查看: 1591|回复: 1
[求助]:偏移问题求助,变量设置问题
发表于 2006-9-16 10:18:42 | 显示全部楼层 |阅读模式
Sub Ch4_OffsetPolyline()
    ' 创建多段线
    Dim plineObj As AcadLWPolyline
    Dim points(0 To 11) As Double
    points(0) = 1: points(1) = 1
    points(2) = 1: points(3) = 2
    points(4) = 2: points(5) = 2
    points(6) = 3: points(7) = 2
    points(8) = 4: points(9) = 4
    points(10) = 4: points(11) = 1
    Set plineObj = ThisDrawing.ModelSpace. _
                   AddLightWeightPolyline(points)
    plineObj.Closed = True
    ZoomAll
    ' 偏移多段线
    Dim offsetObj As Variant
    offsetObj = plineObj.Offset(0.25)
ZoomAll
End Sub
如果Dim offsetObj As Variant 改成AcadLWPolyline就不行,为啥
发表于 2006-9-27 19:32:33 | 显示全部楼层
因为offsetObj 是个数组,而改成AcadLWPolyline当然不行了。
请参照学习本论坛相关主题。
GMT+8, 2026-11-22 07:46 , Processed in 2.202949 second(s), 12 queries , Gzip On, File On.
