查看: 5702|回复: 32
[LISP程序]:自编的dwg批量锁定程序
发表于 2006-8-24 17:52:41 | 显示全部楼层 |阅读模式
锁定核心程序是改编自那个著名的lockup,锁定方式是把所有图元变成一个多重引用的匿名块,无法炸开。
切勿在重要图纸内直接加载lockms.lsp,后果很严重[/COLOR] [/SIZE]
外壳程序是通过使用脚本实现批量锁定的,代码如下:
  1.   [FONT=courier new]
  2. ;;==============================================================================
  3. ;;==============================================================================
  4. (defun c:TW_Batchlock  (/        dcl_id         pinput           poutput   filelist
  5.              savelist  what         file2r           ow             lockm
  6.              lockp     scrfile         scrname   scr             lockfile
  7.             )
  8.   (arxload "acetutil.arx" NIL)
  9.   (vl-load-com)
  10.   (setq dcl_id (load_dialog "TW_BatchLock.dcl"))
  11.   (if (not (new_dialog "TW_BatchLock" dcl_id))
  12.     (exit)
  13.   )
  14.   (set_tile "osa" "1")
  15.   (set_tile "poutput" "c:\\dwg已加锁")
  16.   (setq        poutput        "c:\\dwg已加锁"
  17.         ow        0
  18.         lockm        1
  19.         lockp        0
  20.   )
  21.                                         ;定义选择目录程序
  22.   (defun getpath (/ res)
  23.     (setq res
  24.            (strcat
  25.              (strcase
  26.                (acet-ui-pickdir
  27.                  "选择一个目录,将添加该目录内所有dwg文件"
  28.                  (vl-string-right-trim "\" (getvar "dwgprefix"))
  29.                  "选择目录"
  30.                )
  31.              )
  32.            )
  33.     )
  34.   )
  35.                                         ;定义选择某目录内的所有dwg文件,包含路径前缀
  36.   (defun dwginpath (path / dwgfilelist)
  37.     (setq dwgfilelist (vl-directory-files path "*.DWG"))
  38.     (mapcar '(lambda (x) (strcat path "\" x)) dwgfilelist)
  39.   )
  40.                                         ;定义将表全新填入对话框中的list_box
  41.   (defun push2box (alist boxkey)
  42.     (start_list boxkey)
  43.     (mapcar 'add_list alist)
  44.     (end_list)
  45.   )
  46.                                         ;定义将字符串附加到对话框中的list_box
  47.   (defun add2box (str boxkey)
  48.     (start_list boxkey 2)
  49.     (add_list str)
  50.     (end_list)
  51.   )
  52.                                         ;定义移除文件列表中被选中的项,并重新填充列表框
  53.   (defun getboxsel (boxkey / idlist)
  54.     (setq idlist (get_tile boxkey)
  55.           idlist (str2list idlist)
  56.           idlist (mapcar 'atoi idlist)
  57.     )
  58.   )
  59.   (defun rr (/ idlist file2rl)
  60.     (setq idlist  (getboxsel "filelist")
  61.           file2rl '()
  62.     )
  63.     (princ (length idlist))
  64.     (foreach x idlist
  65.       (setq file2rl (cons (nth x filelist) file2rl))
  66.     )
  67.     (foreach x file2rl
  68.       (setq filelist (a_ext_li x filelist))
  69.     )
  70.     (push2box filelist "filelist")
  71.                                         ;(princ id)
  72.   )
  73.   (action_tile
  74.     "pi_b"
  75.     "(setq pinput (getpath)) (setq filelist (dwginpath pinput)) (push2box filelist "filelist")"
  76.   )
  77.   (action_tile
  78.     "fi_r"
  79.     "(rr)"
  80.   )
  81.   (action_tile
  82.     "poutput"
  83.     "(setq poutput $value)"
  84.   )
  85.   (action_tile
  86.     "po_b"
