查看: 1391|回复: 2
[求助]:关于CAD2007的ET扩展工具与晓东工具箱,帮忙啊!
发表于 2006-9-7 14:14:09 | 显示全部楼层 |阅读模式
准备用2007了,可是ET还是英文的,晓东工具箱还是安装不上的
找了好几天了,也没找到ET的汉化文件,晓东工具箱我按2006的载入方法加载,可是没一个命令可以用,
1,★哪位有2007ET汉化文件或汉化方法,麻烦帮帮忙
2,★晓东工具箱其实我最常用的命令就是“命令:XDTB_LayerIso选层保留(孤立),其他层锁定变灰色,支持多选”和“命令:XDTB_LayerRes恢复选层保留到原来状态”,我找到这个LSP文件,直接AP加载也不行,我把晓东的原始LSP贴上来,哪位帮忙看看,是怎么回事?还是要改改?
这里作揖了,谢谢、谢谢
柔柔如果路过,请帮忙看看,谢了*-*1 *-*1
晓东的原始LSP:
;| "XDTB_LayerMatch" "XDTB_LayerCopy" "XDTB_LayerDel" "XDTB_LayerMerge"
   "XDTB_LayerIso" "XDTB_LayerRes" "XDTB_LayerCur"
   "layres" "layoff" "lay_set_cur" "laychg"
($xdrx_load '("xdlsp.lsp" "laywalk.arx"))
(defun #push_lay (lyr)
  (if (member lyr #lyr_l)
    (prompt "\n已经选取了改层,请继续...")
    (progn
      (setq #lyr_l (cons lyr #lyr_l))
      (redraw e 3)
(defun c:xlayres (/ e #lyr_l n)
  (while (setq e (car (entsel "\n请选取要保留图层上的实体<退出>:")))
    (xdrx_setenttodb e)
    (#push_lay (xdrx_getentdxf 8))
  (if #lyr_l
    (progn
      (xdrx_begin '("expert" 1
                   "cmdecho" 0
      (command ".layer" "of" "*")
      (foreach n #lyr_l
        (command "on" n)
      (command "")
      (xdrx_end)
  (princ)
(defun c:xlayoff (/ e #lyr_l n)
  (while (setq e (car (entsel "\r请选取要关闭图层上的实体<退出>:")))
    (xdrx_setenttodb e)
  (if #lyr_l
    (progn
      (xdrx_begin)
      (xdrx_sysvar_push "expert" "cmdecho")
      (setvar "expert" 1)
      (setvar "cmdecho" 0)
      (command ".layer")
      (foreach n #lyr_l
        (command "of" n)
      (command "")
      (xdrx_sysvar_pop)
      (xdrx_end)
  (princ)
;;设当前图层
(defun c:lay_set_cur (/ e str)
  (if (or (setq e (xdrx_entsel "\n选择设要为当前层的实体(回车输入): "))
          (/= "" (setq e (getstring "\n输入层名: ")))
    (progn
      (if (= 'LIST (type e))
        (setq e (xdrx_getentdxf 8))
      (setvar "clayer" e)
(defun c:xlaychg (/ ss key num num0 n e)
  (defun #chg_color (e cnum0 cnum / tf e blkna)
    (xdrx_setenttodb e)
    (setq tf (xdrx_getentdxf 0))
    (cond
      ((or
         (= tf "INSERT")
         (= tf "DIMENSION")
       (setq blkna (xdrx_getentdxf 2))
       (setq blkna (tblsearch "block" blkna))
       (setq e (cdr (assoc -2 blkna)))
       (while e
         (xdrx_setenttodb e)
         (if (or
               (= tf "INSERT")
               (= tf "DIMENSION")
           (progn
             (#chg_color e cnum0 cnum)
           (progn
             (xdrx_setenttodb e)
             (xdrx_modent cnum0 cnum 62 0)
         (setq e (entnext e))
      (t
  (if (or (setq num (xdrx_entsel "\n指定图层实体(回车输入): "))
          (/= "" (setq num (getstring "\n输入层名: ")))
    (progn
      (if (= 'LIST (type num))
        (setq num (xdrx_getentdxf 8))
      (xdrx_begin)
      (prompt "\n请选取要变层的实体<全选>:")
      (if (not (setq ss (ssget)))
        (setq ss (ssget "x"))
      (setq n 0)
      (xdrx_setsstodb ss 0)
      (xdrx_pbarbegin "已经完成:" (sslength ss))
      (while (setq e (xdrx_getentdata 0))
        (xdrx_pbarsetpos n)
        (setq n (1+ n))
        (#chg_color e 8 num)
        (entupd e)
  (xdrx_pbarend)
  (xdrx_end)
  (princ)
(defun c:draworder_by_layer (/ e tf)
  (if (or
        (setq
          e (xdrx_entsel "\n请点取一个要置顶的图层上的实体<输入层名>:")
        (/= "" (setq e (getstring "\n请输入要置顶的层名<退出>:")))
    (progn
      (setq tf (type e))
      (if (= 'LIST tf)
      (if (xdrx_draworder->top (ssget "x" (list (cons 8 e))))
        (prompt (strcat "\n已经成功将图层 " e " 上的实体置顶..."))
