查看: 1908|回复: 3
[LISP函数]:简单化锁定图层、关闭图层
发表于 2006-7-4 13:48:29 | 显示全部楼层 |阅读模式
如题:
(defun c:sd (/ ssa index n entity)
  (prompt "\n本程序用来锁定所选图层以外的图层\n")
  (setvar "cmdecho" 0)
  (setq ssa (ssget))
  (command "layer" "lo" "*" "")
  (if ssa
    (progn
      (setq n (sslength ssa))
      (setq index (- n 1))
      (repeat n
        (setq entity (ssname ssa index))
        (setq layername (cdr (assoc 8 (entget entity))))
        (if (= index (- n 1))
          (setq str1 layername)
          (progn
            (if        (not (wcmatch str1 (strcat "*" layername "*")))
              (setq str1 (strcat str1 "、" layername))
        (command "layer" "u" layername "")
        (setq index (1- index))
      (prompt
        (strcat "除" str1 "层外其他均锁定\n")
    (progn
      (command "layer" "u" "*" "")
      (prompt "\n所有层均解锁\n")
  (princ)
)http://800.zbscr.com/?dengyuqing
发表于 2009-4-28 18:03:35 | 显示全部楼层
试了,运行没问题,但有什么用呢?只能有选择地锁定图层,还得手动关闭
联系我wangyi2613312@163.com
发表于 2009-5-31 12:00:17 | 显示全部楼层
不好
解锁还要一个个解
能不能改成锁定变灰,亮显未锁定
发表于 2009-6-10 21:17:15 | 显示全部楼层
看不明白
小菜
GMT+8, 2026-11-22 11:15 , Processed in 0.381411 second(s), 16 queries , Gzip On, File On.
