1 2))))))
  236.    (setq p7 (list (car p6) (cadr bp)))
  237.    (if (= k 1)
  238.       (command  "line" bp p4 p5 "" "arc" p5 "e" p6 "r" r "" "line" p6 p7 bp "")
  239.       (command  "arc" p1 "e" p2 "r" r "line" p2 p3 bp p0 p1 "")
  240.    );;end if
  241.    (command "region" "all" "")
  242.    (command "revolve" "aLl" "" "100,100" "2224,100" "")
  243.    ;;相切时
  244.   )
  245. (defun drawdy1 (bp r d1 d2 l k / p0 p1 p2 p3 p4 p5 p6 p7 x )
  246.    (setq x (sqrt (- (* r r) (* (- r (/ (- d2 d1) 2)) (- r (/ (- d2 d1) 2))))))
  247.    (setq p1 (list (+ (car bp) (* k l )) (- (cadr bp) (* k (/ d2 2)))))
  248.    (setq p0 (list (car p1) (cadr bp)))
  249.    (setq p2 (list (- (car p1) (* x k)) (- (cadr bp) (* k (/ d1 2)))))
  250.    (setq p3 (list (car bp) (cadr p2)))
  251.    (setq p4 (list (car bp) (+ (cadr p3) (* k d1))))
  252.    (setq p5 (list (car p2) (cadr p4)))
  253.    (setq p6 (list (car p1) (+ (cadr p1) (* k d2))))
  254.    (setq p7 (list (car p6) (cadr bp)))
  255.    (if (= k 1)
  256.       (command  "line" bp p4 p5 "" "arc" p5 "e" p6 "r" r "" "line" p6 p7 bp "")
  257.       (command  "arc" p1 "e" p2 "r" r "line" p2 p3 bp p0 p1 "")
  258.    );;end if
  259.    (command "region" "all" "")
  260.    (command "revolve" "aLl" "" "100,100" "2224,100" "")
  261.    ;;相交时
  262.   )
  263.   (defun drawjuxing1( bp d1 l k /  p2 p3 p4 )
  264.
  265.     (setq p2 (polar bp (/ pi 2) (/ d1 2 )))
  266.     (setq p3 (list (+ (car p2) (* k l)) (cadr p2)))
  267.     (setq p4 (polar p3 (-(/ pi 2)) (/ d1 2)))
  268.
  269.     (command "pline" bp p2 p3 p4 bp "")  ;;为矩时
  270.     (command "revolve" "aLl" "" "100,100" "2224,100" "")
  271.    )
  272.   (defun  drawd1 (bp r d1 l / p1 p2 p3 p4 p5 p6 p7 p8)
  273.     (setq p1 (polar bp (/ pi 2) (+ r (/ d1 2))))
  274.     (setq p2 (list (+ (car bp) r) (+ (cadr bp) (/ d1 2))))
  275.     (setq p4 (polar p1 0 l))
  276.     (setq p3 (list (- (car p4) r) (cadr p2)))
  277.     (setq p5 (polar bp 0  l))
  278.     (command   "line" bp p1 ""
  279.               "arc" p1 "e" p2 "r" r "line" p2 p3 ""
  280.               "arc" p4 "e" p3 "r" r "line" p4 p5 bp "" )
  281.    (command "region" "all" "")
  282.    (command "revolve" "aLl" "" "100,100" "2224,100" "")
  283.   ) ;;为对称倒圆,相切的情况
  284. (defun drawd2( bp r d1 d2 l / p1 p2 p3 p4 p5 x )
  285.    (setq x (sqrt (- (* r r) (* (- r (/ (- d2 d1) 2)) (- r (/ (- d2 d1) 2))))))
  286.    (setq p1 (polar bp (/ pi 2) (/ d2 2)))
  287.    (setq p2 (list (+ (car bp) x) (+ (cadr bp) (/ d1 2))))
  288.    (setq p4 (polar p1 0 l))
  289.    (setq p3 (list (- (car p4) x) (cadr p2)))
  290.    (setq p5 (polar bp 0  l))
  291.
  292.    (command
  293.              "line" bp p1 ""
  294.              "arc" p1 "e" p2 "r" r "line" p2 p3 ""
  295.              "arc" p3 "e" p4 "r" r "line" p4 p5 bp ""
  296.              )
  297.    (command "region" "all" "")
  298.    (command "revolve" "aLl" "" "100,100" "2224,100" "")
  299. );;对称结构r1=r2所以只考虑个
  300.   ;;为对称倒圆,相交的情况时
  301. (command "color" 1);
另外怎么加个体着色的命令的
谢谢了哈
GMT+8, 2026-11-4 18:01 , Processed in 0.767192 second(s), 32 queries , Gzip On.
