查看: 993|回复: 2
[LISP程序]:兩點之間 等分
发表于 2006-10-20 20:28:45 | 显示全部楼层 |阅读模式
依據輸入的兩點,等分,並劃出等分線
(defun c:test (/)
        (setq old_osmode         (getvar "OSMODE"))
        (setq old_ortho         (getvar "ORTHOMODE"))
        (setvar "OSMODE" 512)
        (initget 1)(setq p1 (getpoint "\n 等分長度,第一點: "))
        (setvar "OSMODE" 128)
        (initget 1)(setq p2 (getpoint p1 "\n 等分長度,第二點: "))
        (setvar "OSMODE" 0)
        (setvar "ORTHOMODE" 0)
        (initget 1)(setq p3 (getpoint "\n 等分線段長度,第一點: "))
        (initget 1)(setq p4 (getpoint p3 "\n 等分線段長度,第二點: "))
        (setvar "OSMODE" old_osmode)
        (setvar "ORTHOMODE" old_ortho)
        (initget 7)(setq num (getint "\n 等分數: "))
        (setq
                dst                (distance p1 p2)
                off_dst        (/ dst num)
                ang                (angle p1 p2)
                perang        (+ ang (/ pi 2.0))
                dp1                (inters p1 (polar p1 perang 1) p3 (polar p3 ang 1) nil)
                dp2                (inters p1 (polar p1 perang 1) p4 (polar p4 ang 1) nil)
        ) ; end setq
        (repeat (1- num)
                (setq
                        dp1                (polar dp1 ang off_dst)
                        dp2                (polar dp2 ang off_dst)
                ) ; end setq
                (entmake         (list
                                        (cons 0         "LINE")
                                        (cons 8         (getvar "CLAYER"))
                                        (cons 10         dp1)
                                        (cons 11         dp2)))
        ) ; end repeat
) ; end defun
已领礼包: 54个
发表于 2008-7-29 11:50:54 | 显示全部楼层
这一个不错嘛,在某些时刻很好用……
已领礼包: 4个
发表于 2019-11-2 15:58:31 | 显示全部楼层
收藏备用,谢谢分享
GMT+8, 2026-11-5 05:12 , Processed in 0.384171 second(s), 37 queries , Gzip On.
