查看: 1100|回复: 0
[转贴]:好久没来了,发现同行多啊
发表于 2006-6-25 13:27:26 | 显示全部楼层 |阅读模式
Home Products Solutions Subscription Store Community Support About Us Contact Us Search United States
Developer Center
Partner with Us
Products and Technologies
Heidi Development Kit
AutoCAD OEM 2007
RealDWG
AutoCAD
ObjectARX
Visual LISP
Microsoft Visual Basic for Applications
Autodesk MapGuide
Autodesk DWF Toolkit 7.2 (release)
Autodesk Inventor
Autodesk Map 3D
DWF
Autodesk Buzzsaw
Autodesk Revit
Autodesk Architectural Desktop
Autodesk Vault
API Training and Consulting
Symbols Registration
Contact Us
Press Releases
License and Download
For AutoCAD® 2007, AutoCAD® 2006, AutoCAD® 2005, AutoCAD® 2004.
NOTICE TO USER:
THIS IS A CONTRACT. BY INSTALLING THIS SOFTWARE YOU ACCEPT ALL THE TERMS AND CONDITIONS OF THIS AGREEMENT.
This Autodesk, Inc. ("Autodesk") License Agreement for ObjectARX® for AutoCAD 2007, AutoCAD 2006, AutoCAD 2005, and AutoCAD 2004 software ("Agreement") accompanies an Autodesk® Object ARX software product and related explanatory materials ("Software"). The term "Software" shall also include any upgrades, modified versions, or updates of the Software licensed to you by Autodesk. Please read this Agreement carefully.
Autodesk grants to you a nonexclusive limited license to use and copy the Software, provided that you agree to the following:
1. Use of the Software
You may install the Software in a single location on a single hard disk or other storage device; install and use the Software on a file server for use on a network for the purpose of installation onto hard disks or other storage devices or use the Software over such network; and make backup copies of the Software. You may make unlimited copies of the Software and give copies to other persons or entities so long as (i) all such copies are used to develop applications for Autodesk products based on the AutoCAD platform excluding AutoCAD LT®, DWG TrueConvert™, and DWG TrueView™ and (ii) all such copies contain this Agreement and the same copyright and other proprietary notices that appear on or in the Software. As set forth above, You may not use the Software to develop applications for AutoCAD LT®, DWG TrueConvert™, and DWG TrueView™ as the aforementioned products are non extensible applications and the use of the Software to develop applications for these products is expressly prohibited by this Agreement.
2. Copyright
The Software is owned by Autodesk and its suppliers, and its structure, organization and code are the valuable trade secrets of Autodesk and its suppliers. The Software is also protected by copyright law and international treaty provisions. You agree not to modify, adapt, translate, reverse engineer, decompile, disassemble, or otherwise attempt to discover the source code of the Software. You may use trademarks only to identify printed output produced by the Software, in accordance with accepted trademark practice, including identification of trademark owner's name. Such use of any trademark does not give you any rights of ownership in that trademark. Except as stated above, this Agreement does not grant you any intellectual property rights in the Software.
3. No Warranty
The Software is provided to you "AS IS," and you acknowledge that it may contain errors. Autodesk disclaims any warranty or liability obligations to you of any kind.
AUTODESK AND ITS SUPPLIERS DO NOT AND CANNOT WARRANT THE PERFORMANCE OR RESULTS YOU MAY OBTAIN BY USING THE SOFTWARE. AUTODESK AND ITS SUPPLIERS MAKE NO WARRANTIES, EXPRESS OR IMPLIED, AS TO NONINFRINGEMENT OF THIRD PARTY RIGHTS, MERCHANTABILITY, OR FITNESS FOR ANY PARTICULAR PURPOSE. IN NO EVENT WILL AUTODESK OR ITS SUPPLIERS BE LIABLE TO YOU FOR ANY CONSEQUENTIAL, INCIDENTAL OR SPECIAL DAMAGES, INCLUDING ANY LOST PROFITS OR LOST SAVINGS, EVEN IF AN AUTODESK REPRESENTATIVE HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES, OR FOR ANY CLAIM BY ANY THIRD PARTY.
Some states or jurisdictions do not allow the exclusion or limitation of incidental, consequential, or special damages, or the exclusion of implied warranties or limitations on how long an implied warranty may last, so the above limitations may not apply to you.
4. Governing Law and General Provisions
This Agreement will be governed by the laws of the State of California, U.S.A., excluding the application of its conflicts of law rules. This Agreement will not be governed by the United Nations Convention on Contracts for the International Sale of Goods, the application of which is expressly excluded. If any part of this Agreement is found void and unenforceable, it will not affect the validity of the balance of the Agreement, which shall remain valid and enforceable according to its terms. You agree that the Software will not be shipped, transferred or exported into any country or used in any manner prohibited by the United States Export Administration Act or any other export laws, restrictions or regulations. This Agreement shall automatically terminate upon failure by you to comply with its terms.
5. Notice to Government End Users
If this product is acquired under the terms of a GSA contract: use, reproduction or disclosure is subject to the restrictions set forth in the applicable ADP Schedule contract; DOD contract: use, duplication or disclosure by the Government is subject to restrictions as set forth in subparagraph (c)(1)(ii) of 252.227-7013; Civilian agency contract: use, reproduction or disclosure is subject to 52.227-19(a) through (d) and restrictions set forth in the accompanying end-user agreement.
Note: * indicates a required field.
* First Name:
* Last Name:
* Company:
* Street Address:
  Address 2:
* City:
* State:
Select State/Province Other Alabama Alaska Alberta Arizona Arkansas British Columbia California Colorado Connecticut Delaware District of Columbia Florida Georgia Hawaii Idaho Illinois Indiana Iowa Kansas Kentucky Louisiana Maine Manitoba Maryland Massachusetts Michigan Minnesota Mississippi Missouri Montana Nebraska Nevada New Brunswick New Foundland New Hampshire New Jersey New Mexico New York North Carolina North Dakota Northwest Territories Nova Scotia Ohio Oklahoma Ontario Oregon Pennsylvania Prince Edward Island Quebec Rhode Island Saskatchewan South Carolina South Dakota Tennessee Texas Utah Vermont Virginia Washington Washington D.C. West Virginia Wisconsin Wyoming Yukon Territory
* Country:
* Postal Code:
* Business Phone:
* E-mail:
ObjectARX for AutoCAD 2007:
I accept the license agreement.
Download ObjectARX Core Files (12.5 MB)
Download Complete ObjectARX SDK (26.3 MB)
ObjectARX for AutoCAD 2006:
Download ObjectARX Core Files (7.48 MB)
Download Complete ObjectARX SDK (19 MB)
ObjectARX for AutoCAD 2005:
Download ObjectARX Core Files (5.73 MB)
Download Complete ObjectARX SDK (16.6 MB)
ObjectARX for AutoCAD 2004:
Documentation updated on 6/17/03
Download ObjectARX Core Files (4.83 MB)
Download Complete ObjectARX SDK (14.5 MB)
Print this pageEmail this page
© Copyright 2006 Autodesk, Inc. All rights reserved. Legal Notices & Trademarks Privacy Policy
GMT+8, 2026-11-5 01:18 , Processed in 0.725857 second(s), 32 queries , Gzip On.