  87.     "(setq poutput (getpath)) (set_tile "poutput" poutput)"
  88.   )
  89.   (action_tile
  90.     "oow"
  91.     "(alert "加锁后的文件无法恢复,请慎重!!!") (mode_tile "out" 1) (setq ow 1)"
  92.   )
  93.   (action_tile
  94.     "osa"
  95.     "(mode_tile "out" 0) (setq ow 0)"
  96.   )
  97.   (action_tile "lockp" "(setq lockp (atoi $value))")
  98.   (action_tile "cancel" "(done_dialog 0)")
  99.   (action_tile "lock" "(done_dialog 4)")
  100.   (defun beginlock (/ fl1 n app filename ms of om ds cmd)
  101.     (if        (and filelist (= ow 0))
  102.       (progn
  103.         (if (not (vl-file-directory-p poutput))
  104.           (acet-file-mkdir poutput)
  105.         )
  106.         (setq fl1 '()
  107.               n          (strlen pinput)
  108.         )
  109.         (foreach x filelist
  110.           (setq fl1 (cons (strcat poutput (substr x (1+ n))) fl1))
  111.         )
  112.         (setq savelist (reverse fl1))
  113.         (mapcar        '(lambda (x y)
  114.                    (acet-file-copy x y T)
  115.                  )
  116.                 filelist
  117.                 savelist
  118.         )
  119.         (setq filelist savelist)
  120.         (setq scrfile (strcat poutput "\" "TW_batchlock.scr"))
  121.       )
  122.       (setq scrfile (strcat pinput "\" "TW_batchlock.scr"))
  123.     )
  124.     (if        filelist
  125.       (progn
  126.         (setq scrname (open scrfile "w"))
  127.         (setq lockfile "lockms.lsp")
  128.         (foreach x filelist
  129.           (setq        scr (strcat "open "
  130.                             x
  131.                             " "
  132.                             "(load "
  133.                             (chr 34)
  134.                             lockfile
  135.                             (chr 34)
  136.                             ")"
  137.                             " qsave close "
  138.                     )
  139.           )
  140.           (write-line scr scrname)
  141.         )
  142.         (close scrname)
  143.         (command "script" scrfile)
  144.         (princ)
  145.       )
  146.     )
  147.   )
  148.   (setq what (start_dialog))
  149.   (cond
  150.     ((= what 4) (beginlock))
  151.     ((= what 0) (exit))
  152.   )
  153.   (unload_dialog dcl_id)
  154. )
  155.   [/FONT]
这只是初期产品,锁定图纸空间部分还未写。
对话框预览
 楼主| 发表于 2006-8-24 17:59:00 | 显示全部楼层
大包下载吧,不要钱
发表于 2006-8-29 18:14:06 | 显示全部楼层
我用lochup加密DWG文件有个问题:
若只加密模型空间,一切都好。
若还有加密图纸空间,麻烦来了:加密后的图纸空间每回打开都要等很久很久,没法等,也就没法用了。所以只能加密模型空间。
发表于 2006-8-30 00:09:28 | 显示全部楼层
试试看
炸开嵌套块。
如果执行完程序,还没有恢复。可用普通explode命令再炸.可炸开。
发表于 2008-6-6 21:42:08 | 显示全部楼层
我在网上找来好久,知道有smartlock 及dwglock,可是前者需注册,而且花钱很多!!!
发表于 2008-6-17 00:28:38 | 显示全部楼层
xiexie
发表于 2008-6-17 10:26:05 | 显示全部楼层
非常感谢
发表于 2008-7-2 16:43:32 | 显示全部楼层
支持一下!谢谢啦!!
发表于 2008-7-3 15:47:30 | 显示全部楼层
支持下
发表于 2008-7-4 12:51:21 | 显示全部楼层
强烈支持,找这东东好久了
发表于 2008-7-5 16:23:53 | 显示全部楼层
楼主,可不可以做一个反操作的呢?
发表于 2008-7-8 20:31:09 | 显示全部楼层
好东西,下在看下了
发表于 2008-7-9 18:13:01 | 显示全部楼层
没有RMB呀,我的钱呀
发表于 2008-7-11 10:28:00 | 显示全部楼层
感性趣
发表于 2008-7-17 23:03:33 | 显示全部楼层
楼主,如何解密啊
GMT+8, 2026-11-7 02:32 , Processed in 0.464163 second(s), 61 queries , Gzip On.