  (xdrx_object_regen)
  (princ)
   命令:XDTB_LayerIso
   功能:选层保留(孤立),其他层锁定变灰色,支持多选
(defun c:XDTB_LayerIso (/ e lyr lyrl clr el sLyrl n)
  (xdrx_begin)
  (while (setq e (xdrx_entsel "\n拾取要保留图层上的实体<结束>:"))
    (setq lyr (xdrx_getentdxf 8))
    (if (not (member lyr lyrl))
      (progn
        (setq lyrl (cons lyr lyrl))
        (redraw (car e) 3)
        (setq el (cons (car e) el))
        (xdrx_Pickset_Redraw (ssget "x" (list (cons 8 lyr))))
        (prompt (strcat "\n选中了\"" (setq sLyrl (xdrx_String_Join
        (reverse lyrl)
                        "\"层!"
  (if lyrl
    (progn
      (xdrx_object_get "layer")
      (while (setq e (xdrx_object_next))
        (if (not (wcmatch (car e) sLyrl))
          (progn
            (if (not (xdrx_getxdata (last e) "XDTB_LYR_COLOR"))
              (progn
                (xdrx_setxdata (last e) "XDTB_LYR_COLOR"
                               (xdrx_getentdxf 62) (xdrx_getentdxf 70)
                (xdrx_modent 62 251 70 4)
          (progn
            (if (setq clr (xdrx_getxdata (last e) "XDTB_LYR_COLOR"))
              (progn
                (xdrx_modent 62 (car clr) 70 (cadr clr))
                (xdrx_object_removexdata (last e) "XDTB_LYR_COLOR")
      (foreach n el
        (redraw n 4)
      (xdrx_Pickset_Redraw (ssget "x" (list (cons 8 sLyrl))) t)
  (xdrx_end)
  (princ)
   命令:XDTB_LayerRes
   恢复选层保留到原来状态
(defun c:XDTB_LayerRes (/ e clr)
    (setq e (cadr e))
    (if (setq clr (xdrx_getxdata e "XDTB_LYR_COLOR"))
      (progn
        (xdrx_object_removexdata e "XDTB_LYR_COLOR")
  (princ)
  命令:XDTB_LayerDel
  功能:删除一个层(包括层上的所有实体)
(defun c:XDTB_LayerDel (/ el lyrl lyr e1 tf e sLyrl n clayer)
  (xdrx_begin)
  (setq clayer (getvar "clayer"))
  (while (setq e (xdrx_entsel "\r拾取要删除图层上的实体<结束>:"))
          e1 (xdrx_object_get "layer" lyr)
          tf (xdrx_getentdxf 70)
    (cond
      ((= lyr "0")
        (prompt "\n不能删除\"0\"层!\n")
      ((= clayer lyr)
        (prompt "\n不能删除当前层!\n")
      ((= "DEFPOINTS" (strcase lyr))
        (prompt "\n不能删除尺寸定义点图层!\n")
      ((= 16 (logand 16 tf))
        (prompt "\n不能删除外部引用图层!\n")
      (t
        (setq el (cons e1 el))
        (xdrx_modent 62 (- (xdrx_getentdxf 62)))
  (if (and
        lyrl
        (= 1 (xdrx_yesorno "\n确定是否执行删除图层操作" 0))
    (progn
      (setq sLyrl (xdrx_String_Join lyrl ","))
      (command "._erase" (ssget "x" (list (cons 8 sLyrl))) "")
      (setq lxd el)
      (foreach n el
        (if (not (xdrx_object_hasreferences n))
          (xdrx_object_delete n)
      (prompt (strcat "\n成功删除了\"" sLyrl "\"图层!"))
    (progn
      (foreach n el
        (xdrx_setenttodb n)
  (xdrx_end)
  (princ)
  命令:XDTB_LayerMerge
  功能:图层合并,合并到目标层后将删除原来图层
(defun c:XDTB_LayerMerge (/ e lyr e1 lyrl)
  (xdrx_begin)
  (while (setq e (xdrx_entsel "\r拾取要合并图层上的实体<结束>:"))
      (cond
        ((= lyr "0")
          (prompt "\n不能合并\"0\"层!\n")
        ((= clayer lyr)
          (prompt "\n不能合并当前层!\n")
          (prompt "\n不能合并尺寸定义点图层!\n")
          (prompt "\n不能合并外部引用图层!\n")
        (t
          (prompt (strcat "\n选中了图层:\"" (setq sLyrl
                                                   (xdrx_String_Join
        (reverse lyrl)
                          "\"\n"
  (if (and
        lyrl
              ss (ssget "x" (list (cons 8 sLyrl)))
        (setq e1 (xdrx_entsel "\n请拾取目标图层<退出>:"))
        (= 1 (xdrx_yesorno "\n合并图层将删除原图层定义,是否继续" 0))
    (progn
      (xdrx_entity_setlayer ss lyr)
      (xdrx_PickSet_Redraw ss t)
      (foreach n lyrl
        (setq e1 (xdrx_object_get "layer" n))
        (if (not (xdrx_object_hasreferences e1))
          (xdrx_object_delete e1)
      (prompt (strcat "\n成功合并了图层: \"" sLyrl "\" 到目标层 \"" lyr "\""))
  (xdrx_end)
  (princ)
   命令:XDTB_LayerCur
   功能:转换实体到当前层
(defun c:XDTB_LayerCur (/ cLyr e ss)
  (prompt "\n请选取要处理的实体<退出>:")
  (if (setq ss (ssget))
    (progn
      (xdrx_begin)
      (setq cLyr (getvar "clayer"))
      (xdrx_entity_SetLayer ss cLyr)
      (xdrx_end)
      (prompt (strcat "\n已经将选取的实体转换到层\"" cLyr "\"(当前层)"))
  (princ)
  命令:XDTB_LayerMatch
  功能:图层匹配,刷子,把选取的实体图层和目标实体匹配。
(defun c:XDTB_LayerMatch (/ $XDTB_LayerMatch_change ss sel lyr)
  (defun $XDTB_LayerMatch_change (ss lyr / e)
      (xdrx_modent 8 lyr)
  (if (setq sel (car (xdrx_entsel "\n请选取匹配的目标层的实体<输入>:")))
    (progn
      (if (= "" (setq lyr (getstring "\n请输入匹配的层名:")))
        (progn
          (if (= 1 (xdrx_yesorno "\n是否使用当前层" 1))
            (progn
              (setq lyr (getvar "clayer"))
            (setq lyr nil)
  (if (and
        lyr
        (progn
          (prompt "\n请选取要改变的实体<退出>:")
          (setq ss (ssget))
    (progn
;|          ($XDTB_LayerMatch_change ss lyr)|;
      (xdrx_begin)
      (xdrx_entity_SetLayer ss lyr)
      (xdrx_end)
      (prompt (strcat "\n已经将选取的" (itoa (sslength ss))
                      "个实体图层匹配到\"" lyr "\"层!"
  (princ)
   命令:XDTB_LayerCopy
   功能:转换图层
        该工具可以把一个层上的所有实体转移到另外一个层上,如果选输入层名,目标图层不存在新建。
(defun c:XDTB_LayerCopy (/ ss sLyr dLyr e)
  (if (xdrx_entsel "\n请选取要处理的一个层上的实体<退出>:")
    (progn
      (setq sLyr (xdrx_getentdxf 8))
      (xdrx_begin)
      (setq ss (ssget "x" (list (cons 8 sLyr))))
      (xdrx_Pickset_redraw ss)
      (if (xdrx_entsel "\n请选取目标图层上的实体<输入>:")
        (setq dLyr (xdrx_getentdxf 8))
        (progn
          (if (= "" (setq dLyr (getstring "\n请输入目标层名:")))
              (setq dLyr (getvar "clayer"))
            (setq dLyr nil)
      (if dLyr
        (progn
          (xdrx_entity_setlayer ss dLyr)
          (prompt (strcat "\n已经成功的将图层\"" sLyr
                          "\"上的所有实体转换到图层\"" dLyr "\""
      (xdrx_Pickset_redraw ss t)
      (xdrx_end)
  (princ)
  所有层开
(defun c:XDTB_LayerOn()
   (xdrx_sysvar_push "cmdecho")
   (command "_layer" "on" "*" "")
   (xdrx_sysvar_pop)
   (princ)
   2003年3月8日新增
   命令:XDTB_LayerLock
(defun c:XDTB_LayerLock (/ e lyr lyrl clr el sLyrl n)
  (xdrx_begin)
  (while (setq e (xdrx_entsel "\n拾取要锁定图层上的实体<结束>:"))
      (progn
        (redraw (car e) 3)
        (reverse lyrl)
                        "\"层!"
  (if lyrl
    (progn
        (if (wcmatch (car e) sLyrl)
          (progn
              (progn
          (progn
              (progn
  (xdrx_end)
  (princ)
发表于 2006-9-7 14:43:19 | 显示全部楼层
  ET工具2007版的汉化版已经有了,在本论坛里可以找到。
  但是,如果你只用ET或晓东工具箱的图层管理功能,那么在2007下就没有必要安装它们了:首先,ACAD2007中已把ET的图层管理功能吸收进去了,工具栏“图层II”即是;其次,对于ACAD2007环境下的ET,其图层管理功能已去掉了,而晓东工具箱目前还没有升级到支持ACAD2007。
 楼主| 发表于 2006-9-7 15:06:41 | 显示全部楼层
终于找到一个ET汉化,就是楼上花清扬的
哎……辛苦,找得很辛苦
晓东工具箱上面的两个命令只好退一步,用锁定非选择层和解锁全部层了,差距就是锁定的层不是灰色显示,对付着用吧
就这样先了……
GMT+8, 2026-11-3 00:39 , Processed in 0.581985 second(s), 36 queries , Gzip On.
